OziExplorer help needed
Submitted: Monday, Nov 28, 2005 at 15:36
Phil 20
Hi all,
I recently posted a request on how to delete a portion of a saved
track/.plt, I got lots of help thanks.
I now find that on some occasions whilst deleting, a straight line
appears from the point of deletion to an apparently random spot along
the track and no matter what I do I can't delete it.
Does anyone know how to clear this line permanently?
Thanks in advance.
Reply By: Keith_A (Qld) - Monday, Nov 28, 2005 at 23:04
Have you visted the Oziexplorer
forum?
For GPS and Ozi related questions, thay have a
forum; a database which includes FAQs etc.
Well worth a look.
http://groups.yahoo.com/group/OziUsers-L/
141419
Follow Up By: Member - Phil B (WA) - Tuesday, Nov 29, 2005 at 16:23
Thanks Keith_A
I will follow up on the
forum.
395174
Reply By: Pluto - Tuesday, Nov 29, 2005 at 07:41
I've seen the same thing and not been able to rectify it. There is nothing in the track file that makes it do this, but the track is fine next time you open it.
It appears to be a bug in some versions of Ozi. I haven't seen the effect for quite a while. So, I believe the bug has been found and corrected. Have you upgraded to the latest version lately?
If not, download the upgrade from OziExplorer and the problem should go away.
141448
Follow Up By: Member - Phil B (WA) - Tuesday, Nov 29, 2005 at 16:22
Thanks Pluto
Like you I have found it it disappears but not on every occassion. I have now determined that when deleting the unwanted potrtion of a plt the line seems to go to the start or finish of one of the 'Appedages' if you know what I mean.
I will follow up on the upgrade.
395173
Reply By: Member- Rox (WA) - Tuesday, Nov 29, 2005 at 23:43
Yes It has been hapening to me since I found out haw to edit. I get rid of the line by presing track replay. Works 4 me.
141619
Follow Up By: Phil 20 - Wednesday, Nov 30, 2005 at 18:24
Hi Rox
I will give that a try
thanks for your help
395416
