Getting Cable through the Firewall
Submitted: Monday, Nov 21, 2005 at 19:22
ThreadID: 28262 Views:3014 Replies:9 FollowUps:5
I have a Series 4 GU Patrol and I am fiiting driving Lights, A UHF Radio and I am running a 8mm cable to the back for an Anderson Plug.
I was wondering if any one knew where is the best place to go through the firewall on the Patrol without damaging something on the other side?
Thank you in anticipation,
Cruiserboxer
Reply By: Exploder - Monday, Nov 21, 2005 at 19:31
Just have a look around in the engine bay> around the firewall for some rubber grommets that are blocking unused cable holes, There should be at lest one if you have an Auto transmission.
AnswerID: 140299
Follow Up By: Member - David 0- Monday, Nov 21, 2005 at 19:34
Do't go through any of the upper grommets, tey will ut you into the A/C fan.
Go through the big grommet around the A/C pipes on passenger side.
FollowupID: 393973
Follow Up By: Member - David 0- Monday, Nov 21, 2005 at 19:35
ehhem...fingers work!!!!!!!!!!
Don't go through any of the upper grommets on PAX side. They will put you into the A/C fan.
FollowupID: 393974
Reply By: bombsquad - Monday, Nov 21, 2005 at 19:34
I ran mine through a rubber gromet under the brake booster to above/behind the brake pedal. Did a bodgeywith silicone to dust/waterproof it & so far so good
AnswerID: 140300
Reply By: MAVERICK(WA) - Monday, Nov 21, 2005 at 21:18
you can also go via the left guard and through the left passenger kick panel. rgds
Slow down and relax......
AnswerID: 140318
Reply By: Star Bug - Monday, Nov 21, 2005 at 21:48
I ran the cable through a grommet on the pasenger side of the firewall.
AnswerID: 140326
Reply By: Voxson (Adelaide) - Monday, Nov 21, 2005 at 23:24
I put mine through the big grommet under the brake booster also..
AnswerID: 140354
Reply By: Richard Kovac - Monday, Nov 21, 2005 at 23:36
Cruiserboxer
Use an old CB areal?
fiberglass
tape wires to it and then push it through a grommet remove wires, and ten retract areal??? (spelling)
Richard
AnswerID: 140357
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Nov 22, 2005 at 09:18
The strip of yellow plastic (the tongue) off the flooring sheets is pretty good for that sort of thing too Richard. Nearly everyone would have access to it too.
The large rubber grommet on the passenger side is easily reached from the inside behind the carpet or rubber flooring.
FollowupID: 394024
Follow Up By: Bonz (Vic) - Wednesday, Nov 23, 2005 at 10:40
Theyre green now Mr J, did u get my email?
FollowupID: 394181
Cruiserboxer
fiberglass
tape wires to it and then push it through a grommet remove wires, and then retract areal??? (spelling)
Richard
AnswerID: 140358
Follow Up By: Richard Kovac - Wednesday, Nov 23, 2005 at 00:49
F knows what happen here
FollowupID: 394133
Reply By: chips - Tuesday, Nov 22, 2005 at 03:04
I to used large gromit just below power brake unit,comes out behind brake pedal,I have used this for lightsand lead for fridge and soon for C.B make hole very neat no need to seal so far,can take a bit of "gentle pulling" to get it through.
AnswerID: 140375
Reply By: Cruiserboxer - Tuesday, Nov 22, 2005 at 08:25
Thanks everyone. I really appreciate your help.
Thanks heaps
Cruiserboxer
AnswerID: 140381
