deul batteries 80 ser cruiser
Submitted: Saturday, Nov 26, 2005 at 16:11
ThreadID: 28396 Views:2210 Replies:3 FollowUps:1
hi everyone i have 2 4wd but am looking for help on my 96 landcruiser gor duel batteries where do they go and where do i get a tray for it christmas is almost here i need some pics please u can email me on knssimpson@optushome.com.au
need it to run my waeco 120l fridge i got duels in my 4runner but not this please help
Reply By: steve21 - Saturday, Nov 26, 2005 at 16:19
hi Mate
goes Drivers side, you have to relocate the windscreen washer bottle. will email you some pics tomorrow.
cheers Steve
AnswerID: 141123
Reply By: Member - Peter R (QLD) - Saturday, Nov 26, 2005 at 18:05
Krislan,
I have an AGM battery in the back of 94 Landcruiser and the 110l Waeco is wired direct from this battery to unit.
My understanding is that for Waeco 110 to work properly the lead from battery to unit should only be no longer than the lead they supply (ie. dont use the lead which is longer and is used in smaller Waeco's). I bought a second lead for a 110l and had this fitted as a permanent fixture to battery.
Battery sits in a battery box which is firmly attached using bolt holes above the left hand rear wheel arch, ( where the third row seat would normally be attached) . A friend made up a frame and it takes up no important room as it is off the floor.
Frame is a flat steel base, with legs attached to bolt holes.
When 240 v is available I simply use the Mobotronic with the normal lead.
Pedro
AnswerID: 141136
Follow Up By: Mainey (WA) - Sunday, Nov 27, 2005 at 00:24
Larger cable thickness, relevant to cable length, reduces voltage drop.
The further the battery is from the alternator the thicker the Aux battery cable has to be, and likewise the further the fridge is from the Aux battery the thicker the cable has to be also.
FollowupID: 394818
Reply By: Member - Jiarna (NT) - Saturday, Nov 26, 2005 at 21:40
I got mine on eBay, included all wiring and battery isolator, as well as the tray.
AnswerID: 141156
