Hayman Reece Towbars
Submitted: Sunday, Dec 11, 2005 at 17:49
ThreadID: 28779 Views:10796 Replies:8 FollowUps:8
Hi all,
Makes me wonder with Hayman Reese Towhitches. Very strong in construction fully welded box section BUT// one small pin to take all the weight on the draw bar, my Landrover is supposingly able to tow 3500kgs legal with trailer brakes. Would not be game without drilling another hole and fit Hi-tensile bolt.
Any comments
Regards Axle
Reply By: Member - John - Sunday, Dec 11, 2005 at 17:58
Good question for HR, ask them what the weight loading on the pin is?? Also ask about the legality of drilling another hole and fitting bolts, should be interesting answers......Ask for them in writing
John and Jan
AnswerID: 143349
Reply By: Kiwi Kia - Sunday, Dec 11, 2005 at 18:41
One hole is enough! The hole needs to be at least 50 mm from the end of the reciever hitch and mild steel is ok for the pin. High tensile, if used, should not be of to high a grade as the higher the grade the more brittle they are and can not take a large shock load. Remember that the pin is in shear loading at two points so the load is shared (like having two tow hooks and a bridle strap). I would not use a pin on its own, use a reciever with a forged steel tow hook (NB FORGED AND NOT CAST!!!). And if you are wondering about the strength of tow hitches, how about pintle hooks? I am a member of the safety committee of a 4wd club and we have some reservations about using them for a snatch recovery. We will be testing a pintle hook to destruction soon by hooking it up in a cage at a commercial test lab and loading it up till it breaks (both straight and angle pulls). We have already done several original equipment hooks on several 4wd's and some failed by breaking with chunks of metal flying through the air! Our club now demands ONLY forged and not cast tow hooks.
AnswerID: 143351
Follow Up By: Axle - Sunday, Dec 11, 2005 at 21:33
Thanks mate for info not to sure on what you mean by use a receiver and not pin on its own
Axle
FollowupID: 396874
Follow Up By: Member - Willie , Epping .Syd. - Monday, Dec 12, 2005 at 09:19
Would you know if the original eqipment towhooks on the Toyota Landcruiser 100 are forged or cast ?? You have me worried now !
Thanks ,
Willie .
FollowupID: 396922
Reply By: Bilbo - Sunday, Dec 11, 2005 at 18:50
A carpenter mate of mine once told me that the shear strength of a TRUE 6 inch nail was around 3 tonnes. A TRUE six inch nail is about 5 mm thick. A hitch tow pin is about 12 mm.
You work it out.
Bilbo
AnswerID: 143355
Follow Up By: Bonz (Vic) - Sunday, Dec 11, 2005 at 21:22
12 / 5 = 2.4
2.4 * 3 = 7.2 tonnes
thats lots
FollowupID: 396871
Follow Up By: Bonz (Vic) - Sunday, Dec 11, 2005 at 21:43
Actually if you apply Hookes law, you will find that with a double shear, the force required to shear the 12mm pin in mild steel will be:
R (shear) = 2 * 0.785 *144 (diameter squared) * f (s) [55Mpa for Mild steel]
That equals 12434.4 Newtons or 1267.955928 tonnes force
NOW THATS A LOT!
FollowupID: 396879
Follow Up By: Member - Ed. C.- Sunday, Dec 11, 2005 at 23:16
The HR hitch pin is actually 5/8" (16mm) dia.
(well mine is, anyway).......
Bonz, you may wish to re-calculate :-)))
Confucius say.....
FollowupID: 396889
Follow Up By: Bonz (Vic) - Tuesday, Dec 13, 2005 at 17:26
Now that DOES make a difference
Its now 2254.143872 tonnes force to shear a 16mm pin, that is more than lots.
FollowupID: 397191
Reply By: mcgra (VIC) - Sunday, Dec 11, 2005 at 18:59
hi axle
know af a fellow who done some tests on the pin it took 12 tonnes of force for the pin to plastic. ( ithink thats the term he used). which means it did not retun to its normal straight state.
the test was done on arb and hayman pins.
cheers gra
AnswerID: 143357
Follow Up By: Axle - Sunday, Dec 11, 2005 at 22:30
Thanks mate for reply 12tonnes a lot of weight as bonz has calculated as well . Im from old school mate if it dont look right it probably aint. murphys law) All tow hitch pins on heavy equiptment are always vertical tractors trucks etc. large van to tow mate gotta make it look safer peace of mind.
Thanks Axle
FollowupID: 396884
Reply By: Kiwi Kia - Monday, Dec 12, 2005 at 06:47
Hi Axle, When I said I would prefer not to use just the pin I was meaning that I use a square section tube with a tow hook mounted on it instead of a tow ball. It is common practice in Australia to just feed a loop end of a tow / snatch strap up into the reciever and slide the hitch pin through the hole,strap,hole to anchor the strap. I am not saying that this is not a good idea just that I prefer using a tow hook.
AnswerID: 143409
Reply By: Ken - Monday, Dec 12, 2005 at 08:33
Hi Kiwi,
You are spot on with your advice. The thing to remeber with high tensile bolts is they are designed for tensile loads. This does not make them suitable for all types of loadngs, and as you say their brittleness makes them unsuitable for shear loads.
Ken
AnswerID: 143414
Reply By: andoland - Monday, Dec 12, 2005 at 11:58
Gents,
Let me pull out my engineering degree for a minute and add some information.
Stress = force/area so Force = stress x area, which Bonz has used.
Using Bonz's shear stress limit of 55MPa, the equation for force is:
55 * pi * 12 * 12/4 = 6220 Newtons. As the stress is applied in two places you can double this to 12440 Newtons.
Divide by 9.81 to get kilograms. So 12440 1268kg or 1.268 tonnes. Sorry Bonz you are out by a factor of 1000.
In any case the shear strength of mild steel is about 144MPa so a 12mm pin should be able to take about 3.3 tonnes of load. Keep in mind that the pin holding your towbar pin is is probably somewhat stronger than mild steel so the actual load rating is probably higher. For a 16mm pin this load capacity becomes 5.9 tonnes.
Also need to remember that the tow rating of 3500 kg is not the actual load that is placed on the towbar, it is the weight of the trailer that can be towed.
AnswerID: 143448
Follow Up By: Banjo 1 - Monday, Dec 12, 2005 at 12:30
Indeed - I'm no engineer but can appreciate risky design to an extent, after years of fiddling with camping toys - that pinned tubing assembly in the HR towbar setup looks mighty strong to me - can't imagine that being compromised in a hurry. I suggest any force that could wreck the pin would make the safety chains useless too.
FollowupID: 396947
Reply By: Kiwi Kia - Monday, Dec 12, 2005 at 18:20
Wille, If you are watching this thread then here is some of what we found regarding original equipment tow hooks;
Big Horn - LOOK OUT they broke!
Nissan Saffari - not bolted, the side welds crack and the hooks tear off!
Surf - off set hook allows the strain to shear the rear bolt leaving the hook attached by only one bolt!
I have not seen any original equipment recovery hooks on 100 series vehicles but I have seen the factory tie-down points. I think that they are prob ok for towing but I would certainly not do any repetitive serious snatching using them. Consider double plating and using spreaders in the chassis rails and fitting an aftermarket forged recovery hook, use grade 8 bolts only.
AnswerID: 143506
