troopy seat swaps
Submitted: Thursday, Dec 29, 2005 at 20:55
ThreadID: 29239 Views:5041 Replies:6 FollowUps:4
I have a 1995 75series troopy RV with standard drivers bucket and a 3/4 passenger seat.Does anyone know of a simple swap for 2 bucket seats from another landcruiser or patrol etc.?Thanks in advance for any help.
Terry
Reply By: Fozbear - Thursday, Dec 29, 2005 at 22:06
Terry,
I remember reading somewhere that someone put some in from a celica but had to alter (and engineer) seat mounts.
Just as an aside, the passenger seat in the troopy, can it fit an adult and a kid?
I notice there is a centre seat belt in it.
Hope this helps a bit.
Steve
AnswerID: 145948
Follow Up By: Terryfied - Thursday, Dec 29, 2005 at 23:57
Steve,the seat will fit an adult and child although the wife prefers it all to herself, where as my 2 daughters like to sit in the front when doing water crossings or climbing hills.
Terry
FollowupID: 399463
Reply By: glenno(qld) - Thursday, Dec 29, 2005 at 22:13
My troopy has falcon buckets (looks like XF falcon seats) and the runners have been modified (bits welded on) and compliance plate . I have seen in an aftermarket seat shop where they have redone the original seats up . Very very comfy .
AnswerID: 145950
Reply By: hombra - Thursday, Dec 29, 2005 at 22:22
My troopy had the passenger seat cut down, restuffed and retrimmed to make it into a single seater..the headrest ends up being slightly off centre, but isnt an issue...it was like this when I bought it, but I'm sure any auto trimmer could do the job easily.
This may be another option for you to consider.
AnswerID: 145951
Reply By: Topcat (WA) - Friday, Dec 30, 2005 at 00:06
Hi Terry, if you can get another troopy driver's side seat you can reposition the tilt lever arm to the left hand side. Also if you position the seat so that the left side floor mounting bolt holes are in line with the existing bolt holes, then position the right side slide bracket in the same position forward to back as the left one, you will find that if you mark out the two floor bolt hole positions & carefully drill through the floor (& not into the fuel tank) using a drill the size of the existing tapped nut size you will find the back nut position for the right side slide bracket (the front one is already there on the inside crossmember). When the troopy floor panels were manufactured the seat mount nuts were welded in place for left side bucket seats as well as 3/4 seats, but the holes were only drilled for the 3/4 seats. Only those for the 3/4 seats are imported to Australia. The Troopies exported to the some of the Middle East countries are fitted with either the 3/4 passenger seat or a single bucket passenger seat the same as the drivers side. I found this out when I went through the same exercise in my troopy as you are proposing.
AnswerID: 145963
Follow Up By: Michael B - Saturday, Dec 31, 2005 at 11:25
Topcat,
No doubt about the benefits of this forum..
Sounds just what I am looking for, thanks. Mine is a '94 RV so shud be same as.
Will start a search for a decent troopy drivers seat.
Any other 'hidden' problems involved or was it as straight forward as you make it sound?
Michael B (SA)
FollowupID: 399631
Follow Up By: Topcat (WA) - Saturday, Dec 31, 2005 at 13:40
There shouldn't be any 'hidden problems' that I know of. When you mark the position of the back nut you should see the spot weld marks around the nut which indicates you're in the right spot. It may be safe to drill a small piilot hole first. As I have already mentioned, you should see the front mounting nut position on the inside crossmember when you lift the floor cover from that area. Cheers.
FollowupID: 399646
Follow Up By: Michael B - Sunday, Jan 01, 2006 at 20:46
Thanks Topcat,
Crawled over and under the truck today, found the captive nuts used on the left hand drive units.
Amazing what u can find when pointed in the right direction..
Noticed that even the floor mats, plastic that is, have a cut out on the passenger side to accomodate the accelerator stop when used in left hand drive, cunning these Japanese!!!
Michael B (SA)
FollowupID: 399773
Reply By: old mate - Friday, Dec 30, 2005 at 09:55
What about seats from a 78 or 79 series Toyota? They are much more comfortable and wrap around the sides to give lower back support. They are heaps better than the seats from a 75 series.
AnswerID: 145979
Reply By: Member - David M (VIC) - Friday, Dec 30, 2005 at 12:50
Hi Terry,
I have front buckets out of a Tarago in my Troopy. Some modification needed, but they offer a lot of comfort, lumber adjustment, wrap around etc. As my Troopy was an 11 seater, I have also installed a rear bench seat out of an early Tarago as well. This folds up like a normal station wagon seat, when not required.
David M!MPG:3!
AnswerID: 145991
