2nd Bat in GU
Submitted: Wednesday, Nov 30, 2005 at 12:21
JAS095
Hi there I looking for some help for a mate who has a petrol 4.2 GU, he has had it converted to gas and wants to put 2nd batery in has any one got andy ideas and pos some pic
send pics to jason@clarkcomms.com
thanks
Jason
Reply By: Member - Troll 81 (QLD) - Wednesday, Nov 30, 2005 at 14:49
There should be a try in there already for it...or am I missing something?
141742
Reply By: Member - Roachie (SA) - Wednesday, Nov 30, 2005 at 15:19
Is it a GU or GQ? I know you've put "GU", but you've also said "petrol 4.2"....the GU never came out with the 4.2 petrol motor AFAIK. So, either you've got the model wrong (and it's a GQ not a GU)....OR....you've got the donk size wrong (and it's a 4.5 or 4.8 and NOT a 4.2).
Whatever he decides to do, I can only suggest caution be exercised if he intends to use one of the trays that sits on the passenger's side mudguard and uses a couple of captive nuts on the inner guard......they will not hold the tray+ battery in the long run; metal fatigue will cause the captive nuts to break-away.
Roachie
141749
Reply By: V8Diesel - Thursday, Dec 01, 2005 at 19:59
My GU ST4500 (TB45E donk) had a second battery tray mounted running east-west on the passengers side firewall. The battery was a bit smaller than the N70 size, same as my Fairlane FWIW.
Worked a treat. Only problem from memory was the cruise control lightly rubbed on the underside of the bonnet.
142007
