Best photo edidting software...
Submitted: Thursday, Nov 24, 2005 at 12:37
ThreadID: 28334 Views:3020 Replies:9 FollowUps:10
http://www.fookes.com/ezthumbs/index.php
This is what I use to thumbnail my pics.... but as a photo editing thing, it's no good. It's awesome for thumbnails though.
What "basic" photo editing software do ppl use that is free to downlaod.
Reply By: Footloose - Thursday, Nov 24, 2005 at 13:23
XnView. Free at www.xnview.com or http://perso.wanadoo.fr/pierre.g
AnswerID: 140797
Reply By: bruce.h (WA) - Thursday, Nov 24, 2005 at 13:32
photoshop is the best you can get
AnswerID: 140799
Reply By: Rob80 - Thursday, Nov 24, 2005 at 13:36
Hi Wheeltravel
Try this link to download HP Image Zone Express - free and and excellent program for digital photo editing
Rob
http://www.hp.ca/portal/hho/ize/
AnswerID: 140800
Reply By: Member - MrBitchi (QLD) - Thursday, Nov 24, 2005 at 13:39
Picasa from google.
AnswerID: 140801
Follow Up By: Notso - Thursday, Nov 24, 2005 at 14:11
Yep, it's the easiest and does a great job.. Great for emailing and editing.
Explore it's functions and you'll be pleasantly surprised.
FollowupID: 394440
Follow Up By: Member - Chrispy (NSW) - Thursday, Nov 24, 2005 at 14:17
It's a good image library too - very much like iPhoto on the Mac.
FollowupID: 394441
Follow Up By: cokeaddict - Thursday, Nov 24, 2005 at 18:25
cant go past it !
Very well set up program.
FollowupID: 394471
Follow Up By: Motherhen - Thursday, Nov 24, 2005 at 23:17
I found Picasa the best for straightening photos; an excellent method compared to other programmes i have tried. I tend to get sloping horizons, so love the easy method, but although they are straight when i look at them in Picasa, they are still crooked in any other programme. What am i doing wrong? I like the way it finds all the photos too, whereever they have become lost, but it sorts them in so-called years, and gets that all very wrong.
Easythumb great for thumbnails, as you can adjust the size.
I use microsoft paint for cutting bad bits out (eg finger over corner of picture) and pasting something similar to patch. I used something else to do this once (my old film camera must have a loose bit of plastic floating around, as i sometimes get a "squiggle" in the corner) - it may have been Microsoft PictureIT, but paint does as well.
A lot more suggestions to try in this thread. Thanks guys.
FollowupID: 394523
Follow Up By: Member - MrBitchi (QLD) - Friday, Nov 25, 2005 at 08:56
Motherhen,
Simple. Picasa doesn't actually do anything to the image itself. Any corrections you make are stored in another file which Picasa interprets in conjunction with the image file.
If you want to make the change permanent you need to "export" the image to another location.
As for sorting files in chronological order, I find it very good. As long as you digital images have the original camera metadata then it works fine. Doesn't work well with scanned imaged though because there creation is when you scanned them, not when they were taken.
FollowupID: 394566
Follow Up By: Motherhen - Friday, Nov 25, 2005 at 13:52
Thanks for the advice MrBitchi - i will try it. Strangley enough, last night i noticed just some of the photos had a "straight" version as well, and it had added 1 after the photo name/number - so it has done it by itself somehow occasionally. When i first downloaded Picasa, i spend darn near all night straightening my photos - so simple compared with what i had used before where you needed to crop afterwards. Then my laptop died and lost all those hours straightening. I just love digital photos - i can fix up all my mistakes, like the horizon on the sea at an aweful angle, or remove spots left from marks on the lens. Motherhen
FollowupID: 394625
Follow Up By: Motherhen - Monday, Dec 05, 2005 at 00:07
Picasa - I have worked out why some were saved nice and straight with a 1 after the photo number - if i straighten, then "save a copy" that does it.
FollowupID: 395942
Reply By: stevesub - Thursday, Nov 24, 2005 at 17:51
A few good ones out there depending what you want to do.
Irfanview from www.irfanview.com is getting dated but used it for years, now superseded
Picasa from Google - good but the photo sorting is crap, Excellent for minor adjustments to photos
Faststone is my current favourite and using it all the time www.faststone.org
Found Photoplus today from Serif - excellent editing. http://www.freeserifsoftware.com/software/PhotoPlus/default.asp
Stevesub
AnswerID: 140832
Reply By: angler - Thursday, Nov 24, 2005 at 17:55
I have a couple loaded on my system and use different ones for different jobs. Photoshop is pretty good but is difficult to use for some jobs whereas photoimpact is better for such things as animated GIF's, dead easy with PI but slow with PS.
Microsoft also has a programme called digital image and it also has some great photo systems.
AnswerID: 140834
Reply By: WheelTravel - Thursday, Nov 24, 2005 at 19:10
Thanks averyone...
This website is a wealth on valuable info... There are not many other Forums...if any that I have come across with such a diverse range of info and set up so well!
Ciao!
AnswerID: 140844
Reply By: Pterosaur - Thursday, Nov 24, 2005 at 21:41
G'day,
for more advanced stuff (RAW image editing) try Raw Shooter Essentials 2005 (RSE), which is a free download from
www.pixmantec.com
I generally find it helpful to have a variety of progs available, as none excel at all tasks.
hope this is useful
Terry
AnswerID: 140860
Reply By: Truckster (Vic) - Thursday, Nov 24, 2005 at 23:08
Depends on what you wanna do
photoshop CS is free on Kazaa :D
AnswerID: 140877
Follow Up By: Member - MrBitchi (QLD) - Friday, Nov 25, 2005 at 08:58
You can't beat Photoshop at that price :-) but for simple image editing the learning curve is a bit steep.
FollowupID: 394567
Follow Up By: Member - Chrispy (NSW) - Friday, Nov 25, 2005 at 13:59
From someone who designs software for a living and depends on its saleability - you two can go jump. Kazaa's thievery!
Then again.... Adobe have always been too expensive in my view.
FollowupID: 394628
Follow Up By: Member - MrBitchi (QLD) - Monday, Nov 28, 2005 at 08:53
Chill Chrispy. I'm on your side here.
I'm in the pre-press game and know all about highway robbery when it comes to software prices though. Ever priced a Quark upgrade???
FollowupID: 394935
