FollowupID: 395927 Submitted:
Sunday, Dec 04, 2005 at 21:38
Member - 'Lucy' posted:
Here ia another simple test for you.
Turn UHF on.
Select channel 20. Make sure there is no interference.
Fire up the vehicle.
Now according to the script you now should have this interference thingy on channel 20.
NOW disconnect the aerial from the back of the UHF set.
Result (1) No more interference = its that mother of an aerial
Result (2) Interference continues = its comming up the 'wires' most probably.
Result (3) Its none of the above and maybe some 'harmonic' thingo directly interfering with that particular set.
If possibl, borrow another UHF, set different make. Temporary rig it up using your aerial and see what happens.
Ken Robinson
Imagination is more important than knowledge
 Click Image to Enlarge |
| Marriage, One mans insane desire to feed and clothe another mans daughter
