Holiday reading for Diesel-heads
Submitted: Friday, Dec 30, 2005 at 10:42
ThreadID: 29243 Views:5211 Replies:8 FollowUps:14
Hi OzExplorers,
Hope we all had a safe and happy Christmas and are now looking forward to a fun night for New Years Eve?
For owners out there who are forward-thinking and discerning enough (?) to own a diesel-engined vehicle, I've just added a new page to my website. It's entitled "Technical Info" and the first instalment "Turbo Talk No.1 - Diesel Engine Basics" (a .pdf download) has just been posted. This is intended to explain some of the fundamental differences in the operation of petrol and diesel engines and, hopefully, dispel some of the myths too.
I intend to add articles to this page from time to time and suggestions, comments, corrections and questions are always welcome. Please let me know what you think.
Ian
Reply By: Snowy 3.0iTD - Friday, Dec 30, 2005 at 11:46
Ian
Stuff on EGT was interesting. Having read various peoples experiences with the 3.0lt Patrols, I have come to the conclusion they can suffer to major faults. One is the air mass flow sensor stuffing up possibly causing the turbo to overboost, to guard against this I am going to get a boost gauge installed. The other main weak point seems to be the Exhaust Gas Return (EGR) valve, the purpose of this valve I am unsure of as I would have thought that feeding exhaust gasses back in to the engine would increase the cylinder temperature for no power or efficiency gain. What are the consequences of this failing in the open or closed position, could it simply be removed or locked in the closed position for peace of mind? How far away is your combined digital boost/EGT gauge from the marketplace?
Snowy
AnswerID: 145985
Follow Up By: bombsquad - Friday, Dec 30, 2005 at 11:59
I think the EGR valve is purely a pollution controll measure, and has no positive effect on power or economy. I recall reading an article on the Patrol 4.2 TD, where it explained that it was the only bit of electronic gear on the 'old tech' motor, which was easily (and illegally) disabled, suposidly to give a little more power and better economy. Perhaps someone with better mechanical knowlege will be able to ellaborate on this.
Cheers Andrew
FollowupID: 399504
Follow Up By: Ian from Thermoguard Instruments - Friday, Dec 30, 2005 at 14:04
Hi Guys,
Here's a bit of a blurb I wrote about EGR in a post a few months back:
"The dreaded EGR (Exhaust Gas Recirculation) - never been able to work out the logic of it meself...
The theory goes: very high combustion temperatures cause nitrogen and oxygen in the combustion air to combine to form oxides of nitrogen (I think the bad ones are NO & NO2,). Whichever ones, these are the major culprits in forming photo-chemical smog in large cities, so the powers that be have declared that vehicles must put out less than a certain % of oxides of nitrogen to meet emission standards. And the method they use: dilute the combustion air charge to the engine by mixing some of the exhaust gases back into the inlet system under certain conditions.
The result: combustion temperatures are reduced because the effective percentage of oxygen in the combustion 'air' is now less than the
'natural' level of about 21% - and a lower PERCENTAGE of oxides of nitrogen is present in the exhaust gas. BUT, I've never been able to reconcile the fact that EGR, by it's very nature, reduces the operating efficiency of the engine and therefore, the engine must use more fuel (and overall, produce more exhaust products!) to accomplish the same job!
It's always seemed to me to be a bit self-defeating. I mean, the manufacturers use turbo-charging, high-pressure, extremely finely atomised injection systems and precise electronic controls on injection timing and duration to get the maximum possible efficiency out of modern diesels - than slap on EGR to undermine their best efforts??
Getting a bit off-thread here - back to you question about the TD42Ti Nissan engine. From the horses mouth (Nissan technical bulletin):
"EGR (Exhaust Gas Recirculation) has been adopted to the TD42Ti. EGR is added to improve emission performance, ie; lower the NOx emissions.
The EGR lowers engine combustion temperatures which has the added benefit of reducing the NOx emissions.
In the case of the TD42Ti part of the EGR piping is a water cooled unit."
and
"To assist in maintaining lower combustion temperatures, the exhaust gas that is recirculated back into the engine via the EGR system is further lowered in temperature by an EGR cooler." [and more unnecessary load on the cooling system??]
Now, far be it from me to suggest anyone remove such an important anti-emissions device, but that EGR cooler looks like it could be easily converted into a nice camping shower hot water heater...
One last point: should anyone remove the EGR system (for, say, off-road competition??), be aware that your full load combustion temperatures will rise, as will the maximum exhaust gas temperature [EGT] - simply because you are now burning your fuel in 'real' air."
Hope this helps. Perhaps I should elaborate on this as another "Turbo Talk" topic?
Ian
FollowupID: 399524
Follow Up By: bombsquad - Friday, Dec 30, 2005 at 14:22
Gday Ian
Does the EGR actually decrease the EGT as you state, I understand it should, but in the reduction of the O2 in the combustion chamber therefore increase the fuel/O2 ratio increasing the EGT?
FollowupID: 399525
Follow Up By: Member - Jeff M (WA) - Friday, Dec 30, 2005 at 15:25
Well there you go, I was going to ask you your opinion on EGR valves but someone beat me to it!! In the surf it's a vacume operated mechanical type valvue (as far as I understand) that closes under low vacume pressure (idle) and opens under full load. a "friend" of mine has blocked his vacume hose with a screw and has found his vehicle performs much better both power and economy wise and blows a lot less black smoke under load.
Interesting about the EGT temps being higher, something I will have to watch out, I mean tell him to watch out for. ;-)
FollowupID: 399537
Reply By: OLDMAGPIE - Friday, Dec 30, 2005 at 11:56
ian, thats a good read mate, even i could understand it , well sought of, thanks for the info cheers
AnswerID: 145986
Reply By: Member - Roachie (SA) - Friday, Dec 30, 2005 at 12:03
Ian,
Thanks for that illuminating account of various internal goings-on....I thought the last bit about the fuel/air ratio of diesels was most enlightening indeed!! I look forward to the future issues, especially the intercooler aspect as I am still quite confused about the possible merits v the possible pitfalls of this additional bit of hardware.
Cheers and happy New Year.
Roachie
AnswerID: 145987
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Dec 30, 2005 at 21:48
G'day again mate. I have been poring over this a bit since Bruce sent me the addy last night on intercoolers. I reckon its worth reading through as it has definitely confused me. You will need to look down the page to "Intercoolers Must Read!! You want to know more?"
I had been attracted to looking at the grey imports to replace the tiddly one in the GU but I would have to be very careful. Some reduce the air pressures of the turbo by 2-3 psi on the back side of the intercooler. Hardly an enhancement :-(
An observation of three friends all driving turboed GUs to Cape York this last year. Fuel economy didn't vary between the intercooled one and the other two non intercooled ones. Nor did it appear power did either. They are all unmodified in the engine but maintained by one guy who is the mechanic in our local community. Funny how we have been sold on these intercoolers on the 4.2. It may be slightly denser air they ingest. I would look forward to some info to reinforce or argue the case
FollowupID: 399572
Follow Up By: Member - 'Lucy' - Friday, Dec 30, 2005 at 22:45
WHAT! You Haven't Got one?
Look out Annette, he is going to raid the kids piggie bank to get one, and maybe his super fund and his poor old mums purse.
I am absolutely p i s s e d and amazed that you don't have one these Roachie.
What happened, SA in the 4WD dark ages and they burn any literature on such a nasty god fearing piece of apparatus.
Annette censor all you Mags in fear of you placing the family in the Bankruptcy courts.
You are just lucky they don't have/run debtors courts like they used to in good old mother England.
I'll take a breath now and look forforward to seeing a brand new sparkling, air rammed via bonnet scoop intercooler in your rig next time I visit.
Ooooooooooooo! you are such good value.
FollowupID: 399580
Follow Up By: Member - 'Lucy' - Friday, Dec 30, 2005 at 22:50
By the way I was out driving arounf in the Troopy today, all 3.2T of her in 39C heat.
Air-Con blowing chilled air on me and cruising up and down a hill or two five times steeper than any Humock you can find.
Guess what. Temp guage never moved from usual spot and Ian's EGT gauge only got to 430C with the speeds varying from 60 - 100kph.
Power steering pump all ok! however thats a camp fire story that one, after I've had a few and feel like sharing.
FollowupID: 399582
Reply By: Member - John C (WA) - Friday, Dec 30, 2005 at 12:48
Ian,
I also enjoyed your article and look forward to others. I operate a Nissan GQ without all the electronic gizmo's and do a lot of caravan towing.
I do note the excess fuel issue is potentially a problem. To reduce the soot deposits on the offside of the van I have turned my exhaust pipe outlet forty five degrees towards the road so I can watch for the black smoke in the rear vision mirror and back off the throttle to suit in these circumstances.
Please expand on this issue in further articles.
AnswerID: 145990
Reply By: rob1 - Friday, Dec 30, 2005 at 16:02
With regard to the Nissan 3.0 Td mass airflow sensor, is this something that can be cleaned (I hope this isn't a silly question.....oh well) As I understand, it is a wire protruding into the airflow, downstream from the air cleaner, so if it gets "dirty" can it be removed and cleaned; for eg. with a soft cloth and metho?
Rob
AnswerID: 146010
Follow Up By: bombsquad - Friday, Dec 30, 2005 at 16:24
Gday Rob
I cleaned mine on the 2.8 the other day. Nissan Dealer advised to clean it with Brake Cleaner(aerosol) and compressed air. Be carefull though, I dont think you'll get much change out of $1000.00 for a replacement. Brake cleaner is similar to carbie cleaner, but is supposidly less abrasive. Good Luck! Oh, and don't do what I did and unscrew the panel on the side to see where the wires go - that will break soldered jounts and require you to do some surgery to get at the circuit board within the unit to solder them back on, provided the 3.0l unit is similar to the 2.8.
I did this after a post I did with good responses concerning poor fuel economy. from the guage only, I seem to have about a 10% improvement there, but I'll fill up on Wednesday when I get home from work and post the first result.
FollowupID: 399549
Follow Up By: Member - Glenn D (NSW) - Friday, Dec 30, 2005 at 17:36
You can also get electrical contact cleaner in a can from the auto store. Probably would advise against using a cloth, but you dont need compressed air , you can let it air dry .
Again not sure of the construction of the sensor , some have the wire inside a glass bulb and are more robust.
Hope this helps
Glenn.
FollowupID: 399560
Reply By: Willem - Friday, Dec 30, 2005 at 16:31
Thanks for that Ian
At least now I know why the old truck was blowing black smoke when I left the radiator cap off a while back. Luckily for me I stopped in time and managed to retify the matter. So far the engine is still running OK.
AnswerID: 146012
Reply By: Motherhen - Friday, Dec 30, 2005 at 21:13
Thanks Ian, we are following these topics with interest. Got the EGT gauge fitted some time back (you gave us helpful advice on temperatures via your website) at the time. Now fitting boost gauge before we go away on holiday; 3ltr td has just clicked over 100,000 kms. PS: Can i proof read your pages before you put them on your website? (Gee my children's school teachers used to hate me - i used to send the newletters back with yellow highlighter all over the 'typos')
Happy New Year
AnswerID: 146032
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Dec 30, 2005 at 21:55
Your other post went on for days Motherhen. I think has some interesting points - enough to ring to talk with one of the forum members this morning. LOL
I particularly laugh at the last comment you made here though. I actually gave a mark of 11/20 for the careers teacher at the local school to have my dearly beloved put the business stamp on it and sent it to the principal :-(
FollowupID: 399574
Reply By: Member - 'Lucy' - Friday, Dec 30, 2005 at 23:06
Can somebody, anybody please tell me why the 2 most asked questions re turbo chargers are.
(1) will it affect my fuel consumption
(2) Will I use more fuel.
When it is as obvious as the dangly bitz on a stud bull.
YES! it will affect you fuel consumption because the whole idea of a turbo is to give you more power and if you want to use that extra power its cost is fuel.
People who suffer from the misconception that putting a turbo on a vehicle is a fuel saving device/move should seek professional help.
Now if you want to save on fuel there are two fantastic devices available which are.
The Fitch fuel doovy and and Hi-clones .
To nullify the effect of my turbo using more juice I have mulled over the idea of fitting two Fitch's in line and four hi-clones. ( two pre inlet manifold) and one either side of the turbo on the outlet side.
AnswerID: 146048
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Dec 30, 2005 at 23:52
and? So you are going to spend money on two devices x several that won't do anything for you except lighten your pocket are you Mr Lucy?
You would be better to mull some wine then mull over it until the thought went away. Could mull over some wine if you came this way....
Have a prosperous New Year sir
FollowupID: 399589
Follow Up By: Member - Ed. C.- Saturday, Dec 31, 2005 at 00:35
well, umm, actually......
With my previous vehicle (GQ TD42), after I had the (AXT) turbo fitted, because it was doing the job just so-o-o much easier, IF one drove within the posted speed limits, it was good for close to 100kms more per 95L tank than before the turbo was fitted.... True!!!...
which demonstrates that a turbo *can be* a fuel-saving device, but that's not why we fit 'em, is it????
Of course, the picture changes once ya start to USE the extra power, and "let it have it's head" a bit;-)))
Confucius say.....
FollowupID: 399590
Follow Up By: Member - 'Lucy' - Saturday, Dec 31, 2005 at 01:10
Firstly - Moses
You leave my dabbling in 'high technology' alone and git back to those cows. I am sure they would love to 'mull a wine' or two with you. (LOLO)
Just leave this high tech stuff to us city slickers.
Now! if it was for the heat wave, I most probably would have been calling in tomorrow. However, it will be home in the Air-con until it 'blows over'.
Second - ED. C.
Precisely my point.
You utilze a turbo for power to do what ever it is you have to or need to do.
Why would you buy/put a turbo on ( $3500 - $6000) to see if you can drive it a few cents cheaper.
If thats what you want/crave, then buy and drive a Hyundi Excel or a Vesper motor scooter.
Even better - walk as its the cheapest of the lot.
FollowupID: 399592
Follow Up By: Member - JohnR (Vic)&Moses - Saturday, Dec 31, 2005 at 07:37
You better come down here and walk to the shops a couple of times a day Lucy. You would be thinner than ever and never get anything else done. LOL
Been thinking of a motorcycle here too but a Vespa? My dad had a Hyundi but my feet tended to cover two pedals and they were too easy to hit the wrong one as my mother proved, God rest her soul. I need another garage to make that practical. I do have a car that is economical if I am to travel anyway. I think friend ED C has some other objectives too with the turbo apart from, but as well as the better economy. No need to hand chit on him over that. LOL
I am glad Moses has a turbo as he would be sluggish at his weight unless he had a 6 litre motor or something. Turbos actually make smaller motors more powerful so the weight advantage is there without the heavier chassis.
Am to be here by the aircon too Lucy. Have a good one, Dierdre too, won't you.
FollowupID: 399601
