Navara ZD30 Vs Patrol ZD30
Submitted: Tuesday, Dec 06, 2005 at 11:29
ThreadID: 28643 Views:14539 Replies:4 FollowUps:6
Ok, can someone clarify for me why there have been dramas with the Patrol motor but not the Navara...given that I am assuming the motors are the same minus the intercooler...or am I way off track here.
Many Thanks
Reply By: Notso - Tuesday, Dec 06, 2005 at 19:17
As far as can be discerned from the outside they are the same. As you say minus the intercooler.
As far as I know the gearbox is a lighter one as well so maybe they just wanted to de rate the motor a bit to make it easier on the gearbox.
AnswerID: 142657
Follow Up By: Member - toohey - Tuesday, Dec 06, 2005 at 20:36
g'day notso & snow
i 've got a navara, to be honest with ya' i have'nt got a bloody clue,i've tried to reseach this thru heaps of chanels, no answers that ain't to say it won't happen.
cheers toohey
FollowupID: 396184
Reply By: 120scruiser - Tuesday, Dec 06, 2005 at 22:27
Same motor but no intercooler means less air in cylinder, means less fuel injected, means less of a bang in combustion chamber means less strain on small motor.
Possibly the Navara goes and is designed about right for the size of the engine where as the Patrol just seems to go too damn good for the weight it is pushing and the size of the engine.
I've got customers with Navaras pushing 100 000 km and they have been not regularly serviced and are going fine and I have customers with impecably maintained service records and they still went bang.
One of lifes mystery's.
The only issue with Navaras to date is the timing chains are a bit rattly but when you pull them down and see how big they are, you can understand why they would easily stretch as they aren't very big. I have only heard of one failing to date in a patrol so that is an isolated incident.
120scruiser
AnswerID: 142683
Follow Up By: Member - Ross H (QLD) - Wednesday, Dec 07, 2005 at 00:57
Hi 120
I thought the zd30 was gear drive and not chain on navara's
regards ross
FollowupID: 396243
Follow Up By: Member - toohey - Wednesday, Dec 07, 2005 at 04:48
g'day cruiser
is the lift pump in the zd30 strong enough to handle an extra fuel filter such as a lucas cav,what do you reckon?
cheers toohey.
FollowupID: 396247
Follow Up By: 120scruiser - Wednesday, Dec 07, 2005 at 09:52
toohey
I have only had customers request to have the OEM filters removed and the CAV type installed.
I can't comment on whether or not to run oem and cav.
All I know is they need impeccably clean diesel. The tolerance in the pumps is that fine and our diesel out here is dirty compared to Europe.
Hope this helps.
FollowupID: 396277
Reply By: Member - Andrew(WA) - Tuesday, Dec 06, 2005 at 23:05
and navara's have a smaller turbo I am led to believe..but you wouldn't know it when driving one.
AnswerID: 142691
Follow Up By: Leroy - Wednesday, Dec 07, 2005 at 15:26
someone posted recently that the Navara has an older style turbo with a waste gate and not the variable vane as the Patrol. Who has a Navara manual??
Leroy
FollowupID: 396323
Reply By: snow - Wednesday, Dec 07, 2005 at 19:53
Many thanks for the replies.
AnswerID: 142872
Follow Up By: fourstall2000 - Thursday, Dec 08, 2005 at 11:17
My information is that the CAV is not as fine a filter as the Nissan type,if this is correct people replacing original filters with CAV are asking for trouble.
FollowupID: 396448
