Water trap for compressor
Submitted: Monday, Dec 05, 2005 at 12:45
Austravel
I tend to get a lot of moisture in the air from my compressor. It's much better now I've put a small receiver under the tray but would like to get the rest out. Can anyone recommend a small
water trap/filter I could use. Not after the large glass bowl style used in commerical air comps. There must be something around for our small, low flow compressors.
Reply By: Member - Troll 81 (QLD) - Monday, Dec 05, 2005 at 12:48
I have the same problem with my ARB pump. One thing I was worried about is does that
water end up in the lines going to the air lockers? I was always a little concerned about this but never followed up, thanks for raising the point
142462
Reply By: V8troopie - Monday, Dec 05, 2005 at 15:25
There are small glass bowl traps available. I have one on my shed compressor ( twin piston, ex car air con compressor) the glass bowl is about 25mm diameter and about 50mm long. It has a drain valve on the bottom, no need to undo glass bowl for draining. I got it from a hydraulic/air gear supplier (Enzed) years ago, it should be still available. You'd have to get 3/8 BSP to hose barb adaptors to plumb it into the air line. It also has to be mounted vertical ( obviously).
Klaus
142466
Reply By: kev.h - Monday, Dec 05, 2005 at 21:17
anyone who sells air compressors will have
water traps available try repco supercheap or someone like that
regards Kev
142519
Reply By: Austravel - Tuesday, Dec 06, 2005 at 14:09
Thanks all.
142608
