nokia 6255
Submitted: Saturday, Nov 19, 2005 at 18:45
ThreadID: 28217 Views:2517 Replies:9 FollowUps:7
hey people does any one recommend this phone need new cdma phone looking for top range phone. have had a lot of bleep with the low price ones. any help would be great.
Reply By: pojo - Saturday, Nov 19, 2005 at 20:17
i would forget CDMA as Telstra is doing away with them
AnswerID: 140066
Follow Up By: Brew69(SA) - Saturday, Nov 19, 2005 at 21:23
Not for another 3 years...don't know about you but that makes 3 more phones for me.
FollowupID: 393782
Reply By: Member - Cruisin' Dave (WA) - Saturday, Nov 19, 2005 at 21:12
Hi sxc_thing,
My son has a 6255 and reckons it is a great unit. Takes nice pictures and videos that you can download to your PC. I have a 6225, with a vehicle handsfree kit installed and a 9db antenna on the bullbar. Do a bit of country travel and I haven't found a spot without coverage yet. Mind you it hasn't been far off the beaten track. They are both great little phones.
CDMA is here for a few years yet so I think CDMA is still the way to go. Most people change their phone every few years so CDMA may be dead by the next time you need a phone.
Cheer
David
AnswerID: 140073
Follow Up By: angler - Saturday, Nov 19, 2005 at 21:33
Seems to be a lot of 6225 phone on ebay and I was wondering if they had some sort of problem. You have answered my questions, they seem pretty good. My 2280 uses battery power like its going out of style. I have tried for a couple of months now to get the thing to work on the laptop for net access wilth a nil result. Nokia has not answered my emails and this is aparently normal for nokia.
Pooley
FollowupID: 393785
Follow Up By: Member - Phil [Sunshine Coast] - Saturday, Nov 19, 2005 at 22:12
Giday angler, I,ve got the same ph. works great, BUT, I cant get the sh*t of a thing to con. to the net either!!! Telstra stepped me through the internet set up but it still wont happen.I can transfer data etc. to the comp. but thats it! I,m just goin to go with the telstra broadband card[ $49 mth.] from all accounts that seems to work okay.. cya
FollowupID: 393789
Follow Up By: angler - Sunday, Nov 20, 2005 at 21:19
Phil,
I can load the modem up each time however I can't get the modem to change from com port 1 to com port 5. If I could do that I reckon I would be in with a chance.
Any chance of sending me your modem drivers? Do you have any instructions at all?
gu2u2athotmaildotcom
Cruisin dave, sorry for the off post messages.
FollowupID: 393848
Follow Up By: Member - Captain (WA) - Monday, Nov 21, 2005 at 00:13
Hi Angler,
I use my 6225 regularly to connect to the net, it works fine once all the right ports settings are selected. To change the port settings you need to;
Go to Control panel, then System, then hardware, then device manager. Scroll down to ports and select the nokia phone. Click on it and then click on the port settings tab and finally you can select which port you want the phone to connect to.
Once you have changed it in WindowsXP, you may need to change the port setting on the Nokia PC suite software. Simply open the nokia suite and then click on adbvanced settings. Change the port number here so they match up and you should be fine.
Hope this helps
Captain
FollowupID: 393876
Follow Up By: angler - Monday, Nov 21, 2005 at 10:08
Captain,
No help as far as the nokia modem is concerned. What modem version do you use ? ie what one is installed? This is available via the dial up poroperties tab.
More about the 2280 phone, Like Phil I can get the phone to transfer data to the computer via port 6 no problems, I can do updates and change phone numbers etc but when trying to use it as a modem we both get zilch or something similar. The modem loads manually, and XP can't find the nokia modem automatically. I am given the choice of four modems using the supplied nokia cd and all load to port 1.
In device manager the modem tab shows a nokia modem and there is no way to change it to port or six or whatever. The thing loads to port 1 and changing ports is not an option.
OK There is a nokia on port 6 and that part works fine as both Phil and I said before, its not the transfer of data thats the problem it's the B modem that won't work.
I will persis for a while. At least unitl CDMA is defunct.
Phil, What modem version did telstra tell you to use?
Pooley
FollowupID: 393895
Follow Up By: angler - Wednesday, Nov 23, 2005 at 22:37
To all who are having a bit of trouble getting your 2280 phone on the net from your laptop I have found what I was doing wrong.
Remove the PC suite from your computer. Load up the modem driver and use the one that does not mention 2g or 3g. The modem should load up to the correct comm port as PC suite is not loaded.
Load PC suite and it will be able to find the phone at the same port as your modem.
If you do it the other way round the PC suite takes over and stops the modem from loading to the correct port.
I tried it last night and all works now Yippee!!!!
FollowupID: 394356
Reply By: Big Woody - Saturday, Nov 19, 2005 at 21:59
6255 was the best thing i ever did. We have quite a few of them at work. We brought ours the same day they were released and 2 of them had to go back and be reprogrammed because they stopped accepting a charge, but Telstra shop have advised that the issue was solved quickly and all phones sold after the 2nd week of release already had the issue fixed.
I would definately recommend it.
Brett
AnswerID: 140079
Reply By: sxc_thing - Sunday, Nov 20, 2005 at 07:55
thanks people think i might go down on wedsday and put the 2280 away as she dont workany more . thanks again
AnswerID: 140111
Reply By: lorry - Sunday, Nov 20, 2005 at 07:58
Checking out Fairfax papers on the Internet this morning, in the item about Telstra a spokesman says not to worry about having to get rid of your present mobile phone, as the changeover will be gradual. Will be 2008 before we have to do anything. He said most people change their phones every 18 months anyway. We don't!
AnswerID: 140112
Reply By: Eric from Cape York Connections - Sunday, Nov 20, 2005 at 09:33
I saw on sunrise that as of 1st January new system is coming in but cdma will be going to 2008.
All the best
Eric
AnswerID: 140116
Reply By: Member - Kim R (QLD) - Sunday, Nov 20, 2005 at 12:56
Hi, I have a Nokia 6225 , have found it quite reasonable out in the bush out performe the digital one by quite a lot.
there is a new one out that looks even better: Nokia 6235.
Good Luck
AnswerID: 140125
Reply By: Turbo - Monday, Nov 21, 2005 at 17:43
Hi just updated our phones mine 6225,hers 6255, both cdma. We live in very poor reception area. I think that both have good reception but the 6255 is by far the best. Picking up calls in the house which never happened with the previous Nokia CDMA (6385) or 3x LG CDMA's we have had before. We are in a remote area, SA ,with marginal coverage according to Telstra coverage map.
AnswerID: 140272
Reply By: Flash - Monday, Nov 21, 2005 at 19:03
Bloody Telstra!
I spent a lot of money on phone, carkit, and antenna and now it's wasted as CDMA is on the way out. I'm REALLY angry about this.
AnswerID: 140288
