FollowupID: 395835 Submitted:
Saturday, Dec 03, 2005 at 12:21
Member - 'Lucy' posted:
Good afternoon Michael.
Mate! go to the head of the class, you have hit it in one.
I don't mean to tell you or anybody else how to suck eggs here, so I'll do my best to explain it understandable plain english.
In essence all any type of pump does is create high presure on the outlet side and low presure on the inlet side to it, with the low pressure part variously described as the suction/lift/drag/pull etc capacity/capabilty.
This in turn creates a vacuum(low presure) on the inlet side causing the fuel to flow (be sucked/dragged) to the pump, with the pump then pushing it on to where it has to go at whatever presure the pump is designed to operate at.
Very basicaly (no physics engineering debate here) cavitation occurs when the flow to the pump is insufficient - for WHATEVER reason - for the pumps output pressure requirement.
In the case you and I are talking about i.e. Diesel engines in vehicles with constantly changing RPM's the usual effect of cavitation is that when the engine hits the critical RPM (what ever it may be) there is insufficient fuel to keep the RPM'S increasing without being impeded.
YES! the effect can be adequately descibed as:
' Does it by any chance cause a hesitation in engine acceleration similar to the feeling of fuel starvation?'
1HZ motors use this type of fuel flow system. Obviously the OEM engineers forsaw no reason to use inline booster pumps prior to the filters.
It just so happed that the critical RPM level on my 1HZ Troopy was 3000 RPM.
In my case the case the fuel flow was being impeded by the 'drag effect' through the filters. In essence, filters are just a blockage (but a necessary one)in the fuel line before the pump.
It made not one iota of difference that I changed the two filters every 5000Km and watched the fuel quality like a hawk.
There are a number of ways of eliminating this problem.
I personally took the option of changing the OEM filtering system to the CAV sytem for a number of reasons that all suited myself and how I operate.
This is not to say that what I do is good for everybody else ( this line is just for those who forgot to take their pills today).
I did play around with the idea of in line pre-aux fuel pumps, however in the end its just more mechanical trhings to go wrong. What convinced me on this was the NISSAN problem that occurs ' too intermittently' when pumping between fuel tanks.
Hope this sheds a bit a light on it for you.
Ken Robinson
 Click Image to Enlarge |
| Marriage, One mans insane desire to feed and clothe another mans daughter
