Slippery Coopers
Submitted: Wednesday, Nov 30, 2005 at 11:48
ThreadID: 28508 Views:2698 Replies:12 FollowUps:4
Has anyone found Coopers to be a bit slippery in the wet. I have 255/70R16 on a Hilux and have got 80% tread left on them. Went for a drive in the wet and ended up on the wrong side of the road. Tyre pressure was 34 front/ 32 back. Hilux was empty.
Reply By: Member - Andrew L (VIC) - Wednesday, Nov 30, 2005 at 12:21
G'day Nobby,
I have stt's on a lc100td. I find that they have sufficient grip in the wet, and will let go progressively. Have not exprienced any sudden slides. I run 36 tyre pressure.
AnswerID: 141709
Reply By: Member - Norm C (QLD) - Wednesday, Nov 30, 2005 at 12:26
I've got the ATRs on my Hilux. I thought they were great in the wet. Never had a problem. Had LTs (don't remember what brand) on my previous Courier Dual Cab and they were treacherous in the wet. Like driving on ice.
AnswerID: 141711
Reply By: P.G. (Tas) - Wednesday, Nov 30, 2005 at 12:48
G'day Nobby, Tyres, pressure and handling, especially in the wet are a pet project of mine. I have Cooper ST's (265/75R16 LT) on my GUIII and they stick like excrement to a blanket in the wet.
There are a few factors involved, but the first, cheapest and easiest is tyre pressure. Even at 34F & 32R they may be under inflated and any under inflated tyre wont stick in the wet!
How do you know if they are under inflated? It's a bit of a process to go into, but I'd be happy to reply by email if you wish. My email address is petermg@bigpond.com
Regards,
AnswerID: 141718
Reply By: Redback - Wednesday, Nov 30, 2005 at 13:51
First thing i thought you got a Prado.
Second those pressure are a tad high for a Hilux aspecially in the wet.
I have the Cooper ST/Cs and there fine in the wet, i run the what the vehicle manufacturer pressures which is a good base to start with when playing with pressures from there you can workout whats best suited to your driving style, these pressure are set for comfort and handling, a sort of compromise, i don't know about you, but i don't feel like adjusting my tyre pressures everytime it's wet or dry.
AnswerID: 141728
Follow Up By: Member - Nobby - Wednesday, Nov 30, 2005 at 14:50
G'Day Redback, yes mate I have just hopped into a Prado, but this is the work truck. The Coopers are AT's. Sorry about that. I certainly don't feel like adjusting pressure in line with the barometer readings, but yesterday I judged them to be bloody dangerous in the wet. I don't drive fast but ended up at 45deg. down the road as I went aeound a corner.Great in the dry. Thanks for the response.. Nobby
FollowupID: 395384
Follow Up By: Member - Jeff M (WA) - Wednesday, Nov 30, 2005 at 20:13
I run 42psi in the surf with MTR's and have been stunned by the grip in the wet, very difficult to lock em up unless you stab the brake pedal. Surf would'nt be much heavier than the lux...
FollowupID: 395439
Follow Up By: Member - MrBitchi (QLD) - Thursday, Dec 01, 2005 at 09:25
Maybe you had the misfortune to strike a patch of oil on the corner???
FollowupID: 395522
Reply By: Moose - Wednesday, Nov 30, 2005 at 14:18
Isn't that interesting - one says the pressures are too low, another too high. Typical of responses to tyre questions - rarely consensus.
Nobby - you should have mentioned which model of Coopers you have - an STT will not perform the same as an ST which will not perform the same as ... and so on. BTW I have always found STT's (mine are the older style) to be excellent in the wet.
AnswerID: 141734
Reply By: Member - MrBitchi (QLD) - Wednesday, Nov 30, 2005 at 15:40
Have Cooper AT's on my Pajero and find them excellent in the wet.
AnswerID: 141752
Follow Up By: Exploder - Wednesday, Nov 30, 2005 at 19:46
Same hear, find the AT's excellent in the wet.
I too think that that pressure is a little low, but not sure of pressure with that size tyre.
I run 44psi in mine on road and to make the ABS come on in the wet I basically have to slam on the brakes and keep the pedal pushed down HARD.
FollowupID: 395435
Reply By: Steve - Wednesday, Nov 30, 2005 at 18:48
Nobby, in the new Aus 4wd (Jan '06) they've done a test on the popular All Terrain tyres. Coopers came out top for off road but 2nd overall. What let them down was their performance on the black-top.
These tests do have their critics but it seems a pretty thorough test with some interesting resuts. I supose there are other factors they haven't taken into account particularly in individual cases, but worth a look at.
AnswerID: 141778
Reply By: Member - Nobby - Wednesday, Nov 30, 2005 at 19:35
Thanks for the replys Guys. I suppose it really doesn't matter what we all think, the bottom line is in my case, I will be VERY carefull when driving in the wet.
AnswerID: 141795
Reply By: S&N - Wednesday, Nov 30, 2005 at 19:38
we have the new cooper stt's on our triton, and in the wet they are fantastic! stopped better than the highway tyres that were on it. we will be putting a set of 33" stt's on our gq as well. better than my old bfg at's both on and off road! (quieter as well!)
AnswerID: 141796
Reply By: TerraFirma - Thursday, Dec 01, 2005 at 14:50
I have the ATR's and love them, in the wet around the corner with a little too much throttle they do spin a bit , but I would think that would be the case with most tires, a torquey diesel engine and light arse end.
AnswerID: 141957
Reply By: V8Diesel - Thursday, Dec 01, 2005 at 20:01
Not at all. Well happy with my last set of ATR's.
AnswerID: 142008
Reply By: Beddo - Thursday, Dec 01, 2005 at 21:16
Hilux's have always been terrible on the wet with the standard tyres. The4 new model handles much better than the old - the work truck is a dual cab 05 Hilux SR with standard tyres - with the new engine it breaks the rear end; my new hilux I fitted Cooper St's and they are much better. But with no weight in the back I am careful and sometimes will flick to 4x4 when really wet, because I hate losing the rear end big time in traffic.
Cheers Jeff
AnswerID: 142023
