calling Crazie - pics of milford installation??
Submitted: Monday, Dec 19, 2005 at 16:06
ThreadID: 28992 Views:2079 Replies:5 FollowUps:7
Adam, I'm sure I've seen pics of your installation of a Milford Cargo Barrier in your Jack (showing the attachment of brackets), but now I can't find them (here or on the jackaroo.australia4wd website). I've checked the archives and found your installation comments (post id 27417), but no pics. Could you please tell me where I can find them? I'm interested in how you've attached the barrier and where it sits relative to the rear seats, since I'm also looking at a Milford. Thanks.
Rob.
Reply By: Member - 'Lucy' - Monday, Dec 19, 2005 at 16:24
Post 27417
AnswerID: 144539
Follow Up By: Robbg - Monday, Dec 19, 2005 at 16:45
Thanks Lucy, but are there supposed to be pics in Adam's original post (or in a followup)? If so, I can't find them.
Rob.
FollowupID: 398087
Follow Up By: Bonz (Vic) - Monday, Dec 19, 2005 at 17:26
Robb, I mounted mine on a GU by utilising the existing rear seat mounts and fabricating brackets that I welded to the milford. The actual barrier is from a XF Falcon wagon/Panel Van and fits exactly.
FollowupID: 398098
Reply By: jackablue - Monday, Dec 19, 2005 at 21:06
You may have seen mine Robbg
link text
Jackablue
AnswerID: 144582
Follow Up By: Robbg - Monday, Dec 19, 2005 at 21:19
Thanks Jacka, but those aren't the pics I was after. I remember Adam's pics because I recall he'd connected the top of his barrier to the third row hand grip bracket, whereas yours is the connection that goes up under the trim near the top of the rear side window. By the way, that was a lot of work just to fix a rattle - did it work?
Rob.
FollowupID: 398142
Follow Up By: Member - Tony G (ACT) - Tuesday, Dec 20, 2005 at 08:17
Robbg, I don't have a photo, but that is where I mounted the top bracket of my barrier. I used longer bolts and the front hole of the hand grip.
FollowupID: 398181
Follow Up By: Robbg - Tuesday, Dec 20, 2005 at 10:59
Thanks Tony, sounds like this should work OK for me too.
Rob.
FollowupID: 398211
Reply By: Member - Crazie (VIC) - Tuesday, Dec 20, 2005 at 13:51
Hi Rob
Sorry have had a few days off the computer. I will find them mate
Ads
AnswerID: 144705
Reply By: Member - Crazie (VIC) - Tuesday, Dec 20, 2005 at 13:59
Hi Rob
Just had a quick look. They are on the home computer. I will post them when i get home
Ads
AnswerID: 144707
Reply By: Member - Crazie (VIC) - Tuesday, Dec 20, 2005 at 21:25
Hi Rob
I have added them to my gallery
Ads pics
Ads
AnswerID: 144767
Follow Up By: Robbg - Tuesday, Dec 20, 2005 at 22:40
Brilliant Adam, they're the ones I was after - now I have a good idea of where the top of your barrier sits relative to the C pillar. Did you drill new holes in the jack for the bottom mount? Thanks.
Rob.
FollowupID: 398313
Follow Up By: Member - Crazie (VIC) - Wednesday, Dec 21, 2005 at 08:33
Hi Rob
No Mate all holes I used were exsisting ones. I used M8 bolts into the floor, there should be a threaded hole available on each side.
This is not Milfords recommended way to fit. This suited me.
Ads
FollowupID: 398357
