Custom snorkels and custom rear bars
Submitted: Saturday, Dec 10, 2005 at 17:45
Pajio
Does anyone know how i would go about getting a
snorkel made for my pajero io?
and is it possible to fabricate steel rear bars cheaply?
Reply By: Shaker - Saturday, Dec 10, 2005 at 17:58
Whereabouts are you?
143249
Reply By: hoyks - Saturday, Dec 10, 2005 at 18:12
Rear bar would be easy enough.
Snorkel wouldn't be too hard either. You need to find an exhaust
shop (or metal fabricator that knows someone) with a MANDREL bender, not just the standard bender, that is willing to give it a go.
The mandrel bender has a mandrel that fits up the tube (hence the name) so that the diameter of the tube stays constant throughout the bend. It gives a much better appearance and smoother, unrestricted airflow through the duct. More importantly it looks better. ;-)
Getting the angles right can be a bit fiddly and the under bonnet ducting can be fun. Then there is getting up the courage to lay into the paint with a 3” hole saw.
Snorkel heads are easy enough to come by at 4x4 shops. One to fit a Suzuki
snorkel should suit the Io, find the diameter of the
snorkel head base and make the tube to suit.
143250
Reply By: Carchania - Saturday, Dec 10, 2005 at 18:53
gday mate
for the
snorkel call a place like queensland diesel spares and ask for the size pipe u want (ie. 3", 4", etc). i am currently making a dual setup for my safari out of 4" alloy tube. u can either get the tube mandrel bent or buy the big rubber elbows and metal clamps that truckies use. the cost of fabricating a rear bar is pretty hard to say, as there r a few factors to consider. do u want a rear wheel carrier or two? jerry can holder? is it going to have a towbar hitch receiver as part of it? hilift jack mounting points? etc etc.
Leayton
143256
Reply By: rolande- Sunday, Dec 11, 2005 at 18:28
You could also see if a stainless fabricator can make up something suitable, welding only as 30 , 45, and 90 degree elbows can be bought separately and simply welded together
Rolande
143350
