All you OziExplorer experts out there
Submitted: Wednesday, Dec 14, 2005 at 17:11
Pajman Pete (SA)
Does anyone know how to change the colour of the moving map arrow from red to something else? The big red arrow gets hard to read on the Natmap 2005 series in the flat treeless plains between
Adelaide and almost everwhere else!
Pete
Reply By: Member - Robert R (QLD) - Wednesday, Dec 14, 2005 at 17:43
Pete,
Go into File, Configuration, Moving Map and select the pointer tap at the top. In there you can change the size, colour and style. Hope this helps.
Regards,
Robert
143862
Reply By: ExplorOz Team - David - Wednesday, Dec 14, 2005 at 17:44
Pete,
Easy one:
Go FILE - CONFIGURATION
Then select Moving Map tab - down the bottom you will see pointer colour and als pointer - you can change the pointer and the colour and even the size (use the Scale option).
Good luck.
143863
Follow Up By: Member - Robert R (QLD) - Wednesday, Dec 14, 2005 at 17:46
I was just going to say that. I gave directions for a PDA
397341
Follow Up By: Pajman Pete (SA) - Wednesday, Dec 14, 2005 at 23:33
Duh,
I knew it was going to be easy, I spent ages looking in the help file!
Pete
397405
Reply By: Pajman Pete (SA) - Wednesday, Dec 14, 2005 at 23:33
Thanks Robert and David
Pete
143935
