AP 50 Cruise Control
Submitted: Wednesday, Nov 30, 2005 at 18:38
ThreadID: 28528 Views:5777 Replies:5 FollowUps:4
My cruise control has stopped working. I need the setting up and check pages from the installation manual. Can onyone help? Thanks
Reply By: Bros 1 - Wednesday, Nov 30, 2005 at 19:05
LBJ,
I have still got my installation manual, but have not got the electronic means to get it to you.
The address listed is:-
THE COMMAND AUTO GROUP
17 DAPHNE ST,
BOTANY,
SYDNEY,
AUSTRALIA or
P.O. BOX 115,
BOTANY N.S.W. 2019
TEL: (02) 316 5033 (02) 316 6373
The address on the paperwork for dissatified customers is:-
MANAGING DIRECTOR
P.O. BOX 115
Botany N.S.W. 2019
I have had it fitted for quite a few years now and the contacts may have changed.
Bros.
Work is the curse of the down and out bludger.
AnswerID: 141780
Reply By: Philip A - Wednesday, Nov 30, 2005 at 20:22
They are in Silverwater now. I think its in the phone book but hey have a website.
You can still get parts and the guy is very helpful. he diagnosed my GA300 over the phone, new solonoid pack and away it went.
regard s Philip A
AnswerID: 141804
Reply By: joc45 - Wednesday, Nov 30, 2005 at 20:25
Quoting from the book for the diagnostic mode:
Your AP50 cruise control comes with a self test mode. the round red LED on the grey electronic module indicates al function inputs.
To enter diagnostic mode, turn the ignition switch on with the cruise control ON/OFF switch in the OFF position. Now hold the SET button down while turning the cruise control ON/OFF switch to ON.
Your cruise control is now in diagnostic mode. The red LED will light up showing correct connections in the following steps:
1. Depressing the SET key
2. Depressing the Resume key
3. Depressing the brake pedal
4. Driving on the road, the LED will flash ON/OFF once per second.
(I put the wagon up on stands to do this last test)
Once in diagnostic mode, the actuator function can be checked. To do this, start the engine. Tap the SET button about 10-15 times. (you should hear the solenoid clicking in the servo) The revs should rise as the cruise control pull in. The revs should now be steady. Tapping the RES/DEC key will reduce the revs. Now tap the brake pedal, the revs should drop to idle.
To exit diagnostic mode, turn the cruise control ON/OFF switch to the OFF position.
Hope this helps. There is also a trouble shooting guide, too much to include here. If you want a scanned copy emailed, drop me a line on gezza90 at tpg dot com dot au
Good luck...
Gerry
AnswerID: 141805
Reply By: V8troopie - Thursday, Dec 01, 2005 at 02:42
Mine stopped working once too. The problem was the switch I had fitted to the clutch pedal, it had moved a little. Readjusting it made the unit fully operational again.
Check the brake and clutch switches ( if fitted) first, then see if all the magnets are still present on the tail shaft flange, lastly check the vacuum hose connection and the attachment of the throttle cable actuator.
If it just stopped suddenly its most likely one of the above.
Good luck in finding the problem.
Klaus
AnswerID: 141866
Follow Up By: IBJ - Thursday, Dec 01, 2005 at 07:58
Thanks Guys, that's all I need.
FollowupID: 395505
Follow Up By: 944runner - Thursday, Dec 01, 2005 at 12:18
V8Troopie was wondering if you have any ideas where I can get the clutch switch from or if you have any ideas on how to make one myself?
FollowupID: 395547
Follow Up By: Ian from Thermoguard Instruments - Thursday, Dec 01, 2005 at 13:36
Hi 944,
I've got a simple circuit that allows any 'common or garden variety' brake light switch to be used as a clutch switch. Mine's been working for several years now on my AP60 - I'd imagine the AP50 would work the same in this regard.
Send me PM if you'd like the details.
Ian
FollowupID: 395554
Follow Up By: joc45 - Thursday, Dec 01, 2005 at 14:28
I made the clutch switch using a microswitch with inbuilt lever. Usually avail from Jaycar, etc. I used a changeover switch so that the brake lights didn't operate when you pressed the clutch pedal, made up a bracket from some scrap plastic.
My AP50 stopped working recently, and I found it was the crimp connectors which connect the AP50 to the brake light wiring. Using the diagnostic facility helped a lot.
Gerry
FollowupID: 395558
Reply By: 944runner - Thursday, Dec 01, 2005 at 15:56
Ian
can you please send the diagram to byford@internode.on.net.
that would be great.
AnswerID: 141971
