fitting driving lights to new 2005 hilux
Submitted: Thursday, Nov 24, 2005 at 21:59
scottp
Has any one got any detailsor ideas on the best place on the new hilux to connect the relay to the highbeam lever in the car?
Reply By: Brett_B - Thursday, Nov 24, 2005 at 22:13
Fitted
Driving lights to my new Hilux last weekend, spliced into the headlight wiring just behind the headlight, connected the relay wiring there. Mounted the relay on my duel battery tray.
I didnt need to go near the high beam switch itself !!
140867
Follow Up By: scottp - Thursday, Nov 24, 2005 at 22:24
did you mount an isolating switch in the cab?
Where did you get your dual battery tray and what was the biggest aux batt you could fit?
394512
Follow Up By: Brett_B - Monday, Nov 28, 2005 at 21:49
Hi Scott.
Sorry missed your post - reply.
Did you get your system sorted out, I had problems with my IPF D/Lights - Negative earth had me stumped for a while :-)
Battery tray I use is ARB, it takes a big battery (size i cant quote) I fitted a small 46T deep cycle battery from my previous Hilux System, I'll wait till that battery dies or I get sick of it before I lash out for a larger one.
Hope all is going
well with your Lux, so far I'm REAL happy with
mine.
That TD has got some balls :-)))
395055
Reply By: Member - David B (QLD) - Friday, Nov 25, 2005 at 18:46
Hi scottp,
the biggest deep cycle battery i could fit under bonnet was a 105ah.
It sits in a TJM stainless steel tray.
Dave.
141012
Follow Up By: scottp - Friday, Nov 25, 2005 at 19:20
thanks dave
394685
