Question re NISSAN SAFARI HELP
Submitted: Monday, Dec 12, 2005 at 12:42
ThreadID: 28796 Views:4603 Replies:5 FollowUps:1
Am looking at buying a Nissan SAFARI.... I realise this topic has been probably discussed before but a search did not help on the availability of parts for these 4bys. I have been told conflicting stories that yes they are hard to get parts for if things go wrong (as say GQ parts wont fit) but other mechanic says imports (namely surfs) are no prob.
SO, does anyone know whether GQ parts bolt up to the SAFARIS or are they slightly different? Has anyone had major dramas with replacement parts if things go wrong??
Help
Reply By: Truckster (Vic) - Monday, Dec 12, 2005 at 13:33
There are some parts that are different, but most major things are the same.
Remember, dont believe all the "LOW" klms you see either.
AnswerID: 143463
Reply By: revhead307 - Monday, Dec 12, 2005 at 13:45
Gday, I have had an 88 GQ Safari for 6 months. Very happy with it.
Standard GQ parts bolt straight up no dramas. I removed the towbar from my old SWB and bolted it up to the Safari.
There are some things to note....
They are 24V not 12...,so you have to make some alterations like fitting 24v - 12v converters if running 12v gear (there are a number of other ways around the problem like charge equalisers)
while 90% of standard GQ parts will bolt up...obviously you have 24v starter motor, alternator and other electrics.
Due to the number of imports in OZ, nissan have stocked parts for them as well...so sourcing 24v Glow plugs is as simple as picking up the phone and ringing ur nissan parts.
Some interior trims etc may be different to OZ models.
Insurance has to be sourced through a specialist like just car insurance, as SGIO wont insure imports.
Rev
AnswerID: 143464
Follow Up By: Greggo - Monday, Dec 12, 2005 at 14:00
thanks mate... the one I am looking at has a cd player so obviously there is a a voltage reducer in it somewhere.
I wonder why they use 24v are there any advantages (eg; easier starting over 12v)?
FollowupID: 396959
Reply By: revhead307 - Monday, Dec 12, 2005 at 14:10
Gday,
I spose 24v is more efficient on a lot of things (hence use in trucks)...seems to work well...cranks over like a beauty.
yeah there is a small factory reducer behind the passenger side kick panel (under the glove box).
this runs the factory stereo, and a few dash instruments..but wouldnt be suitable for larger 12V accessories...or aftermarket CD players with 4x 50W inbuilt amp etc)
personally i have a 20A redarc reducer to run 12V cig lighter (it already has a 24V vig lighter), also runs UHF and Radar detector etc.
I have a 30A GSL 24v - 12v battery charger than maintains a 3rd (auxillary 12v) sealed battery in the rear to run car fridge and high power car stereo.
I wired up my towbar with a redarc 10A trailer reducer to tow a van.
check out
http://www.patrol4x4.com/forum/
it has a nissan safari forum (albeit small) scroll back trough the archives and you will have all your questions answered even how to disable to 100km/hr annoying speed chime.
Rev
AnswerID: 143467
Reply By: Batboy - Monday, Dec 12, 2005 at 18:14
Ditto the parts GQ to Safari
Have replaced
Clutch
Clutch master and slave cylinders
Panhard bushes
free wheeling hubs
Fuel air and oil filters
Engine mounts front and rear
I have also installed a charge equaliser to cope with the 12v gear. Works fine.
Also a tow bar from a wrecker which bolted straight on.
I also use a gregorys manual for a GQ with no significant differences so far.
NRMA will insure imports but only market value they will not do agreed value
AnswerID: 143504
Reply By: Big Woody - Monday, Dec 12, 2005 at 22:15
I had a Nissan Safari for 18 months and sold it about 6 months ago with 290,000km's on the clock.
As mentioned above, the only real difference I found compared with the Oz version is the 24 volt electrics. I did have trouble getting a starter motor but I think that it was more of an issue because I live in Bundaberg and imports aren't so common.
The other thing I would do is rustproof it as I don't think the Jap units get the same panel treatment as the Oz version and seem to be a bit more prone to rust.
Would I have another one? Probably not.
Even though I did 100,000 km's with very few dramas I did not feel comfortable going on a long trip for the fear of being stuck somewhere waiting to try and source parts from interstate etc. It was also a mission to get insurance and had to sacrifice my no claim bonus to go with another insurance company.
Also with the price of the Oz versions at the moment I can't see the the benefit now anyway.
Brett
AnswerID: 143568
