4WD System in New Hilux
Submitted: Friday, Nov 25, 2005 at 14:22
ThreadID: 28363 Views:10906 Replies:3 FollowUps:1
I was wondering if anyone could explain how the 4WD system in the Hilux works. When I engage high range 4WD in the car it feels like it has a diff lock engaged, not sure..? It feels very loaded compared to other full time 4WD's such as the 100 series cruiser. Was also wondering what conditions , slippery roads etc, would you engage 4WD over 2WD. I ask this because in normal 2WD when it's raining the car tends to wheelspin going around corners sometimes, so was really trying to undestand when 4WD should be engaged and is safe to drive the car in normal conditions in 4WD mode continually..?
Reply By: Fronty - Friday, Nov 25, 2005 at 14:37
Your could be be diff-locked once 4H is selected. Cars such as Landcruisers which are full-time 4WD would have a viscous coupling of some sort, which allows them to be used on bitumen surfaces. Only when 4H is selected on these vehicles would the centre diff-lock be activated. 4H should only be used on loose surfaces eg. sand, gravel etc.
AnswerID: 140976
Reply By: Wizard1 - Friday, Nov 25, 2005 at 15:17
We did a course with a reputable 4WD driving school a few years ago for my wife to learn off road driving. It was surprising how much new stuff I learned as well, such as when to engage 4WD, etc....and I had been driving 4WDs for over 20 years.
AnswerID: 140986
Follow Up By: gramps - Friday, Nov 25, 2005 at 16:17
Well come on Wiz. Are you going to answer Terrafirma's question or keep us in suspense :))))
FollowupID: 394655
Reply By: Member - Jeff M (WA) - Friday, Nov 25, 2005 at 17:03
The Hilux is not a "Full-Time" 4wd and should not be driven as such. If you engage 4wd on hard surfaces (such as normal roads) and continue to drive it, you will get what is called "Wind up" this will eventually either make in impossible for you to stear or snap a CV Joint, Axel, Uni joint, gearbox, transfer case or diff.
With a Hilux you only engage 4wd on loose gravel, mud, snow or sand. Full time 4wd's have a centre diff lock, which means the front and rear drive wheels can work indepentally from each other and when the going get's tuff you lock them together. Yours are always locked together, so going around corners when one of the front wheels is turning more or less than the back wheels and there is no slip or give somthing else will have to give.
Hope this explains it.
AnswerID: 140996
