Tyre Gauge
Submitted: Tuesday, Dec 13, 2005 at 09:53
Ross & Jen
Over the years have purchased numerous gauges and am now looking for one that is accurate. On a recent trip four other gauges all read differently. I am looking for quality and accuracy. I am sure there are some experts out there.
Reply By: Shaker - Tuesday, Dec 13, 2005 at 10:06
Good subject! I have exactly the same problem, I have tried all types, dial, digital etc & they all read differently. At the moment I am using one that i bought from repco, a Jamec dial type, around $30.00. I took it to Tyrepower & compared it to the guage they have which they swear is accurate, & it read the same. So, I am relatively happy, but not 100% convinced as to it's accuracy.
A lot of people also say that the old pencil type that force a calibrated rod out of the end are the most reliable, who knows?
143632
Reply By: Feral - Tuesday, Dec 13, 2005 at 11:05
Does it really matter????
As long as you have the same pressure according to the guage that you have, AND USE IT EACH TIME YOU CHECK THE PRESSURES, there would not be a problem with the inaccuracy of your guage.
We all make changes to pressures, up or down, to suit the conditions. Finally you will work out the pressues that you like according to the guage that you have. It dosn't matter if it is half a pound out.
Next post will be on clocks in vehicles according to the position of the sun!!!!
Lyndon.
Immaculate Discovery Td5
143638
Follow Up By: Member - Coyote (SA) - Tuesday, Dec 13, 2005 at 11:09
Have to agree with you Feral.. we don't all have exactly the same set of scales at home.. but Iknow if I've lost weight or put weight on when I stand on it.. it still says " One at a time please"
397134
Follow Up By: gramps - Tuesday, Dec 13, 2005 at 11:12
My dashmounted sundial works perfectly
well thankyou very much. No need for one of those newfangled clock thingies with all the little metal gizmos turning round. Not to mention that damn irritating cuckoo jumping out at the most inopportune times :))))))
397135
Follow Up By: vitara - Tuesday, Dec 13, 2005 at 11:18
It doesn't matter if its only a psi out here and there and all tyres have the same pressure as long as it's not out by 5 psi or more would make a big difference. Myns only a $20 cheapie from super cheap and had it calibrated/ check at my work and was out by 1/2 psi. Have had it 3 years now and check it every 12 months when our machinery at my worrk is done. Cant complain for the price. I think a major thing to is not to throw them about or drop them. Notice all the ones in the garages are stuffed from being dropped (and probably driven over as
well) which would stuff most things. Regards Vitara
397136
Follow Up By: Shaker - Tuesday, Dec 13, 2005 at 12:40
Some are out by more than 5 psi.
397153
Follow Up By: Feral - Tuesday, Dec 13, 2005 at 13:30
Yes they are.
But you set your pressures according to what the tyre is doing...ie. the shoulders are wearing....too little pressure. The middle is wearing...too much pressure. The ride is harsh..too much pressure. The rear feels loose....too little pressure. The fronts understeer...too much pressure.
It's about building a relationship with your tyre gauge and what the tyres are doing, not the accuracy of the tyre gauge itself.
Lyndon.
Immaculate Discovery Td5.
397156
Reply By: signman - Tuesday, Dec 13, 2005 at 11:54
I have a Michelin dial gauge. Cost about $25-but is consistent, easy to use & read.
143646
Reply By: Member - Crazie (VIC) - Tuesday, Dec 13, 2005 at 13:19
Ross and Jen
Best one I have found is the ones for the Polyair Airbags, branded Polyair, has to be the most accurate I have had. Next best would be a digital one i brought from a motorbike
shop for my bike.
143655
Follow Up By: Member - Tony G (ACT) - Tuesday, Dec 13, 2005 at 14:33
Yep I have a Polyair one as
well, had it for over 12 years and it still accurate. One of the only ones that go low enough for 4-6 psi in the bags when vehicle is unladen.
The only draw back is that you have to hold then on to read pressure,
well not a draw back really but by the time I get to the next tyre I have forgotten what the last one was.
397161
Follow Up By: porl - Tuesday, Dec 13, 2005 at 14:48
Yeah i agree the best one you can buy you will find in a motorcycle
shop where tyre pressures are way more important when you're on two
wheels than four. When I was riding bikes 20yrs ago i bought the best one i could afford, a michelin dial one. Still have it, is still accurate, and still holds the pressure for up to 2 weeks.
and why'd i go to a 4WD, got sick of falling over in sand, and of course, beer fridges don't carry too
well on a motorbike.
397163
Reply By: Sand Man (SA) - Tuesday, Dec 13, 2005 at 13:50
As good as any that I have found is the digital tyre gauge available from KMART.
Previous "mechanical" gauges I have tried in both pen and dial styles are a PITA.
The digital gauge from KMART is not only cheap but consistent. It turns itself off off after a few minutues and the mercury battery last "forever".
Easy to read too and measures in 0.5 PSI increments. (or KP's if you prefer)
I agree with others in that the actual acuracy (within reason) of a gauge is not important, just it's consistency.
143661
Reply By: cmilton54 - Tuesday, Dec 13, 2005 at 19:22
Go to a reptuable tyre store and check to see if they have their gauges checked with a calibrated gauge. If they do check yours with theirs, and adjust your pressure accordingly.
Charlie
143713
Reply By: Member - Phil G (SA) - Tuesday, Dec 13, 2005 at 19:39
I'll put another vote in for the digital gauges. I've had one 5 years, used heaps, and never changed the battery - it appears to be dead accurate when compared with expensive gauges, and it measures low pressures accurately, so is ideal for polyairs and that odd occasion where you might go below 10 psi on sand.
143718
Follow Up By: scoof - Wednesday, Dec 14, 2005 at 13:42
I'll second that digital is way to go.We all used them when I use to race speedway very robust.The dial type didn't last.
397312
Reply By: HJ60-2H - Tuesday, Dec 13, 2005 at 20:48
If you go to an industral gauge supplier you can get a gauge with the range and accuracy, robustness, and type you desire. I did this after years of dissapoitment with the commerical ones. Built it into a manifold and works a treat.
143736
Reply By: snailbait (Blue mntns) - Tuesday, Dec 13, 2005 at 21:14
hi
Ross
you could not afford it
143745
