A/C Expert needed
Submitted: Saturday, Nov 26, 2005 at 22:27
Rock Crawler
Hi Guy's and gal's . I have just done the last engine fit trial and I have aissue with the A/C. Now before I make the last chassis mod. I was wondering if anyone here knew if a A/C cmpressor , can be rotated on the rear housing. My hose fittings now sit on the side of the compressor and after having a close look , I notices that the actual compressor is made up of 3 housings , now if I could unbolt the fromt 6 bolts and rotate the rear housing , so the hoses are in another possition, it would save some nasty chassis mods which would mean cutting and welding near the engine mount.
Reply By: Member - Bradley- Sunday, Nov 27, 2005 at 02:04
dunno mate, depends on whether the pump has a swash plate or vane offset keyed to the rear housing, best way is to pop it apart (or see an a/c expert) .
if it hasnt and the rear plate is just a bearing carrier, and the mount bolts are equally spaced then yeah spin it round, but as the inlet and exit ports are mounted on it i dont like your chances.
What about some half moon shaped brackets to mount the whole pump rotated around ?
141171
Follow Up By: Rock Crawler - Sunday, Nov 27, 2005 at 09:13
Another option I guess
394825
Follow Up By: Nudenut - Sunday, Nov 27, 2005 at 17:00
another option.....a different make model of compressor?
394860
Reply By: Nudenut - Sunday, Nov 27, 2005 at 11:21
duuno , but your going to need a qualified person to reclaim the gas or charge it up...why not ask them?
141188
Follow Up By: Rock Crawler - Sunday, Nov 27, 2005 at 12:00
Because you get your A/C gased by todays mechanic's , who are really removers and fitters lol and would have a clue how things actually work. I asked the question here first , incase there was some one who understood the inner workings of a A/C compressor. Why run around when you can let your fingers do the walking lol .
394840
Follow Up By: Nudenut - Sunday, Nov 27, 2005 at 13:32
true we are becoming a race of removalists and fitters....makes one wonder what the real removalists are doing these days.....
everything is throw away......some say we mere males are too hahaha
394850
Follow Up By: Bonz (Vic) - Sunday, Nov 27, 2005 at 16:55
Check the ellipsoid parameter Eric and adjust the backing plate to suit, you should be fine
394858
Follow Up By: Nudenut - Sunday, Nov 27, 2005 at 16:57
why didnt I think of that...its so simple hahaha
394859
Follow Up By: Rock Crawler - Sunday, Nov 27, 2005 at 17:55
no worries Bonz , now when your ready , in English would be great lol
394871
Reply By: cmilton54 - Sunday, Nov 27, 2005 at 21:02
Rock Crawler
G/Day
If it is a early style sanden, other than the 2 locating dowells in the head assembly the head could be rotated and should not be to much of a problem. Later models would need to have head removed to check, or look under the manufactuers web site to check head diagrams. Job would have to be done by licenced ac person.
Sanden swash plate have inner and outer chamber`s so it should turn
Charlie
141237
Follow Up By: Rock Crawler - Sunday, Nov 27, 2005 at 21:09
Thanks , it sounds like I need yo get the unit to someone that works on them to have a look.
Anyone know someone lol ???
394893
Follow Up By: awill4x4 - Sunday, Nov 27, 2005 at 22:26
Eric, we have dealings with an onsite air con specialist at work. He's often coming in and getting aluminium fittings welded up to suit some odd air con job he has on the go.
He tends to get the odd work the workshops can't handle so he may be a useful guy to contact.
His name is Glen and his business name is GP Auto Air and he is in Berberis Cres Frankston. His mobile number is 0418 364138. I don't know how far he travels but it may be worth a try.
Tell him Andrew from D&F Racing Products in Carrum Downs said to give him a call and I expect he'll insult me the next time he needs something welded. lol.
Regards Andrew.
394909
