DPChip
Submitted: Friday, Dec 02, 2005 at 14:29
Twinkles
Does anyone have any experience or knowledge of "DPChip"? Similar to "Safari Dtronic". Are there other chips available?
Reply By: Member - The Crow (QLD) - Friday, Dec 02, 2005 at 19:34
For another try this site www.steinbauer.com.au looks the goods.
| 200 Series V8 Diesel
Thanks for the Rest Flying West and Flying Very Low along the track not coming back. The CrowLifetime Member My Profile My Blog Send Message |
142170
Reply By: prado_95 - Sunday, Dec 04, 2005 at 15:58
Twinkles,
You did not mention which vehicle you are referring to, so I'll be general.
The reality ie that there are few like products available now (yes I know each vendor is going to say that theirs is completly different to all the others on the market - I can even add my own ENG-TEK range to that).
Essentially they remap engine parameters with the view to more power. How much more power depends on a few things, including the reliability/durability you want from the motor.
Diesel engines are controlled (in the vast majority) by the amount of fuel injected (were as on a petrol you control the air, then try to maintain a desirable A/F ratio). Given that, all Diesel Tuning Modules will all add more fuel. Some will fool the ECU into this by modifying sensor inputs, others will modify the ECU outputs. Some new (mostly European) engines now have provision to modify the ECU program by re-flashing it. This is quick and easy, but will be lost if the dealer ever updates the ECU program to address a manufacturer identifed 'problems'.
You can expect a 15% to 35% power improvement by installing a Diesel Tuning Module.- depending on your vehicle and its existing state of tune. The main thing you should be looking for is TORQUE improvment on a diesel engine, since most diesel 4x4 and truck engines are not operated at red line very often. You may even get more, but care is needed to ensure long term reliabilty.
BEFORE you install a Diesel Tuning Module I would suggest that you do some of the simple things first, like a free flowing exhaust. If its a 4 to 5 litre engine a 3" system is required, otherwise go for 2.75" for 3 litre engines. Typically the turbo dump housing on factory TD engines leaves a LOT to be desired, so a huge exhaust system is not going to solve that problem (but will help). As an example look at the picture of factory dump housing. That matchbox wont go thru the casting from a 4.2 litre TD engine.
By the time you see the temp gauge move much on a long
hill, the turbo will be
well into the problem zone if you over do the additional power without other mods to retain reliability (an the first one is to keep the EGT to a tolerable level by improvong air flow into and out of the engine).
Hope that clears up some points, and helps you.
142345
Reply By: Twinkles - Sunday, Dec 04, 2005 at 22:24
Thanks for that information Dave. I looked at the ENG TEK site.
I have a friend with a Ford F250. Monster of a vehicle. He tows an enormous 36 foot long horse float rig. He got a plugin chip from the States (not adjustable) called "The Edge" and has has dramatic improvement in towing and fuel consumption. It was a fraction of the cost of the ones I've seen in Australia.
Why are the ones available here so expensive? Some are adjustable, some are not.
142398
