Treg or Hyland hitch
Submitted: Sunday, Dec 18, 2005 at 20:41
Member - uncle
Hi all,which is the most favoured? About to get a new CT soon and just after some feed back thanks,merry Xmas.
Reply By: Banjo 1 - Sunday, Dec 18, 2005 at 20:49
Can only say that Treg is very robust, highly functional and reliable long term - the most widely used in articulated hitches it seems - never heard a bad or even cautionary word about them. Had a Trigg once - that seemed very good too.
Others may comment on Hyland.
144429
Reply By: Member - Nick (TAS) - Sunday, Dec 18, 2005 at 21:05
We got a Treg and find it very good.Some say they are hard to hook up on uneven ground but so far its been as easy as a normal coupling.
144431
Reply By: rolande- Sunday, Dec 18, 2005 at 21:35
G'Day,
If like me you have more than one trailer which needs to be moved regularly, anything to make the process easier and quicker is much appreciated.
In my case the hyland would be the only answer. The others may perform better in extreme situations however the need to swap couplings on the tow bar is a major P.I.T.A
I leave the same towball / coupling on for all my trailers
Hope this helps
Rolande
144434
Reply By: Truckster (Vic) - Sunday, Dec 18, 2005 at 21:37
Another thing to think of, Tregs are harder to steal... Hylands use a normal towball.
YMMV
144436
Reply By: Member - uncle - Sunday, Dec 18, 2005 at 21:50
Hi guys ,thanks for the replys,we only have the one trailer to tow which will be the CT,however later on we may buy a small tinnie as
well.The CT comes standard with the Treg,so suppose we'll go with that one.Cheers and many thanks for the input.
144437
Reply By: HJ60-2H - Sunday, Dec 18, 2005 at 22:11
Only negative with the Treg is if the pin bends. Hacksaw and a spare pin and you are prepared for that.
144440
Follow Up By: Member - JohnR (Vic)&Moses - Sunday, Dec 18, 2005 at 22:37
Reckon the hand may be saw from trying to get through the hardened steel of the pin. Try angle grinder if you really need to remove it.
397966
Follow Up By: HJ60-2H - Monday, Dec 19, 2005 at 19:40
I was thinking of what would be pratical to carry for a bush repair. To the hacksaw I would add a nice hammer and a cold chisel (that I carry anyway)
398129
Reply By: Member - Kingsley N (SA) - Sunday, Dec 18, 2005 at 22:47
We have the TREG on our Coromal. It is a pain in the A when trying to hook up on any sort of slope. If you can't wriggle the trailer to get the holes to line up it is very frustrating. A good squirt of WD40 helps but makes it a messy business. The Coromal weighs in at over 1200KG loaded so it is a bit tricky to manouever. A lighter CT would be less of a problem.
The problem with my Nissan is that when the handbrake is applied on a slope it always moves a bit when you take your foot off the brake. So your best effort at reversing is always going to be wrong. It then becomes a trade off involving releasing the brake on the trailer and positioning the vehicle. My wife does a great job with hand signals for guidance, but it can be frustrating. Invariably I have to get out of the vehicle and haul on the A-frame so she can drop the pin in. It is much easier on level ground. Our most difficult moments have been in caravan parks where there is a shallow gutter that just happens to coincide with the rear
wheels of the Nissan, creating a potential for movement.
Once hitched of course, it is great. The trailer just sits there and tracks true come hell or high
water.
Creek crossings are made with confidence. The articulation is great. No rattles or clunks when on the move; it is very solid.
I have seen the other type of Off Road ball, presumably the Hyland and I must say that it does not look to be as strong as the TREG.
Kings.
144447
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Dec 18, 2005 at 23:00
I'll second all that .
Mine is parked on a slope with a wheel stop.
It is very hard to line it up and get it on and off . My wife will not help me anymore 'cause I've had a few dummy spits !
Willie .
397970
Follow Up By: Alloy c/t - Monday, Dec 19, 2005 at 20:12
Easier to take square bar out of Hayman than to line up treg , once lined up roll back to pinup.
398132
