V8 Landcruiser Exhaust
Submitted: Tuesday, Dec 27, 2005 at 23:13
ThreadID: 29202 Views:16278 Replies:4 FollowUps:2
Hi there,
I am interested in improving my 100 series V8 cruisers low end, fuel consumption and exhaust note and was wondering if there is anyone who may have done some mods to the std exhaust.
Any suggestions?
Steve
Reply By: Exploder - Wednesday, Dec 28, 2005 at 00:02
Depending on what you want to do, like just mod the stock exhaust buy removing the factory mufflers and replacing with a single straight thru muffler (Loud) or a cross-flow (Still has a exhaust note but will not attract the cop’s as much).
Or replace the whole system> Twin 2 ½ inch pipes from manifold running HY-flow cat’s and a single Straight thru Muffler per pipe, with tuned length Extractors (Optional)
Then you have to decide on Stainless steel or mild steel pipe
Stainless will cost a lot but last forever
Mild is a lot cheaper but will rust out over time.
Muffler’s I would go Lukey or Magnaflow, The Magna flow are form the U.S and have a nice note but are more expensive than the Lukey but the lukey’s are also good.
AnswerID: 145756
Reply By: Sarg - Wednesday, Dec 28, 2005 at 11:50
Try here for starters
http://www.dtperformance.com.au/v8cruise.htm
AnswerID: 145781
Reply By: Member - DOZER- Wednesday, Dec 28, 2005 at 17:52
Gday
Keep the system std and put extracters on the motor....the exhaust manifolds look like they are from a grey motor ( fe holden motor) and are very restrictive for a 4.7 litre v8
AnswerID: 145802
Reply By: Member Steve & Lorraine Mc - Wednesday, Dec 28, 2005 at 18:01
Hi Fozbear
Give Beaudesert Exhausts QLD a ring , when they were fitting my exhaust we got talking, and in the conversation a system for a LC 100 V8 had just been made, 30-40% improvement performance, fuel cant remember. It was mentioned that the STD Exhaust manilfolds looked like they belonged on a aeroplane motor , bad air flow etc,etc, They fit them by going in behind the IFS thru the mudguard.
As for quality we haven;t had a problem or one rattle on our 4.2 Patrol not very noisy either. They send their exhausts anywhere so you might get someone else to fit it.
Hope this helps
Cheers Steve
AnswerID: 145803
Follow Up By: David from Engine Saver Low Water Alarms - Wednesday, Dec 28, 2005 at 19:45
A 30 to 40% improvement in either performance or economy sounds VERY GOOD.
If it is true someone should patent this system immediately.
Regards David
FollowupID: 399302
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Dec 28, 2005 at 21:27
I have a heavy vehicle and a considerable improvement just this week from a Beaudesert system - as measured on acceleration 0 -> 100 kph which is good even at my level of 16%. The only difficulty was the OE nuts and bolts round the dump pipe. Every clamp and bracket fits to the cm. Its quiet too for my aging ears. Believe the muffler is straight through but the engine was hardly noisy with no muffler.
FollowupID: 399312
