km per ltr V6 4 runner petrol
Submitted: Tuesday, Jan 07, 2003 at 18:38
ThreadID: 2841 Views:1817 Replies:1 FollowUps:1
HI all , I have a 1993 4 runner v6 3lt petrol, on my last trip I averaged 8km per LTR mainly hardtop driving and 7.2km per LTR off road I am interested to know what other owners of the same are getting thanks for any info Peter.
Reply By: Chris - Tuesday, Jan 07, 2003 at 20:17
Peter, I assume your 4runner to be a manuel with those consumption figures.
I had a 1993 RV6 (3ltr V6, auto) and my feul consumption was terrible. I suspect that the slightly oversized tires reduced the torque and the engine had to work harder as the gearing was effected.
AFTER adjustments for speedo error of 4.5% due to the larger rubber, my consumption was 21 lt/100 km for medium (no sand) offroad conditions. worse for sand and heavy off road, with the consumption best at 100 km/h on the highway at 16.5l/100km (6 km/lt)
I tried everything: had it dynatuned, replaced the computerised air flow/feul injection meter, airfilters, fuel additives, you name it, but without any luck.
Other than the fuel consuption which was a problem with the range, I found it to be a very capable vehilcle indeed. I did not have LSD, lockers or any other traction control, but did have a OL coil, shock and torsion bar job done, which improved the ride both onroad and off.
Hope this helps
AnswerID: 10771
Follow Up By: Member - Peter- Wednesday, Jan 08, 2003 at 12:03
THANKS CHRIS , yes I have a manual,I have fitted Roncho5000 Front and rear , I have also added heavier rear springs and air bags to rear this has really helped with the ride and towing the caravan . Also have added a second fuel tank above spear wheel (65 lt ) this is giving me a range of approx 900 km on the hardtop . Peter
FollowupID: 5791
