Jeep CHEROKEE recovery points
Submitted: Monday, Dec 19, 2005 at 20:14
ThreadID: 29002 Views:6810 Replies:5 FollowUps:0
Hi All,
Does anyone know if a jeep cherokee has any factory fitted RATED recovery points - front or rear??
Reason...a friend just bought a new one and want to come away with us!
no tow bar .... stock standard 3.7L V6
Reply By: Member - Omaroo (NSW) - Monday, Dec 19, 2005 at 20:18
Ozman - head on over to
http:www.ausjeepoffroad.com/forum
and ask there. It's a dedicated Jeep website, so you'll get a targetted response. Go to the "Cherokee Forum".
Cheers :)
Chris
AnswerID: 144570
Reply By: glenno(qld) - Monday, Dec 19, 2005 at 20:26
I pulled out a late model jeep grand cherokee out of soft sand at fraser . It was bogged down to the door sills . I remember putting a shackle thru an eye at the front which wasnt rated . Attached the snatch strap and drove off in low range second . Didnt pull the front end off but i would advise to put a rated shackel front and rear .
AnswerID: 144572
Reply By: desert - Monday, Dec 19, 2005 at 21:36
So what does a rated shackle protect you from? What's the point if the factory won't tell you the load rating on the recovery point? And what if they did insist you only use a 3,25t shackle on their 3.25t recovery point, how are you going to measure that as you pull away with the snatch-em doing what it wants to do?
Bollocks!
AnswerID: 144590
Reply By: Kiwi Kia - Tuesday, Dec 20, 2005 at 07:22
What 'someone else' has done does not make it safe! Tie down points are not recovery points. Good on you for asking the right question, shows that you at least are thinking safety. Please let us know what you manage to find out as this type of question is often asked but seldom answered.
AnswerID: 144633
Reply By: Member - Oldplodder (QLD) - Tuesday, Dec 20, 2005 at 08:46
Good question.
Would be good to know just in case I need to recover a jeep, or a jeep pull me out.
Let us know.
AnswerID: 144651
