HZJ75 Steering Damper
Submitted: Thursday, Jan 09, 2003 at 02:30
Troopie owner
What are the symptoms of a shot damper?
Any recomendations on the best steering damper for this model?
How to easily remove it ( have tried undoing the nuts and giving it a wallop!)
Thanks in advance
Reply By: tour boy - Thursday, Jan 09, 2003 at 06:51
The pin is tapered so a tie rod seperator may be needed. If it is shot, it may leak and the steering will kick alot more and may be harder to control under heavy braking. Any good quality damper will do but genuine will last alot longer if you want to spend mega bucks!!
10886
Reply By: Member - Robert - Thursday, Jan 09, 2003 at 12:21
To remove it using an FBH (a big hammer), you also need a solid backing point to counter the wallop. I have used a mallet on the other side to remove tie-rod ends. I find that a block of wood dampers the action too much, so something of steel construction is the go.
Rob.
10903
Reply By: Truckster - Thursday, Jan 09, 2003 at 21:54
steering shakes on corrigated roads, more viabration/shake when you hit potholes.
Also anythin simliar to what you would get from a Shocky since thats what it is!
for the price replace it! Keep the old one for a spare.
BIG HAMMER to remove, although you shouldnt have to
10951
Reply By: colin - Friday, Jan 10, 2003 at 21:41
any shock absorber has a life of 70000ks, in easy conditions less in a harsh terrain, you know your vehicle. A shocky doesnt have to be leaking to be shot. Col.
11028
