HF static
Submitted: Saturday, Dec 17, 2005 at 08:06
ThreadID: 28936 Views:2773 Replies:7 FollowUps:9
I have installed a Codan 8528 with a auto tune aerial. So far I have only been getting static and very little voice transmission.
I have heard that the aerial has to be earthed which I have done but only to the wheel carrier, should it be direct to the body or chassis of the vehicle?
The unit works OK with the aerial showing that it has tuned and the signal does get stronger but more static. I have also tried it in the Vic High Country with the same results. I have also tried it at different times of the day and even left it on while driving.
Any ideas on how to fix the problem would be appreciated.
Wayne
Reply By: Member - Raymond - Saturday, Dec 17, 2005 at 08:49
Hi Wayne
Earthing of the Autotuner and the Radio is critical with HF. It would pay to run quite a heavy earth wire from the autotuner to the chassis. Also the Radio should be earthed from the earth screw on the back to the Chassis as well.
HF radio does have quite alot of static and it get worse depending on conditions.
Also remember the higher the sun the higher the frequency you should be using. Is the static the same on all on the VKS737 frequencies?
Have you called in to the Base stations during the skeds to see if they are coping you.
Does the static increase when you ahev the engine running or the fridge has switched on?
Have fun
Regards Ray V2010
AnswerID: 144238
Follow Up By: Wayne (NSW) - Saturday, Dec 17, 2005 at 09:53
Ray,
I have just re earthed the aerial and main unit and there is still static. The motor is not running and the fridge is off and there is 12.4 v in the battery.
Static is the same regardless if the motor is running or not.
Wayne
FollowupID: 397694
Follow Up By: Member- Rox (WA) - Saturday, Dec 17, 2005 at 11:52
Have you got your audio mute button pressed? this (on Barrett's) stops the static until an audible voice is heard. Then there is selcall mute but only press this if you don't want to be disturbed until some one selcalls you, this will be like the ring of a normal phone till you pres the talk button.
FollowupID: 397719
Follow Up By: Wayne (NSW) - Saturday, Dec 17, 2005 at 12:00
Rox,
I have pressed the two buttons and all is quite as you say, and it will come back when some talk/ static is heard.
I just went and tried to transmit and I noticed the red TX light does not come on when the mic is used, but the unit does go quite.
Wayne
FollowupID: 397720
Follow Up By: Member- Rox (WA) - Saturday, Dec 17, 2005 at 12:05
Are you a vks 737 member if so I can give you a call on ch 4 14xx not sure. Do you have a selcall no can also give you a call from the west.
FollowupID: 397721
Follow Up By: Wayne (NSW) - Saturday, Dec 17, 2005 at 12:08
Ray,
Romeo 4254 and I will go to ch 4
Wayne
FollowupID: 397722
Follow Up By: Member- Rox (WA) - Saturday, Dec 17, 2005 at 12:14
Just tried but no respones to voice & selcall W4279
FollowupID: 397723
Follow Up By: Wayne (NSW) - Saturday, Dec 17, 2005 at 12:18
Nothing heard this end. Might have to see a Codan specialist to see if they can get it to work.
Wayne
FollowupID: 397725
Follow Up By: Member- Rox (WA) - Saturday, Dec 17, 2005 at 12:25
Ok better do that. Mind you it is a fair distance. Listen out for the lunch time sked from the alice or evenings from Charters towers & newcastle (usualy on the side) or the Alice & St Marys base. Check you book for chanells Kevin
FollowupID: 397726
Reply By: Banjo 1 - Saturday, Dec 17, 2005 at 09:03
Wayne - manuals for such hardware always have detailed advice on installation - sounds like you may not have that paperwork - as Ray says, efficient earthing of all components is a must - you can't rely on the rear door hinges etc. Power supply issues are critical too - lot of power consumed when transmitting. Are you with an HF network ? You could arrange to comm with bases etc to give the unit a good test run.
AnswerID: 144243
Reply By: VK3CAT - Saturday, Dec 17, 2005 at 09:30
Hi Wayne.
RF earthing is very important. Earth direct to the chassis, a broad flat strap type cable is best - jumper lead type cable will also work. It is best if the top of the auto tune antenna is about level with the roof, this leaves the whip - which radiates the signal - in the clear.
Is the antenna the 9350? If so, this has a built in preamp that works well on receive only frequencies.
The radio should also have a good RF earth fitted to it.
Try also tuning into other HF services suck as short wave services and the like.
HF daytime conditions are not brilliant at the moment.
You should be able to hear amateur HF activity on 40 metres (7MHz) in the mornings and in particularly in the early evening - Try 7.050 to 7.100 LSB.
Short wave AM signals on 40 metres - 7.1MHz and above should be quite strong at night.
Also 80 metres (3.5MHz) after about 7.00pm.
Note that you will have to have the LSB crystal fitted to receive the LSB signals & the eprom must be programmed for LSB & USB (I think). So, this may not be an option for you?
At the onset of sunset (& also sunrise although that is quite early at the moment) you may be able to hear a peak in weak overseas stations working a path of propagation called the grey line.
On the onset of night time, longer distance propagation will occur. This is due to the breakdown of the ionospheric "D" layer - which is generated by the sun and which blocks frequencies below 10MHz. This allows propagation via the higher "F" layer.
If you wish a sked for testing etc, give me a call via email.
Just a note on transmitting. The output signal can be distorted (FMing) if the battery volts are low. This can be a problem if the fridge kicks in etc. Often best to turn the motor on.
vk3cat@qsl.net
Cheers Tony, VK3CAT
AnswerID: 144246
Follow Up By: Member - JD - Saturday, Dec 17, 2005 at 10:42
Hi VK3CAT,
Meery Xmas, nice to see a amateur giving good advice...a lot of the time the answer is under your nose...people overlook...just don't relise how important a "GOOD" earth is.VK3..vic l think any way doesn't matter..when lfirst started in radio l called myself an amateur l soon learned that this was full licence operator...so l started calling myself a novice...bychrist this was also another lic grade....I thought great....so from them on l called myself keen bum grade and no one complained.All the Best
FollowupID: 397706
Reply By: Peter 2 - Saturday, Dec 17, 2005 at 10:00
Wayne
I have installed dozens of HF's in 4wd's, several in my own troopies over the years.
If you don't have the Codan installation manual see if you can get one as it has several good tips.
My troopy was electrically virtually totally silent after I did the same to it as the police do to there vehicles fitted with HF's.
As has been said earthing of components is paramount, remove bolts holding bullbar, towbar etc, remove paint to shiny metal, fit grounding straps, then repaint/spray whatever to stop corrosion.
Even if the item such as a towbarisn't involved in the install it will still generate static electricity when driving down the road due to airflow if not well grounded to the rest of the vehicle.
Fit copper braid straps across ALL door hinges, bonnet and exhaust system, the latter at the rear, fit it around the rubber block at the back, again remove paint to ensure good connections.
Basic things to pay attention to as detailed in the manual are: don't run power cables alongside control cables (antenna and remote head) or antenna coax, I used to run power down one side of the vehicle and control cables down the other.
Preferably fit the HF to the main battery as when camped the aux battery is usually drained due to frig and lights and even a volt or so will affect antenna tuning efficiency. Even talking on the hf for several hours you won't drain the battery enough to affect starting. When the HF is just listening the battery drain is negligable.
Re the antenna, if you have the black parallel sided job start saving for a new one as they will fail, the most reliable were the earliest rough fibreglass ones, parts are virtually non existant for them these days. The later versions of the tapered antennas seem to be ok.
None of the auto antennas like being mounted beside a steel belted radial spare tyre, you have a coil of wire electically isolated from the vehicle which badly affects the antenna tuning and operation (reception and transmission)
On the troopy various things will cause interference, the biggest is the sender for the oil pressure gauge, soldering a 1.5uf capacitor between the centre terminal and the metal case should stop most of it, the fan motor and windscreen wiper motors both cause noise, some later models the dash instruments cause probs (probably the voltage regulator for the dash). The HF may also pick up the CPU in GPS's, laptops and anything else that has a chip in it, they have a very sensitive receiver. Fluoro lights will also play havoc with reception, not just yours but anyone elses nearby.
Your HF will probably interfere with other electrical appliances in the car too.
My UHF CB stops on certain channels when in scan if the HF is on.
Other vehicles may be affected by RF from your antenna if you transmit too. My favourite used to be a mates early V6 Pajero, we could be side by side at the lights, on the green he would start to pull away from the diesel troopy, I'd tune the antenna on 11 megs as he got level with the bullbar and antenna and his engine would miss, die, and nearly cut out, he'd get the bleep s as the troopy beat him to the punch!
When we had an incoming selcall we had a routine to turn everything off and pull over and stop the engine to minimise reception problems.
Also forget about using your HF if within close proximity to a TD5 landy, the noise from the electronic injection overloads the receiver!
Any questions give me a yell.
The 8528 is one of the best and simplest radios to have, very easy to use and very reliable, keep the sun and UV off the front panel on either transmitter or remote head as that is the weak point and there are no new spares available.
AnswerID: 144252
Reply By: Member - Raymond - Saturday, Dec 17, 2005 at 10:46
Hi Wayne
A silly question, but have you used HF before as the noise level on it compared to UHF is terrible.
Also I use a Barrett and have turned the Noise Blanker on (NB) which reduces some of the noise.
The fact that the engine is off and no fridge may mean that it is just the conditions at the moment on HF which are terrible.
Is the noise level different on each of the VKS channels
Regards Ray
VK3CRK V2010
AnswerID: 144256
Reply By: Member- Rox (WA) - Saturday, Dec 17, 2005 at 11:59
Another tip male sure that your earth is SOLDERED.
AnswerID: 144273
Reply By: geocacher (djcache) - Saturday, Dec 17, 2005 at 20:00
Hi Wayne,
Lots of good advice here. I've had about 5 codans over past years and those included an 8528. They are a good rig.
Don't worry about the TX light. It shouldn't come on when you push PTT.
In a way it is a transmitted signal strength indicator. Because you are operating on a side band it doesn't light until audio is transmitted and then it will flicker with the strength of the audio.
If you transmit and talk does it light? The level will vary with voice volume.
It will also flicker with the tune operation.
The antenna relies on a transmission to tune as it is seeking best VSWR. If the radio wasn't transmitting at all it wouldn't tune.
Do you know anyone else you can have a listen to their set. Static is normal and on some days the conditions will give you heaps of it and others it will be quiet as a mouse.
Built up areas are worse for HF noise also.
An old hands tip. When conditions are bad and received audio is well down in the static turn the volume down low and get your good ear close to the speaker. Audio pulls through the static better at low volumes. That's why my speaker is mounted up above the door frame above the rear door drivers side.
Earth, earth, earth is important too. Follow some of the previous posts tips. My 8558 wouldn't tune reliably until I bared the metal under it's seating ring around the mounting bolt. These days I have an NGT & 9350 but the same rules still apply even though I have the advantage of being able to turn noise filters on that weren't in the earlier sets.
My 8528 served me well from the high country for quite a while. I'm sure yours will too.
The Codan_outback_radio group on yahoo groups is worth joining too. Plenty of this sort of stuff in their archives.
AnswerID: 144323
