100 Series V8 LPG conversion
Submitted: Saturday, Nov 26, 2005 at 16:38
ThreadID: 28397 Views:6942 Replies:3 FollowUps:5
I have a 100 series V8 and am considering conversion to LPG. I have seen a couple of questions in Forum re this but no one seems to have done it yet. So, like the other guys I am also seeking comments on V8 conversion to LPG. Or reasons why it is not advisable. My discussions with local Toyota dealer were not encouraging but they cannot give any technical reasons why it should not be done. I am not concerned with where to put the spare wheel or the economy - just want to know if my engine will fail if run on gas. Have heard rumours of burnt out valves and valve lag - whatever that is - but also have heard many good stories but only for the 6 cylinder motor. Others have said I must install an "oiler" - help again - what are they talking about?
For the record I do a lot of touring with a 21 ft van for what that's worth and can easily return 20l/100 overall for a 4 week 6,000km trip - of course that's a combination of towing and sightseeing type driving.
Any and all info helpful
Reply By: Member - Peter R (QLD) - Saturday, Nov 26, 2005 at 17:33
Bob,
Can't help you with the V8 but i would think it would be possible.
To be sure I would suggest a phone call to Scott at Metropolitan Autogas in Brisbane (07 3256 0333) and he would be able to give you the right info.
I have an 80 series 6 cylinder, dual fuel, with an Impco fitted and had over 100000kms of trouble free motoring until some clown hosed down engine. After that I had an engine backfire which blew out air flow meter, while i was running on gas.
Also had a further backfire on trip to Broome and the problem was traced to an arking in ignition leads.
Apparently the ignition leads for LPG running need to be a certain type and not the standard issue, which mine were at the time (though i got over 100000kms on them)
Scott at Metropolitan autogas, when he fixed things up for me, told me to make sure I had the right ignition leads, which are to be changed every 80000 kms and spark plugs to be changed every 20000kms.
When the backfire happened we were on trip to Broome from Gold Coast and I had to change over to petrol at Kununnara and towing a 17ft Jayco poptop got an average of 22l/100kms (9858kms) which is close to your 20/100.
Whilst running on gas prior to the problem got 30.5l/100kms (3212 kms) and the average cost per kilometer was
LPG 23cents
PETROL 30 cents
Re the "oiler" perhaps this is an "upper cylinder lube system" .
If you speak to Scott ask him about that too.
Pedro
AnswerID: 141127
Follow Up By: Charlie 12 - Wednesday, Dec 07, 2005 at 14:11
Peter R
Thanks for the info. Will be contacting Metropolitan Auto Gas this week - been too busy till now. Have found out the the "oiler" is probably a "Flashlube" installed to maintain lubricant to the upper cylinder. Am now showing interest in the Parnell sytem - see reply from Anthony.
FollowupID: 396308
Reply By: Member - Stan (VIC) - Saturday, Nov 26, 2005 at 18:54
My sister's 2004 100 series was converted to gas about 3 months ago.
There are quite a few system for them older style and Injection systems.
My sister got older style impco system and it uses about 22l per 100 on gas
(was about 18l per 100 on petrol).
Few companies in victoria that supply them are www.vags.net.au
and www.parnell.com.au
AnswerID: 141140
Follow Up By: Charlie 12 - Wednesday, Dec 07, 2005 at 14:08
Stan
Thanks for the info. All info is helpful at this stage.
FollowupID: 396306
Reply By: Lc100 V8 - Saturday, Nov 26, 2005 at 20:18
Hi Bob
I Have a V8 100 series which is due to be converted to the Parnell Squential Vapour injection system next week. When I Spoke to the Toyota dealer he said there's no reason why there should be any problems,along a Flashlube Kit for the upper cyclinder head lubrication is fitted. Although the gas converted said there was no need for the Flashlube kit as the engine starts on petrol and also delivers petrol in small amount under load - I think for a small outlay I'll get the kit fitted, to be on the safe side. The spare is going on a bracket in the back on the drivers side - so I'll lose the use of the rear seat for that side which I can live with. I being told gas usage is 15% extra because the gas is injected which is more efficient, also a 3 Kw increase in power - I will do my own fuel consumption test as soon as I can.
Anthony
AnswerID: 141147
Follow Up By: Charlie 12 - Wednesday, Dec 07, 2005 at 14:06
Anthony
How did the conversion to the Parnell system go? I have e-mailed Parnell and they gave a very good and very prompt response unlike Impco who have not bothered to respond to my questions.
I was particulalry impressed with the technology of the Parnell system however as I'm not an engineer I have to believe what I read on this occasion.
FollowupID: 396305
Follow Up By: Lc100 V8 - Wednesday, Dec 07, 2005 at 20:40
Had a call from the conversion place 2 weeks ago, they were unable to get the Injection kit from Parnell's. The kit has since come in, and the cruisers has been re-booked for next Tuesday.
I'll let you know how it goes.
Anthony
FollowupID: 396388
Follow Up By: Lc100 V8 - Monday, Dec 19, 2005 at 18:53
All done - got the cruiser back Friday, no problems. No lost of power that I can notice. Need to take the cruiser back after 1500km for adjustments and tune, after that I'll do a couple of fuel consumption tests.
Happy so far
Anthony
FollowupID: 398124
