GU - Front Diff Clicking Noise
Submitted: Wednesday, Dec 07, 2005 at 17:19
Fusion
Hi Guys,
My GU4 Patrol has a clicking noise, a bit like the old spokey dokes (or bits of cardboard) we put in the bike spokes as kids, only a lot quieter.... but only when in 4wd. The noise persists for a while after going back to 2wd, then dissappears again, so I'm confident it's to do with the front diff.
Nissan have had it twice and haven't fixed it yet. 1st try, repacked wheel bearings, 2nd try did similar thing to front diff I think. Friday is their 3rd try, I'l like to give them a leg up if I can.
I've heard of this before somewhere but I don't recall where.
Any clues?
Thanks,
Aaron.
Reply By: Andrew (Whyalla SA) - Wednesday, Dec 07, 2005 at 17:44
CV joint or more likely its the auto hubs.
Try locking the hubs and see if it still happens.
142846
Follow Up By: Fusion - Wednesday, Dec 07, 2005 at 18:25
Hi Andrew,
Yeah I though it might be the auto hubs, so when I was out with Paul & Frank (Adventure Campers) for a week around Innaminka shooting the campers I locked them in but unfortunately no change.
I'll ask about CV's when I drop it in on Friday.
Thanks,
Aaron.
P.S. - love the magazine, great work :)
396353
Reply By: Truckster (Vic) - Wednesday, Dec 07, 2005 at 18:44
Does the noise increase when you turn?
142854
Follow Up By: Fusion - Wednesday, Dec 07, 2005 at 18:51
I've driven hundreds of kays on sand, loose gravel, wet stuff but haven't noticed any situation that increases or decreases the sound level.
It's not very loud, but it is annoying and means something isn't right. On the
Tibooburra, Cam Corner, Innaminka trip I had a 100 Cruiser owner as a co-driver and was forced (through sheer embarrasement) to apologise for the noise my Nissan was making :(
So the answer is I haven't done any specific testing on corners, but I haven't noticed it.
I'll go and have a quick drive tonight to specifically listen for changes when turning.
Thanks,
Aaron.
396368
Follow Up By: Andrew (Whyalla SA) - Wednesday, Dec 07, 2005 at 21:15
Wow, it must be load then. If its a CV and its that loud then the damage should be pretty obvious.
396395
Follow Up By: Truckster (Vic) - Thursday, Dec 08, 2005 at 17:55
I have the same sound coming from my GQ at the moment.
thought of CVs but if it hapens in straight line, and doesnt increase in corners, it aint them..
So Im lookin at the hubs next..
bleep in me off big time.
396503
Reply By: muzzimbidgie - Wednesday, Dec 07, 2005 at 19:33
Aaron. My 2000 model GU does the same thing. I have had it in to the local mech several times. I even had them remove/re-pack the whole lot (swivel hubs, etc) and it still does it.
Now I'm not worried, I just drive it.
142864
Follow Up By: Fusion - Wednesday, Dec 07, 2005 at 22:24
G'day Muzz,
From the low level of noise coming out of it, I don't think it's anything major. But I did buy the car new 11mths ago, so I'd like it to be making all the right noises or lack of them :)
I'm heading off to Fraser on the weekend though, and if Nissan can't fix it with the 3rd try, I'll not be too worried while I'm away. Do you Nissan would take any responsiblity if it broke down on Fraser though? No me either :)
Thanks,
Aaron.
396409
Reply By: P.G. (Tas) - Wednesday, Dec 07, 2005 at 19:34
G'day Aaron, had a similar problem in my GU III after I had it serviced. Turned out to be the wrong transmission fluid in the transfer case. Apparently the transfer case was turning the front diff and hubs with the selector in 2WD.
Hope this helps
142866
Follow Up By: Fusion - Wednesday, Dec 07, 2005 at 22:20
Hi PG,
Sounds like it was more than just wrong fluid, must have been glue or something to make the transfer case stick when it was out of 4wd ;) It doesn't sound too healthy. But I'll mention it the Nissan as
Thanks,
Aaron.
396408
Reply By: STEVE069 - Wednesday, Dec 07, 2005 at 22:26
Hi Aaron,
Like others have said first check t-case oil, we used to fit ATF witch is verry thin and doesnt drag on the chain,turning the front drive shaft and causing the auto hubs to try to engauge. Second thing to check is the adjustment on the manual hubs (if fitted). Hope this helps.
Steve
142904
Reply By: Bilbo - Wednesday, Dec 07, 2005 at 23:21
Fusion,
Do you have manual locking hubs or auto locking hubs. My answer will depend on your answer.
I had a similar problem on a GQ and the solution was simple. But if it's auto hubs then I can't help ya.
Bilbo
142911
Follow Up By: Fusion - Wednesday, Dec 07, 2005 at 23:36
Hey Mr Baggins,
My Gu has Auto/Manual hubs. That is, they are usually auto, but you can lock them in manual.
What was your fix? I'll be printing out all these answers and taking them to Nissan so they can see what others have done.
Thanks,
Aaron.
396415
Follow Up By: Bilbo - Thursday, Dec 08, 2005 at 13:18
Fusion,
I'm not sure if the new Patrols ahve the same front end set up as the old ones, but here's what I found on my old 1989 GQ Maverick (Nissan) ute. It's an edited reprint from a rely I made on the
forum last year. Hope it helps.
Copy 'n past start.............."inside the front locking hub there is a spacer ring. It's easy to get access to it. Just remove the Allen screws (11mm metric) and tap off (gently) the outer hub. Inside there you'll see the locking clutch. Around the outside of that clutch is very thin steel ring that looks like part of the whole assemby. It isn't. It fits between the aluminium outer casing and the inner clutch asembly. These rings can 'catch' on the clutch hub and create high temperatures through friction. When they are really dry and 'catching' they can make a very elusive rattling sound. It took me weeks to track this noise down when it happened to me. Just remove the ring and have a look at it. If it looks burnt or scarred then it's 'catching'. Rub down the high spots on the inside of the ring and on the outside of the clutch assembly with fine emery cloth or wet 'n dry pape, put some grease on it and put it back. Be careful with removing & replacing the circlip. It's tricky........."
Cut 'n Paste ends
I had to do that way out in the bush. It was driving me insane listening to that noise. I sat on the bonnet of the truck whilst my son drove. Hanging onto the bull bar over the front of the truclk............listening, listening..........I musta been mad but I found it.
Bilbo
396459
Follow Up By: Fusion - Thursday, Dec 08, 2005 at 14:36
LOL, I'd love to see some video of you holding onto the bullbar while driving along. Did anyone see you?
Great job on finding the problem. I'll point this one out to Nissan as
well. There have been a number of issues people have had, it should be one of them. I'll let you all know, assuming Nissan fix it :)
Thanks,
Bilbo.
396470
Follow Up By: Bilbo - Thursday, Dec 08, 2005 at 21:36
Fusion,
No, there's no video and only my son was with me. We were prospecting about 120kms NE of
Laverton in WA - indian country, real far out.
We had all sorts of problems, including his Suzuki Sierra at the time.
Afer stripping out a whole Nissan front axle with no help in sight, whilst whistling and drinking a beer, my son stated - "Only crazy people come out here - Dad yer mad". And he never came bush with me again.
Liuckily I'm a former truck mechanic, so breaking down in the bush really wasn't a BIG problem. But I can think of better ways to pass some time!
Hope ya fix yer Nissan.
Bilbo
396537
