Landcruiser gearbox oil - cold shift improvement
Submitted: Thursday, Dec 22, 2005 at 15:27
V8Diesel
Hi, I have a Landcruiser 105 with the H151 5 speed manual and it a bit stiff on the changes in the mornings for the first few km's.
I'm giving it service over Xmas and was wondering if anyone knew of a suitable gearbox oil that would improve its cold shifting characteristics?
Ideally something easy to obtain would be better.
Reply By: tour boy - Thursday, Dec 22, 2005 at 16:22
Hi, I always use Castrol VMX80 this makes the cold running great and also quietens the box.
Regards Tour Boy
145105
Follow Up By: Member - Nick (TAS) - Thursday, Dec 22, 2005 at 23:13
VMX80 worked great in my 4 Runners box,will be be adding it to the Cruisers box as soon as I get some more.
398703
Reply By: Turbo Diesel - Thursday, Dec 22, 2005 at 17:35
Any good gearbox/diff oil will be ok in reason, i add some NulonG70 (I thinkk thats what it is called) to the box when changing the oil helps heaps. Buy it at repco or Supercheap auto.
145119
Follow Up By: WheelTravel - Thursday, Dec 22, 2005 at 17:50
I too have heard Nulon is a goer, added to diffs, gearboxes tranniy cases etc.
398621
Reply By: Member - Paul P (Bris) - Thursday, Dec 22, 2005 at 17:36
G'day
A suitable full synthetic gearbox oil will do wonders for the cold shifting particularly second gear. I would also suggest full synthetics in the transfer case as
Paul
145120
Reply By: 100TD - Thursday, Dec 22, 2005 at 17:38
as much as i hate saying this penrite lite oil works a treat in tojo boxes and transfers (i think they call it some thing else now but look on back of pack and it says replaces lite oil) even fixed a bleep ty shifting VW golf and i think thats saying something!
145121
Reply By: Patroleum - Thursday, Dec 22, 2005 at 20:00
V8 Diesel
Go with Synforce All Terrain 80. It was developed for the poor cold shift 4wd box.
Use it in my 80 series box - should be same as yours, made a great difference to
mine. Was a pig to shift 1st - 2nd cold - now greatly improved.
Look up Synforce on the net, they're factory is in Hervey Bay QLD, they have distributers everywhere.
145136
Reply By: Sarg - Thursday, Dec 22, 2005 at 20:07
Valvoline Dura Gear HD synthetic 75W90 . Use in both gearbox & transfere case. Yes, it is expensive but the results are worth it.
145140
Follow Up By: craig - Friday, Dec 23, 2005 at 01:00
Yup, thats the stuff. Fixed the cold shifting in my Landcruiser.
398717
Reply By: 120scruiser - Thursday, Dec 22, 2005 at 20:39
The correct fluid in which Toyota use is
Mobil Fluid 424.
The equivalent in
Caltex is Textran.
You need to use a gear oil which isn't an EP (Extreme Pressure) oil. This is what makes them hard to shift.
Put this in the gearbox and normal 75w/90 in the Transfer Case and you will be very happy with the shifting.
Hope this helps
120scruiser
145149
Follow Up By: 120scruiser - Thursday, Dec 22, 2005 at 20:41
I forgot to add that I wouldn't use a Synthetic oil as I think it is a bit too good for gearbox's.
I have had experiences with it glazing up synchro rings but by the sounds of it many have had good experience with it.
398657
Reply By: jon p qld - Thursday, Dec 22, 2005 at 20:42
G'day V8Diesel
Seems like everyone's got their favorite oil, I'll add my two cents worth as
Mobil 424 changed my gearbox from being stiff and notchy into a very smooth changing gearbox, I would highly recomend it.
Regards Jon
145151
