cheap ebay winches
Submitted: Wednesday, Dec 14, 2005 at 17:42
ThreadID: 28869 Views:2874 Replies:4 FollowUps:8
has any one bought a cheep winch on ebay are they any good there are 10000pnd winches for around $780 jfr
Reply By: glenno(qld) - Wednesday, Dec 14, 2005 at 18:24
I dont know what part of the country you are from but i counted 10 warn winches(private ads) in the trading post . About 9 other brands . Hope this helps
AnswerID: 143869
Reply By: Member - JD - Wednesday, Dec 14, 2005 at 19:22
Hi jfr,
If you type in, which winch,to our thread search option it will bring up a post I posted asking opions from forum members the responce was varied. I have since purchased a winch...which appears to be strong and robust and rated at 12000 lbs,but as I havent had the oportunity to test run and check it write out I cannot comment on its quality or lack of,shortly I will be putting it throught its paces.. it was made in China..the price was rite..once I test this unit out I will post a follow up to let everyone know my opion on my unit be it good or be it bad.
JD
AnswerID: 143874
Follow Up By: Member - Brian (Gold Coast) - Wednesday, Dec 14, 2005 at 19:31
JD,
A scenario I witnessed a few months back..... a friend with his brand new winch, decided to "test" it out on a reasonable incline, y'know... to load it up properly. With about half the cable out, it kinda jerked.... so he lowered himself back down and then rolled the cable out to find it wasn't anchored on the drum.... at all!!!
(It is now!)
He was lucky he was playing and not in "real life" as he could have been in a bit of strife! I promised myself there and then that I would "test" it out as he did when I get mine.
FollowupID: 397356
Follow Up By: Member - JD - Wednesday, Dec 14, 2005 at 19:44
Hi Brian,
Lucky he did'nt hurt himself,and also break the drum as I was told this is how they break,I had to rotate the clutch on mine so it would fit..but i've been told this is not uncommon,I've had mine all the way out and its conected LOL,yeah your suposed to pre tension the cable to "set " it on the drum properly and not damage the cable by crushing the under layers I'm going to hook up my trailer weighted up 500kgs set it this way hopefully under controlled circumstances..at least this is the plan...something I've been thinking about do you a circut breaker inline to power source??.
JD
FollowupID: 397358
Follow Up By: Member - Brian (Gold Coast) - Wednesday, Dec 14, 2005 at 19:48
Not sure about the breaker JD.... food for thought though... an auto sparkie will know for sure, I would think it needs one, but geeeeeze, you wouldn't want it tripping when you're on the side of a mountain would ya???
Truckster will know!!!!
FollowupID: 397359
Follow Up By: Member - JD - Wednesday, Dec 14, 2005 at 20:02
Definatly not,but its a very thick cable strait up to the battery if it shorts the whole system will melt!...maybe the safty in the controler ???Idont know?
JD
FollowupID: 397367
Follow Up By: Member - JD - Thursday, Dec 15, 2005 at 09:04
How rude ! Membership is current! Check your bank.
JD
FollowupID: 397434
Follow Up By: chump_boy - Thursday, Dec 15, 2005 at 11:53
Brian,
I'll say up front I sell these winches, so take what I say with a grain of salt....
I have seen how the cables are rolled onto the drum - the bolt is put into the little eye-let, the drum is rotated, and the cable is wound on. It is not wound on tightly in the factory, hence the reason pretensioning is required.
You will probably find the cable had a bit of spring in it, and actually snapped the head off the bolt as it sprung back. These bolts are not real strong, as you are normally required to have a few layers of cable on the drum before operation. The drum itself takes the force, not the bolt. It is kinda like if you wrapped a rope around a tree a few times, then pulled on the rope. The other, disconnected end has absolutely no force on it.
JD, I'll be very interested to see how you go with yours. It is one thing for the importer to try them out and tell you how good they are, but quite another for someone that has paid their hard earned for one.
Chump
FollowupID: 397460
Follow Up By: Member - Brian (Gold Coast) - Thursday, Dec 15, 2005 at 19:59
JD
I'm either;
A) A bit thick
or
B) the wrong side of 6 tinnies.....
but I don't get the "Membership is current" bit.......
(I suspect it is "B")
FollowupID: 397528
Reply By: Motherhen - Wednesday, Dec 14, 2005 at 20:09
We felt the eBay Chinese winches were good enough for occasional use (only there as a 'security blanket'), bid on a couple, but in the end we got a re-conditioned Warn at a good price.
AnswerID: 143885
Reply By: Play Rough - Tuesday, Dec 20, 2005 at 00:04
Sorry for slow reply... I (I should say my wife) purchaced a 12000lb winch 7 months ago from ebay for $800. So far i've used it a couple of times and it's been great. Last time was a 3m down to the axels skull drag and it worked a treat especially since the nearest useable tree was 40m away (used a winch extension strap to cover the last 15m. I left 5m on the drum). The only problem I had was fittting to the ARB bull bar on my Prado, The fair head was slightly bigger than the cut out and I had to rotate to clutch end to fit in the bar.
Ragards
Craig
AnswerID: 144620
Follow Up By: jfr - Tuesday, Dec 20, 2005 at 14:32
craig thanks for the info what do you mean by rotate the clutch end did this make it fit or did you cut the bar out also what brand was your winch
joe
FollowupID: 398238
