Water storage
Submitted: Saturday, Nov 26, 2005 at 02:10
ThreadID: 28381 Views:6361 Replies:8 FollowUps:6
Hey guy's n gal's. What's the goss on water storage. When I go camping without the Camper, we take a 20l plastic container with tap water, and a small 5L container plus two or three small drinking bottles filled from the filter in the kitchen.
All this moving containers in and out of the car plus occaisionally getting the bedding wet when going off road is getting to me. I don't have the moolah for a permanent water tank under the GU and was shocked when I saw a 32L water bladder at the 4X4 show selling for nearly 300 buckeroonies.....what the?
Reply By: Tony - Saturday, Nov 26, 2005 at 07:40
Mate i reckon you are still on the right track, maybe get better sealing lids for your drums, and come down to 2 x 10ltr containers. Its a bit easier to share the weight that way.
AnswerID: 141072
Reply By: Member - Reiner G (QLD) - Saturday, Nov 26, 2005 at 08:36
I bought a black plastic water tank made for Caravans and build a ply wood box around it. fitted it under the tray with a tap on one side and a filler on the other. The tank holds 60l I think and cost less than $100 including tap and filler.
Reiner
AnswerID: 141076
Reply By: lindsay - Saturday, Nov 26, 2005 at 08:42
I think that you are doing the right thing. We carry 3 X 20 litres and a couple of 5 litres, all drinking water. We have them numbered and when one is empty we fill it with any water (washing ect) and so on when we get to drinkable water we then wash them out and refill with drinking water. The small containers we call day water and are replentished each day for drinking or washing hands. With one container you will have to shandy good water with not so good water if you want to keep your supply up,you also run the risk of losing all your water if the container is damaged,as I have seen , then no water, then you may be in trouble. Plastic containers are not hard to pack.
AnswerID: 141077
Follow Up By: Member - Willie , Epping .Syd. - Saturday, Nov 26, 2005 at 15:04
Lindsay ,
My sentiments exactly . Might I also add that if you have to walk up a gorge to fill up , its a tad difficult with a bladder .
Cheers ,
Willie .
FollowupID: 394777
Reply By: Member - Banjo The First (SA) - Saturday, Nov 26, 2005 at 09:51
Stay with it - a number of plastic containers is the go - safe too - even Murphy can't get them all to leak and empty out at once........especially important in remote areas......... we use a mixture of water carriers....... main thing is to have backup., in case one springs the dreaded leak. We choose from 20 and 10L plastic jerries with the flip taps (inside the cab), a stainless custom made tank that slots into the Jackaroo's rear, and the 120L tank on the camper.
AnswerID: 141083
Reply By: Michael ( Moss Vale NSW) - Saturday, Nov 26, 2005 at 09:54
Those 20 and 25 litre square containers ar the best, the blue water containers similar to jerry cans are only good for trailer or gerrycan holders, obviously they wont stand up unsupported, whereas the square ones will. Michael
AnswerID: 141085
Reply By: ev700 - Saturday, Nov 26, 2005 at 12:41
Agree that plastic containers are the way to go.
However I think some 10L make life easier.
AnswerID: 141106
Reply By: Jimbo - Saturday, Nov 26, 2005 at 12:59
"Plastimo" bladder tanks designed for boats; 50L $85, 100L $100 available from Whitworths.
In WA: Mosman Park 9385 5877, Leederville 9381 1442.
Jim.
AnswerID: 141107
Follow Up By: muzzgit (WA) - Saturday, Nov 26, 2005 at 16:10
Thank's Jim, that's exactly what I was hoping this thread would do.
Cheers mate,
Muzz
FollowupID: 394786
Follow Up By: Jimbo - Sunday, Nov 27, 2005 at 21:19
Muzz,
That's the way it is on forums.
Some people answer your question.
Others tell you what THEY think is right for you.
I've been guilty of it myself at times.
Jim.
FollowupID: 394894
Reply By: Willem - Saturday, Nov 26, 2005 at 18:13
I have made a tray behind the rear seat that holds 6x 10lt plastic water containers bought at Supacheap for $7 each last time I was in the Big Smoke. Having carried 20lt plastic water jerries for years, the 10lt container is by far the easier option. I also carry 2x20lt plastic water containers on the bush trailer(not CT) and empty them with as plastic syphon hose. Going to get an old caravan mechanical water pump and fit it to the 20 lt containers.
AnswerID: 141138
Follow Up By: Member - Phil G (SA) - Saturday, Nov 26, 2005 at 20:47
Willem,
Only warning about the caravan pumps is they leak because the water can pass thru them. Don't notice it until you go offroad. I've found a syphon system with half inch hose going thru the lid works best for me. Can either use a half inch tap or trigger gun at the end. And you need to put a fine breather in the lid.
phil
FollowupID: 394802
Follow Up By: Willem - Sunday, Nov 27, 2005 at 18:06
No, I intend to make one as a separate unit and then attach it when needed. The syphon is still the best however.
Hope to meet you at the TBP next Sunday.
FollowupID: 394873
Follow Up By: Member - Phil G (SA) - Sunday, Nov 27, 2005 at 21:46
Hi Willem,
I've got a couple of caravan pumps that you're welcome to have for nothing. I'll bring them Sunday.
Yeah, I haven't met any of the exploroz crew before, so it will be nice to put faces to names.
FollowupID: 394899
