OT, Computer, Favourites list
Submitted: Monday, Dec 12, 2005 at 18:04
ThreadID: 28809 Views:2697 Replies:6 FollowUps:1
Hello all
Q' for the computer savvy.
Is it possible to save/transfer from old comp' A to new comp' B the column of "favourites". I have many saved in the old comp' and wish to add to new.
Is it possible at all, or how can it be done "easily"?? Not asking too much am I???
Andy
Reply By: glenno(qld) - Monday, Dec 12, 2005 at 18:17
Burn them .
I assume you have xp .
AnswerID: 143505
Follow Up By: Wisey (NSW) - Monday, Dec 12, 2005 at 18:30
Thanks glenno
Sorry, should have said this before. The old has Win 98 and no burner but the new is XP and burner.
Can I somehow save it to floppy?
FollowupID: 397005
Reply By: Member - Paul P (Bris) - Monday, Dec 12, 2005 at 18:31
Greetings
Commonly used WEB browsers allow you to import and export your favourites in various formats.
I assume you are using the same brand web browser on your new system as the old one. Simply export from one, burn the file onto a CD or USB storage device, and import into the other.
Choose manage Bookmarks from your favourite WEB browser Bookmarks menu for access to these options. Use of the browsers help file will further explain this capability. Use the search term " bookmarks" .
All your 4WD and Caravan reference URL's including of course Explore Ozz bookmark, will be in your new browser without any difficulty (just to keep the message on topic:-))
Paul
AnswerID: 143509
Reply By: Truckster (Vic) - Monday, Dec 12, 2005 at 18:37
if its XP goto DOCUMENTS AND SETTINGS/USERNAME/FAVORITES and you found them
Favorites is just a normal Folder. Links are almost like files, You can create folders in there and organise them too
Copy the Favorites folder, then put it on a floppy disk, copy contents of disk to new machine. If yours is more than mine which is 350kb you will amazed.
AnswerID: 143511
Reply By: Nudenut - Monday, Dec 12, 2005 at 18:40
internet explorer
click> file
Click> export
and follow the prompts
and as said above burn to cd or copy to wherever.....
AnswerID: 143512
Reply By: Notso - Monday, Dec 12, 2005 at 18:48
If XP you can use the files and settings transfer wizard to transfer all your settings etc to a new comp
Start
All programs
Accessories
System Tools
Files and Settings Transfer Wizard
and follow prompts
AnswerID: 143513
Reply By: Wisey (NSW) - Monday, Dec 12, 2005 at 19:18
Thanks everyone ::))))))))) I'll be busy for a while. I'll get back to ya soon
Andy
AnswerID: 143517
