fitted boost gauge to nissan 3.0ltd
Submitted: Tuesday, Nov 29, 2005 at 16:47
Member - toohey
g'day all
i fitted the boost gauge to my navara 3.0ltd today getting max. boost reading of 15 psi. has any one fitted one to same or 3.oltd patrol if so what readings are you getting.
cheers toohey.
Reply By: Motherhen - Tuesday, Nov 29, 2005 at 16:54
You fitted it yourself? Glad your Navara reads OK. We've yet to fit one to our Patrol, and solve any problems that may have caused the turbo hose to blow off when we last towed the caravan. Motherhen
141543
Follow Up By: Member - toohey - Tuesday, Nov 29, 2005 at 17:42
g'day motherhen
yes i did ,less complicated than the patrol,no intercoolerjust a teepiece fitted in line under the boost sensor,i have done plenty of towing of my caravan,never had a turbo hose blow off ,i did fit better clamps than the original nissan ones when vehicle was fairly new (did'nt like the look of em')
cheers toohey
395191
Follow Up By: DEANO WA - Tuesday, Nov 29, 2005 at 21:10
Motherhen, did ACDC ever reply to the correct installation position of the boost gauge ?????
395216
Follow Up By: ACDC - Tuesday, Nov 29, 2005 at 22:26
Anywhere after the turbo is OK but the best place is the inlet manifold, drill and tap it.
I was on holiday's when you fella's were looking for me sorry!
395229
Follow Up By: Motherhen - Wednesday, Nov 30, 2005 at 09:43
Good to hear from you ACDC - sure hope you had a nice holiday. This topic has been followed by a number of us. Thanks for your reply. Motherhen
395290
Follow Up By: Trev88 - Wednesday, Nov 30, 2005 at 12:03
Hi Motherhen
A mate has his patrol in the nissian
shop to get his turbo adjusted his hose keeps blowing off as
well (while under load 500kg boat & trailer up cement
hill) he has put on hevey duty clamps and hoses but still blows off.
Have you fixed yours and what was the problem.
Trevor
395365
Follow Up By: Leroy - Wednesday, Nov 30, 2005 at 12:12
Trev,
Sounds like an over boosting issue. Would be interesting to hook a boost guage up to see what is happening.
Leroy
395368
Reply By: DamoHJ61 - Tuesday, Nov 29, 2005 at 22:03
Was it a hard fit up? I was thinking of fitting one to my 'cruiser - any tips???
What guage did you use?
Thanks.
141599
Follow Up By: Member - toohey - Wednesday, Nov 30, 2005 at 06:15
sorry damo can't help you with the cruiser side of things.
cheers toohey
395251
Follow Up By: prado_95 - Sunday, Dec 04, 2005 at 16:52
Damo,
you could T into the boost sesne line on the pressure side of the turbo (probably between there and the HAC on 80 series TD).
Use a gauage that peaks just over the factory spec boost (7.1 to 9.2 PSI), so a 15PSI gauge is ideal. Thats what I have used - a VDO 15PSI unit.
ENG-TEK
395901
Reply By: Richard Kovac - Wednesday, Nov 30, 2005 at 01:44
toohey
why did you fit it if you don't know how to read it?
It's like wearing a watch and not knowing what time to set it tOOOOO
Richard
ps Ask NISSAN
141638
Follow Up By: Member - toohey - Wednesday, Nov 30, 2005 at 06:13
g'day dick
the gauge is a auto meter brand,calibrationns are 0-35psi the max boost pressure reading i'm getting for my vehicle IS 15PSI.
nissan tech dept said this is spot on,could you please explain how i'm reading it wrong.
cheers toohey.
395250
Follow Up By: Member - toohey - Wednesday, Nov 30, 2005 at 17:23
g'day RICHARD
iwas not being a smart a$se,best mate's name is richard i call him dick as does all his family
cheers toohey.
395407
Reply By: Richard Kovac - Wednesday, Nov 30, 2005 at 14:46
Ha smart ass the NAMES Richard
I don't hide behind pet names like most
"nissan tech dept said this is spot on,could you please explain how I'm reading it wrong."
No one said you were reading it wrong.
The questing was way fit it if you don't know how to read it,
not saying you can't read, but if you don't know what boost pressure it should be then why fit it?
Thats why comment about watch....
RICHARD
141741
Follow Up By: Goons - Wednesday, Nov 30, 2005 at 16:26
Richard
He has fitted it to monitor his boost, which is what most 3.0lt owners should do. This motor has a habit of letting the boost go as high as 25-30psi without warning. This happened to my vehicle last month and a simple change of MAS returned boost down to 15psi.
I beleive toohey was just checking if 15psi is normal - which is what this
forum is for isn't it?
395401
Follow Up By: Richard Kovac - Wednesday, Nov 30, 2005 at 17:19
Fair enough
395406
Follow Up By: Member - toohey - Wednesday, Nov 30, 2005 at 18:12
g'day goons
also fitted a egt. gauge and calibrated
water temp. gauge,i reckon the more i can monitor on this particular donk the better.
cheers toohey
ps to richard my explanation to you ended up in the wrong spot
cheers toohey
395411
Follow Up By: DEANO WA - Wednesday, Nov 30, 2005 at 19:19
some body had their grumpy pills Richo
395430
Follow Up By: Richard Kovac - Wednesday, Nov 30, 2005 at 22:14
Yes
395470
Reply By: DamoHJ61 - Wednesday, Nov 30, 2005 at 21:41
The cockpit on that thing must look like a fighter jet, how do you go monitoring all that info??
Do you drive it much or just enjoy working on it???
141825
Follow Up By: Member - toohey - Thursday, Dec 01, 2005 at 17:18
g'day damo
it's start'n to look a bit that way,yep drive it every day &like add'n things as
well,sometimes i have the co-pilot with me don't know if that's good or bad,nah just joke'n.
cheers toohey
395576
Reply By: Goons - Thursday, Dec 01, 2005 at 01:08
Gday Toohey
EGT gauge is my next step, how do i go about setting this one up. ie which section does the temp probe go into and is there any drilling/welding required?........Is the Nav exhaust the same as patrol?....Bloody nissan make it hard enough to fit the boost gauge to the patrol.
This car is making me paranoid.........but i love tinkering on it so who cares.
141861
Follow Up By: Member - toohey - Thursday, Dec 01, 2005 at 16:32
g'day goons
drilled and tapped the exhaust manifold before the turbo,removed it to do the job had to buy all new associated gaskets cost abit but better than drilling it on the motor,don't know about difference between navara and patrol,the guage is a thermogaurd diital read out they a advertised on this site,hope this helps.
cheers toohey.
395570
Follow Up By: Member - Roachie (SA) - Thursday, Dec 01, 2005 at 20:46
Goons,
I'm paranoid too (and I've got the tried and proven 4.2!!!!).
I've fitted the Thermoguard EGT gauge with probes both above and below the turbo, + a boost gauge, + an extra water temp gauge in top radiator hose, + oil temp gauge (sump), + oil pressure gauge, + low water alarm, + low oil pressure alarm.
Can't have too much information.
Now, if I happen to be in somebody else's vehicle (either driving or passenger) I feel "uncomfortable", cos I have no idea what's happening under the bonnet!!!!
395619
Reply By: Flash - Thursday, Dec 01, 2005 at 17:13
I'm often quite amazed that any reasonably competent driver would NOT want a boost gauge.
On two occasions my GQ boost has gone ballistic because of a blockage on the sense line (there is a tiny hole on the boost adjustment which blocks. Very easily fixed- about three minutes work IF you know there's a problem.)
If I had no gauge I'd be driving around at 20psi plus boost and would have no way of knowing..... I'd fit one petrol or diesel, Nissan Toyota or anything else with a turbo. It's called cheap insurance.
141987
Follow Up By: Member - toohey - Thursday, Dec 01, 2005 at 17:21
i'm with you flash
cheers toohey
395577
