Landcruiser power steering
Submitted: Wednesday, Dec 14, 2005 at 18:39
ThreadID: 28870 Views:5886 Replies:3 FollowUps:3
Howdy, the power steering in my HJ75 is not up to scratch. The fluid is fine, the belt is in good condition and correctly tensioned and revs do not make a difference.
Tyres are 15 x 12.5, rims are 15 x 8.
It works sort of OK, but does not have enough grunt to turn the wheels when stationary. This makes low speed manouvering difficult.
Any ideas?
Reply By: Bros 1 - Wednesday, Dec 14, 2005 at 20:57
V8Diesel,
When the P/S stuffed up on my HJ75 (leaking fluid) i bought an aftermarket exchange one for roughly 60 oxfords 3 to 4 years ago now. My tyres are roughly the same as yours. Maybe yours is stuffed internally. Just a thought.
Bros.
Work is the curse of the down and out bludger.
AnswerID: 143897
Follow Up By: V8Diesel - Wednesday, Dec 14, 2005 at 23:47
What did you replace - the pump or the box?
FollowupID: 397406
Reply By: Bros 1 - Thursday, Dec 15, 2005 at 09:19
V8Diesel,
I replaced the pump unit that runs off the fan belt.
Bros.
AnswerID: 143970
Follow Up By: V8Diesel - Thursday, Dec 15, 2005 at 09:23
Thanks for that.
FollowupID: 397438
Reply By: Tom - Thursday, Dec 15, 2005 at 19:49
Currently going through this exact problem on my 60 series Cruiser.
Found last week that my car will only turn half a steering wheel rotation either way before the steering gets very hard. While moving it will turn further but with more effort required than previously.
Early in the week I fitted a new pump that fixed all problems, and I can now turn wheel lock to lock while sitting stationary and idling (I have 33" tyres on my Cruiser)
I say currently going through this problem because I had to return the pump and am waiting for a new one. Rather than fit a recoed Toyota pump, I have been recommended to fit an adapted Ford pump because parts are easier to get. The one I was given early in the week worked fine but had the wrong size spacers fitted that meant it put the pump at a angle to my water pump - new spacers are being put in and should be ready tomorrow.
Tom.
AnswerID: 144076
Follow Up By: V8Diesel - Thursday, Dec 15, 2005 at 20:01
Thanks Tom, that seals it. New pump it is!
My 75's been through 20 years of hell, can't complain really.
FollowupID: 397529
