two batteries in the camper trailer
Submitted: Wednesday, Dec 28, 2005 at 20:39
ThreadID: 29221 Views:3561 Replies:6 FollowUps:5
I have decided to put two batteries in the camper trailer. Batteries are/will be powered from the vehicle via a parrallelled cable from the vehicle's auxillary (75 ah) when driving. Simple solenoid isolator in the vehicle.
I have one 120 ah that predominantly runs the fridge. I want to add a second battery to the c/t so that the fridge has a dedicated battery. Is there a good way to ensure that the fridge battery gets most of the charging but still ensures the second battery is not left high and dry.
I thought of a basic solenoid however with a fridge running I am not sure the second battery would ever get any current (or will it)
Any thoughts appreciated.
Spade Newsom
Reply By: Member - Roachie (SA) - Wednesday, Dec 28, 2005 at 21:37
G'day Spade,
Only my personal opinion, but I think you're buying more trouble than you need. I'd be inclined to fit a 2nd battery the same as the one you already have (space permitting of course) and wire them in parrallel too. I would imagine the fridge is the biggest/most constant draw you would have on the battery/ies and the other things would mainly be intermittent type uses such as flouro lights and maybe a water pump, possibly a radio/stereo system.
I have done this in my camper trailer and it works well.....no need for a separate battery for lights, radio, pump.....the 2 SuperCharge Gold 105 a/h batteries handle everything just nicely. I have a similar set-up on the Patrol to what you've described, with a simple solenoid (which I control via a switch). My 2nd battery now resides in the cargo area of the Patrol (but that is of no consequence for what we're discussing here).
If you MUST fit a battery of a different capacity in the trailer as a back-up, I would venture to say (just my opinion) that you would be best advised to have a separate solenoid mounted in the vehicle, with separate cabling from truck to trailer; keeping the whole extra trailer battery totally isolated from the fridge battery.
Roachie
AnswerID: 145816
Reply By: ferris - Thursday, Dec 29, 2005 at 09:18
G'day Spade. I think Roachie's hit the nail on the head. As I understand it, (and I'm no expert) different types/sizes of batteries will cause problems. There's a wealth of info out there on this topic if you check through the archives and also on google. The general consensus is, if possible put one big battery in that will handle the whole job, and if that's not possible two or more matched batteries, wired in parrallel. For camp trailers agm batteries are IMHO the only way to go, even though they cost a lot more. They are totally sealed, can be mounted on their sides, or in any position, wont leak or gas and accept charge a lot quicker than a conventional lead acid battery. As for a solenoid, there are plenty of different types out there. Have a look at the Redarc voltage sensitve one. It doesn't connect until the car is producing 13.6 volts, which means your car battery will get first go at the charge, and then it will charge the CT battery. It disconnects when the voltage drops back to 12.6.
Whatever battery you end up going for, make sure you get sufficient capacity, so you are not discharging below 50% to ensure good battery life. Also if you go with the agm's, don't hook them up to a conventional $50 battery charger - a good way to kill the battery. The agm's are far more voltage sensitive than a lead acid battery and need a good three stage charger. That's my two bobs worth. Ferris.
AnswerID: 145859
Reply By: phil - Thursday, Dec 29, 2005 at 14:55
Spade,
The most important thing with a remote battery is to make sure that it actually gets a full charge. Usually the voltage drop in even large cables means that the charge current is quite limited meaning that the battery takes a very long time to charge from the vehicle. Long term undercharging is very detrimental to your expensive batteries. Putting 2 batteries in just makes it worse.
One solution is to use something like the Arrid Twin Charge
http://www.allabout12volt.net.au/indexcat.html
which provides up to 20 amp charge, correctly regulated, even if there is voltage drop in the supply or a load on the battery. Not cheap, but neither are good batteries.
Phil I
AnswerID: 145881
Reply By: Member - Norm C (QLD) - Thursday, Dec 29, 2005 at 16:19
Some good advice here already Spade. In my view keep it simple. Don't think you need a separate battery for the fridge. I agree with Ferris. AGMs are ideal for the CT. I've got two 120AH AGMs in parrallel in the CT and they are brilliant. They charge via a standard solenoid and very thick double insulated welding cable. Measured voltage drop (without load) is 0.1V. They charge quickly and hold their charge well (ie don't need to be on trickle charge). The two identical batteries act like one big one. I also have a 105 AH DC in the 4B.
I carry a 25 Amp 3 stage charger to use if I have access to 240V or with my 1KVA gennie, but rarely use either. I get 5 or 6 days at least, running fridge (70 litre dual temp Reefer), heaps of lights, radio etc without driving or charging. With a bit of daily running around (which tops up the vehicle DC) I can get a week or more without suplementary charging.
For cheaper AGMs some of the Chinese ones are pretty good. I've got Fullriver and can not fault them.
AnswerID: 145905
Reply By: Mike DiD - Thursday, Dec 29, 2005 at 18:16
There is no point putting in 240 amphours of battery if you can't recharge within a day - if you don't recharge them promptly, they will Sulphate and not last long. If you are just going away for weekends and will charge them with a 25 amp charger when you get home - fine.
If you plan to charge them from the car you will need to run a MINIMUM of two 4 gauge wires from the main battery to the Trailer batteries to keep down voltage drop. An ARRID Twincharge will help - at $300. You will need to drive for for up to 8 hours to charge up the batteries (dpending on Alternator Capacity and other loads).
Paralleling batteries of different size does not cause a problem.
Paralleling batteries of different chemistry does cause problems - but nomore than putting in one battery of the wrong chemistry e.g. if you put in a Calcium Calcium Maintenance free battery but your Alternator is designed for Calcium-Lead batteries then the Calcium Calcium will charge slowly - whether it is the only battery or in parallel with another battery.
Mike
- Licenced Electrical Contractor
- Degree in Electronics Engineering
AnswerID: 145914
Follow Up By: Member - Norm C (QLD) - Thursday, Dec 29, 2005 at 18:53
Mike, can you explain this bit a bit better for me please:
'There is no point putting in 240 amphours of battery if you can't recharge within a day'.
By that, do you mean you should recharge within a day of use, meaning you should recharge batteries just about every day? Or after running them down to (say) 11.5V, you should recharge them within a day or so?
Or something else entirely?
I try to recharge as early as possible after I get below 12V (as measured by voltmeter built into my fridge controller), but sometimes get down to 11.5V or so. Never leave them in this state for more than a few hours with applying charge. Does this meet you stated 'rule'.
FollowupID: 399413
Follow Up By: Mike DiD - Thursday, Dec 29, 2005 at 20:34
Whenever a Lead-Acid battery is at less than full charge the Lead/lead oxide is converted to Lead sulphate. The longer this lead sulphate remains the harder it will get.
"Being able to charge your batteries in 24 hours" is not a rule - it is a guide.
Perhaps a more sensible rule is - for long battery life, your daily usage must not exceed your daily charging capacity.
If you have 100 amphour a day charging ability (e.g. solar ) and you use 150 amphours a day there is no point buying more batteries - you will just have more batteries sulphating.
But the detail really depends on what your charging arrangements are.
Mike
FollowupID: 399418
Reply By: Spade Newsom - Thursday, Dec 29, 2005 at 18:53
Thanks all for some good responses here. If I could indulge further I would appreciate some further replies. I have searched archives however could not find specific answers to what I want to do.
1. I have a fullriver 120ah and am looking for another the same, as the existing 120ah will not last a full week in many conditions.
2. I have a good 3 stage charger (CTEK Multi XS7000)
3. The 75ah auxillary battery in the vehicle is a flooded deep cycle. There is no danger of flattening the starter battery as it is isolated with a simple solenoid (nothing fancy). There is little room in the Pajero and the battery was the best fit.
4. I have a parrallel cable to the trailer (will check the guage) connected straight to the existing c/t battery.
I am convinced that I should simply parrallel the two c/t batteries that will be the same size and type (thanks comments above). So what I am really after now is advice on what is the most efficient way of getting the vehicles alternator to charge the c/t batteries given what I have.
1. Is it necessary/wise to isolate the vehicle auxillary from the c/t batteries.
2. If I use an isolator/solenoid does it need to be mounted near the vehicle auxillary or can it be mounted in the c/t. (If I mount an isolator in the c/t the connecting socket on the vehicle can be used as a power source)
I have also been working (rightly or wrongly) on the theory that if the c/t battery is at the correct distance from the vehicle alternator (spitting out current at say 14.5volts) the voltage drop of approx 1 volt will see an ideal voltage to charge the AGM battery in the c/t. I am sure I read this on this forum somewhere.
Thanks all for your assistance here.
Spade Newsom
AnswerID: 145920
Follow Up By: Mike DiD - Thursday, Dec 29, 2005 at 20:47
"1. Is it necessary/wise to isolate the vehicle auxillary from the c/t batteries. "
- isit important to have the front auxilairy charged before the CT batteries ? If not, just parallel all three Aux batteries.
"2. If I use an isolator/solenoid does it need to be mounted near the vehicle auxillary or can it be mounted in the c/t. (If I mount an isolator in the c/t the connecting socket on the vehicle can be used as a power source) "
- it can be at either end.
- you MUST have fuses or Circuit Breakers with an Interuppting Current capability of 3000 amps (short-circuit current of the batteries) located at BOTH ends of the cable. The small in-line Circuit Breakers will weld shut with the high battery current until the cable melts and opens.
"I have also been working (rightly or wrongly) on the theory that if the c/t battery is at the correct distance from the vehicle alternator (spitting out current at say 14.5volts) the voltage drop of approx 1 volt will see an ideal voltage to charge the AGM battery in the c/t. "
- AGM batteries will charge fully at 13.8volts, just more slowly - my Remco 80 amphour AGM charged from empty at 13.8 volts (I will have to check how long it took- about 24 hours ?)
How long will you be driving after discharging the batteries ?
Mike
FollowupID: 399421
Follow Up By: Spade Newsom - Friday, Dec 30, 2005 at 12:24
Mike,
Very helpful thanks.
"How long will you drive after discharging the batteries"
This will vary considerably from time to time, however if I can get a week in between 240 volt charging with the odd drive of say 1 hour this would be ideal. The existing 120 ah I have will only cover this in ideal conditions. The extra 120 ah will mean I won't have to worry too much.
"Is it important to charge the vehicle battery fully first"
No not really.
From your advice it seems that a simple set up will work as long as I have correct wire protection and limit voltage drop to achieve a minimum of 13.8volts.
Can you recommend a circuit breaker. I have one, 40 amp from Autobarn.
I haven't earthed either, any suggestions here?
Thanks again
Spade Newsom
FollowupID: 399507
Follow Up By: Mike DiD - Friday, Dec 30, 2005 at 12:39
" the odd drive of say 1 hour "
- you COULD Boost charge batteries in an hour, but it would shorten their life and need higher voltage than from an Alternator. From an Alternator you are unlikely to put more than 25% charge into EACH battery if driving.
"Is it important to charge the vehicle battery fully first" - No not really.
- then don't bother with an Isolator between Auxiliary and Trailer batteries
"Can you recommend a circuit breaker. I have one, 40 amp from Autobarn. "
- small DC Circuit Breakers can weld shut with the 1500 amp short-circuit current from a car battery. It is dangerous to use them as the ONLY method of current limiting. Use an automotive Fusible Link - available up to 100 amps or a Maxi Blade Fuse.
Mike
FollowupID: 399511
