Battery Thingo
Submitted: Monday, Nov 21, 2005 at 11:10
ThreadID: 28249 Views:2757 Replies:3 FollowUps:7
I am getting a new Coromal Silhoutte Camper with solar panels, etc already fitted up. I have been told there is a device that you can get that will tell you how much power there is left in the battery and when it needs to be charged, etc. I am sure someone on this forum will be able to tell me what the device is please.
Thank you.
The Bigfella
Reply By: Motherhen - Monday, Nov 21, 2005 at 11:27
You are buying the caravan already fitted for 12 v? Surely it would already have the digital thingo fitted. If not, go to a 12 volt shop.
AnswerID: 140226
Follow Up By: The Bigfella - Monday, Nov 21, 2005 at 13:03
Thanks for the info. Maybe it will have the digital thingo already fitted. Hopefully will find out in about 3 weeks when I pick it up.
The Bigfella
FollowupID: 393918
Follow Up By: Motherhen - Monday, Nov 21, 2005 at 13:33
I can't imagine them setting up solar and not including one. They are not expensive anyway, and tell you what amps are going in, coming out, and voltage level of batteries, plus a number of warning lights - eg green, all is OK, orange, battery getting low, and red - too low. In the small camper we set up with a portable solar panel and one deep cycle battery, we would turn the fridge off at night if it got to orange. With the present caravan, while parked at home, we just watch it daily and put lights on and off to maintain batteries at optimum level (too low or too high will shorten battery life).
FollowupID: 393922
Follow Up By: V8troopie - Monday, Nov 21, 2005 at 16:13
Motherhen, your last sentence got me thinking that you got too much time on your hands.
Sure, your regime of watching a battery monitor and switching things off and on might work but a simple little solar regulator does all that fully automatically.
If the solar regulator is set correctlyit will NOT overcharge the battery, neither will it undercharge it, in fact, I dare to suggest, it would maintain a far better charge level than you will ever be able to do manually with your method.
Klaus
FollowupID: 393936
Follow Up By: Motherhen - Monday, Nov 21, 2005 at 16:23
Hi Klaus, We just keep thing ticking over nicely - usually one light is sufficient, but on a clear day sometimes needs 2. I understand giving the fridge a run every now and then is a good idea, so did that once instead when levels were a bit on the high side. Some people in hotter areas leave just the fridge running to keep everything in good order, here a light is usually adequate. Only once did they go too low - missed checking over a few wintery days. Everything switched off, and only came back to life when we used the battery charger.
FollowupID: 393938
Reply By: Member - JD - Monday, Nov 21, 2005 at 11:37
Hi Bigfella,
Please dont take this as me trying to be a smart @##@@## but I think that is the job of the regulater,allows current,or charge when your batterys falls below a certain voltage to flow and charge them back to a certain level then it turns of again,just like a light switch but controled by battery charge level.there is allway a fancy gadget you can buy in most situations,but a amp and volt metre inline will tell you how much drain your apliance are using,keep it simple less to bugger up out bush.Hope this helps
JD4WDActivist
AnswerID: 140227
Follow Up By: The Bigfella - Monday, Nov 21, 2005 at 13:05
No, your not a smart @#&$# that I am aware of. Thanks for the reply. All will be taken on board.
The Bigfella
FollowupID: 393919
Reply By: Wombat - Monday, Nov 21, 2005 at 12:16
I think what you are after is called an ampmeter. It tells you what state your battery is in. Have you decided what sort of battery you are going to use? When you take delivery from Coromal just double check that the microwave is fixed into place correctly. It seems a lot of owners (us included) have had problems with the microwave coming adrift or, in our case the screws being too long and piercing the bottom of the unit. Bet you can't wait!
AnswerID: 140229
Follow Up By: Member - Beatit (QLD) - Monday, Nov 21, 2005 at 12:30
Another Marilyn! What's the go with you guys? This is obsessive.
Kind regards
FollowupID: 393910
Follow Up By: The Bigfella - Monday, Nov 21, 2005 at 13:02
Thanks for the advice. The Coromal comes out of the factory next Monday and I have been told it goes in to quality control for two days and then I have to allow a week for it to come over to Windsor (NSW) where I am picking it up. I live in Bathurst. Heading off for two weeks on Boxing Day to try it out. I will do the microwave check by all means.
The Bigfella
FollowupID: 393917
