Bridge
Submitted: Saturday, Dec 17, 2005 at 22:27
ThreadID: 28952 Views:5504 Replies:10 FollowUps:3
Hi, Anyone know where I could aquire a Bailey bridge about 11m long (metres not miles)
Harry
Reply By: Member - John - Saturday, Dec 17, 2005 at 22:33
Aussis Disposals???????
John and Jan
AnswerID: 144341
Reply By: Mike - Saturday, Dec 17, 2005 at 23:07
That's a whole heap of steel. Good luck with your search and putting it together.
Happy trails, Mike.
AnswerID: 144343
Reply By: geocacher (djcache) - Saturday, Dec 17, 2005 at 23:50
Dunno what you want it for but to bridge the river on our farm a few years ago we used the base of a railway carriage that had been bought by a nearby caravan park to convert to a cabin.
Some little feral set fire to it and the upper part was destroyed leaving only the base. Lifted into place on some concrete blocks set into either bank it made a great bridge and would have gone close to the length you want.
I'd say an old railway carriage would be cheaper & easier to come by than a bailey bridge. Might be cheaper and you need to be able to get a crane in there to lift it into place.
AnswerID: 144348
Follow Up By: Bob Y. - Qld - Sunday, Dec 18, 2005 at 13:06
There was some flat top wagons for sale, minus the bogies, some years back. Can't remeber whether they were advertised in Qld country Life, or in Deals on Wheels magazine.
Agree with Dave, they would be ideal. We have some bridges here, that are made out of railway line, and steel sleepers. Ccould send you some photos if you like, but they wouldn't be cheap to fabricate.
What weight would the structure need to carry, and how deep is the channel?
Hooroo...
FollowupID: 397891
Reply By: Kiwi Kia - Sunday, Dec 18, 2005 at 07:35
Railway carriage ! Great idea. I am sure you could even get the design safe loading figures as well for peace of mind.
AnswerID: 144357
Reply By: Member - Leith H (NSW) - Sunday, Dec 18, 2005 at 08:55
You could try the Roads and Traffic Authority in NSW, their bridge crews still use bailey bridges while carrying out maintenance on the timber bridge's. They could have some old stock??
AnswerID: 144361
Follow Up By: Harry - Sunday, Dec 18, 2005 at 20:23
Great stuff guys, I'll follow up on the flat top idea (weight)and thanks Leith, that's a good lead as well.
The creek is about 10' deep but is dry most of the year and wouldn't lend itself to getting a crane in, too much sloping ground around.
That would be the problem with a stucture such as a flat top to be able to get it in, that's why the Bailey bridge enquiry.
Should be able to lift things around with a Jimmee pole, and winch.
Amazing what can come off this forum aye.
FollowupID: 397930
Reply By: hoyks - Sunday, Dec 18, 2005 at 20:43
Have a look in The Land news paper. They have adverts in the classified sections for bridges or bridging materials at times. You could also use the old bunch of logs across the gap then build a deck on top.
Installing a temporary bridge isn’t exactly an easy job. Last time I did one was with the modern equivilent of a baley bridge that is made out of Aluminium. It took 20 blokes going for about 4 hours and the aid of a Unimog to ‘launch’ it across a 20m gap.
There are ways it can be done, but none of them are easy.
AnswerID: 144427
Follow Up By: hoyks - Sunday, Dec 18, 2005 at 21:23
Knocking up something like these might be the way to go. Trees if you have them and they are solid enough or a few I beams across the gap and build the deck on top of that.
http://www.outdoorstructures.com.au/pdf/vehicle_bridges.pdf
http://www.modularbridges.com/
FollowupID: 397941
Reply By: jackablue - Sunday, Dec 18, 2005 at 20:53
Might be more than you need.
link text
AnswerID: 144430
Reply By: Alan S (WA) - Monday, Dec 19, 2005 at 11:18
We used an old Semi Trailer tray on my Mother in laws farm. Just put in suitable foundations each side. 12mt bridge only cost about $2000.
Admittedly was restricted in weight capacity, i thnk from memory about 5 tn max.
AnswerID: 144490
Reply By: Eric Experience. - Monday, Dec 19, 2005 at 21:21
Harry.
A 40 ft shipping container up side down makes a cheep bridge. They slide fairly easily when upside down. they weigh about 5 ton but can support a lot more.
Eric
AnswerID: 144586
Reply By: Harry - Monday, Dec 19, 2005 at 21:57
Ah it's getting better, lots of suggestions and I'm writing them all down.
John---
Aussie doesn't have any Bailey's
Alan---
Semi top sounds good, but need to take at least 8ton.
Eric---
Shipping container, well it would be impressive to say the least, but a little impractical for the situation, thanks all the same.
Hoyks---
The logs are our first way to go, but finding ones long enough will be a
c h a ll en ge. We still might have to go that way anyway if we can't find a Bailey or modular bridge of sorts. Now that newspaper your talking about, The Land, where is that publication from?
Keep em coming fellas I'm all ears. :>)
AnswerID: 144599
