Salt water ratio for mud crab cooking
Submitted: Monday, Dec 26, 2005 at 14:15
Austravel
What ratio of salt do you add for cooking your mud crabs? Yep
water straight from the sea is best but I've cooked at home many times and just added what I thought. Usually depends on who's helping and how many drinks I've had, only to help pass the time of course, as to how much salt is added.
So what's the best????
Reply By: Flesh - Monday, Dec 26, 2005 at 14:30
You need to add at least 1 cup of salt.
If you have a gas burner - bring
water to a hard rolling boil, drop the crab in (make sure that it is dead so that it dosen't throw the claws). Bring back to a hard rolling boil for a few minutes then turn off heat. Leave in hot
water for another 15 - 20 minutes. Remove from
water and cool in fresh cold
water (crab will continue to
cook if not cooled).
On electric hot plate - boil for 15 - 20 minutes then cool as above.
Enjoy.
145602
Follow Up By: Member - Poppy (QLD) - Monday, Dec 26, 2005 at 14:51
Have you tried steaming them?
Just add sugar to fresh
water and steam for 20 minutes... yummeee
Can taste them now,actually heading up
Hinchinbrook Channel tomorrow for a couple of days, might just throw in a couple of pots
Cheers Poppy
399137
Follow Up By: Member - Brian (WA) - Monday, Dec 26, 2005 at 14:58
Hi A handful of salt and I drop then iced
water after cooking
Then get into them. enjoy
399138
Follow Up By: Flesh - Monday, Dec 26, 2005 at 14:59
No Poppy I haven't but that method sounds good. Will give it a go - just gotta get a legal buck.
Good luck with the crabbing.
399139
Follow Up By: Member - Brian (WA) - Monday, Dec 26, 2005 at 15:08
Or you can clean first them and do chilli or garlic crabs on the b-b-q
all mouth watering. That reminds me I have not been this season yet
399140
Follow Up By: Austravel - Sunday, Jan 01, 2006 at 13:27
Thanks all. Yep I usually clean them first as
well, I think they taste better this way but it's an individual preference. the 35g per litre of
water is what I was after.
399743
Reply By: Member - Brian (WA) - Monday, Dec 26, 2005 at 15:13
Just been reading my replys. Must have drank to much already
145604
Reply By: Original Banjo (SA) - Monday, Dec 26, 2005 at 15:27
It has been alleged by someone here in these southern areas that the northern mud crabs MAY be nearly as good as our local blue swimmers - probably not but :-0) ! Anyway, the sea
water is great for cooking of course, and various government sites say that the sea
water all over the planet is close enough to 35ppm salt. Ergo, 35g of salt to 965ml of
water (by my quick calcs).
145605
Follow Up By: The Explorer - Monday, Dec 26, 2005 at 18:26
Actually The salinity of seawater is about 35 parts per THOUSAND in most marine areas...not parts per million.
399145
Reply By: Flesh - Monday, Dec 26, 2005 at 15:37
Here's what the NT Fisheries has to say:-
"Cooking Mud Crabs
Mud crabs are often boiled whole and they should be killed beforehand by chilling or piercing their central underside. Steaming them is also a popular cooking method and they should be cleaned and have their claws cracked beforehand to allow steam to penetrate and make them easier to eat. Crabs that are to be boiled should not have their claws cracked as this allows
water to be absorbed into the flesh.
Whether steamed or boiled, mud crabs should be placed in a cooking pot once the
water is boiling. This will usually stop the
water boiling for a few minutes. Once the
water is brought back to boiling point, mud crabs should be cooked for ten to twelve minutes then allowed to cool before being eaten."
N.T. Fisheries on cooking mud crabs
145606
Reply By: Nudenut - Monday, Dec 26, 2005 at 19:12
i'm digging into a CRAYFISH at this very moment
you can stick to your crabs that taste like mud!
145625
Reply By: The Rambler( W.A.) - Tuesday, Dec 27, 2005 at 22:52
Just another tip with mud crabs---Clean them(remove shell etc.) BEFORE cooking regardless of steaming, boiling, or whatever as you end up with crabs that you do not have to remove the sh-----t and you use a lot less
water and smaller pot.Have introduced this to many campers and most will go this way everytime.
145750
Reply By: Member - David 0- Thursday, Dec 29, 2005 at 22:25
Just use the
water you caught them in :-)
Seriously 30 -35 ppt is the trick.
Thats very roughly about 6 really heaped teaspoons per litre of
water.
145953
Follow Up By: pojo - Wednesday, Jan 04, 2006 at 20:25
I have found that a goood spoonful off brown sugar in the
water is the best way to bring out the flavour in the crabs
399946
