Tyre Pressures
Submitted: Thursday, Nov 17, 2005 at 17:31
Brian Bentley
Hello again,
I was on a couple days ago asking about leaf springs, how i could improve ride quality in my 94model landcruiser ute.
I decided to decrease my tyre pressure from 50 psi to 40 psi and my ride quality has dramatically improved.
I have BFG 32x11.5x15 muddys on and i was wondering what the correct tyre pressure would be on and off road?
The tyres say max 50psi (at a certain tonne) but do not specify on or off road.
Would running my tyres at 40 psi all the time have any serious consequences later on?
Reply By: Muddy 'doe (SA) - Thursday, Nov 17, 2005 at 18:30
Hah, Many car manuafacturers recommend pressures down around 26psi to improve ride comfort but most 4by's run about 35 to 40 psi on tar and 25 to 30 on gravel. Off road in sand you can go as low as 8-12psi to get the effect of a larger footprint on the ground to increase grip but generally 15 to 20psi good for off road.
ALWAYS depends on individual vehicle and what size tyres. If you are fully loaded then add 5 to 10 psi to these figures. 50 psi sounds high unless you have heavy load on. I run 40 generally.
There are many opinions on Tyre Pressures and you may get a few on this thread.
The lower the pressure the greater the contact patch with the road and the more the tyre can deform over rocks and objects. Trade off is that at low pressures you run risk of poor handing or rolling tyre off rim so easy does it on the right foot. At low pressures and higher speed the sidewalls of the tyre also heat up due to the friction of flexing and can blow out. Low Pressure = Lower Speeds.
Also remember there will be a difference of about 4psi between cold and hot tyres.
Muddy
139815
Reply By: Exploder - Thursday, Nov 17, 2005 at 18:55
Short answer, No it will not cause any problems you should be concerned about, A little more tread wear possibly.
139822
Reply By: simple - Thursday, Nov 17, 2005 at 20:21
50psi sounds too high, it'd be like driving on the
wheels off an old horse drawn cart, all steel and wood.
i drive a patrol ute and run 36psi all round on road cos i dont carry much, if loaded i might go higher. tried 40psi but found it too harsh unloaded.
139834
Reply By: Truckster (Vic) - Thursday, Nov 17, 2005 at 20:24
Try 36/38psi on road.
Offroad all depends on "the conditions"..
Dirt road, firetrails, mud, wet, dry clay, etc.. anything down to 10psi should be fine offroad depending on the conditions.
139835
Follow Up By: Willem - Thursday, Nov 17, 2005 at 21:55
I run 32 in the STT's on the black top. Wagon rides comfy
28 on dirt
25 in rougher dirt
16 in sand
Tyre wear seems to be OK...noise not too bad
393544
Reply By: Member - Jeff M (WA) - Thursday, Nov 17, 2005 at 21:49
I find a good rule of thumb (but this depends on the vehicle, load and tyre sizes) is:
42psi on Road.
29psi on Gravel.
16psi on Sand. (but anywhere down to 10psi when the going gets tough)
Try em', it won't hurt, and I reckon it'll work
well for you. Personally I have run these same pressures on:
Daihatsu Feroza (approx 1.5 tonne with 205 15 tyres)
Daihatsu Rocky (approx 2.2 tonne with 9R tyres)
Toyota Surf (anywhere between 2.1 to 3 tonne plus loaded with 31" tyres).
Good luck with it! Just muck around with it.
139856
Reply By: Blaze - Friday, Nov 18, 2005 at 00:52
Willem has the figures spot on, maybe even 30 in the blacktop if your travelling light. I run a Tirealert system which gives you pressure and temp readouts continually from each wheel, and may surprise a few the temp and pressure changes that go through over inflated tyres on asphalt, with 30psi in the backs and 28 in the front, I checked them on some HOT blacktop, tyres ranged from 28psi to 40 and 28deg to 65 after about 80k's, next morning I inflated them to 38psi, pressure rose to 55psi and temp nudged 75c. So some food for thought. Wragler MTR's which aren't really suited to full time use get over 60,000k's with 30psi pressure on blacktop.
139883
Follow Up By: Member - Jeff M (WA) - Friday, Nov 18, 2005 at 16:41
Blaze you should find you're tyres heat up less on hot sealed roads at higher tempetures as the metal sidwalls flex less, ergo producing less heat and fatique in the tyre wall.
393676
Follow Up By: Blaze - Saturday, Nov 19, 2005 at 03:13
Hi Jeff,
My records show there was very little difference between black top and off road, I guess when you think about it, on the tracks the sand and ground are to hot to stand on with bare feet and as you say the tyres are working harder...on the sealed roads there is a lot more heat transfered from axles bearings and especially brakes. I was amazed to hear at one of the last V8 Races that they generate more heat in the tyres in warm up laps from the heat transfer from the brakes through the rims etc than in any other way (such as swerving like they do)
One thing I was hoping everyone took notice of was that if you drive 10 k's down the road to Sevice station and check your tyres they will not be the pressure later into the trip or warly the next morning.
393710
Reply By: Turbo Diesel - Friday, Nov 18, 2005 at 13:41
Brian
Tyres tyres, just curious about your cruiser if its a diesel or a petrol, my brother and i have found in his 97 model 75 series diesel ute that the 32 x 11.5 put to much of a strain on the motor in sand, (The humble 1HZ never had that much go, rather it just keeps on goen) he changed over to 265 75R16 that according to BFG are 30mm smaller in width but the same overall diameter. I dont want to start a tyre debate AGAIN however you may find that a smaller tyre width will help overall with economy and noise and off road ability and etc etc. The idea of lettling your tyres down is to increase the track of the tyre NOT THE WIDTH. In other words your tyre should act like a set of excavator tracks. A tyre that alot of people don't know exists is a 235 75R16 BRG MT an absolute weapon in the mud and dirt. Just thought that 50psi is to much.
139953
