80 series mystery noise
Submitted: Friday, Dec 30, 2005 at 14:44
MrBreeze
Hi, I've got a '94 80 series GXL auto that has developed a vibration/rattle type noise which appears to be coming from under the passenger side front floor.
It sounds like a heat shield or guard which has lost a bolt or such.
I cant see anything obvious underneath the vehicle that is loose or has lost a bolt.
Maybe its from the firewall or the dash ,hard to pinpoint it while driving.
Just wondering if anyone has had a similar problem?
Reply By: crusa - Friday, Dec 30, 2005 at 15:44
Hi Mr Breeze - My '94 80 series developed a rattle which turned out to be in the main muffler (right hand side) where an inside baffle came loose. Bit different to yours, took a while to work out where the noise was coming from. Exhaust
shop located the problem on the hoist............ good luck!
146007
Follow Up By: MrBreeze - Friday, Dec 30, 2005 at 17:26
thanks Crusa,
I'll check that out as I'd imagine a loose baffel would make a similar noise.
I'll let you know how I go.
399557
Reply By: Member - DickyBeach - Friday, Dec 30, 2005 at 16:42
Gentlemen,
I can't help but as I also have a '94 #80 GXL auto may I ask how many klicks you have on the clock?
146014
Follow Up By: MrBreeze - Friday, Dec 30, 2005 at 17:24
DickyBeach,
My unit has 62,000ks on the clock.
I've had a few minor problems with it since purchasing mid year.
As the car was in storage for a long while,(only 7,000klms since 2001),some ithings weren't working properly.
Now that the car has been driven most days it has loosened up a lot.
The main thing is that the econony has improved heaps (from 24/100klmpl to 17 klmpl) since cleaning the injectors and replacing the plugs,leads and filters.
399556
Reply By: Member - Davoe (Widgiemooltha) - Friday, Dec 30, 2005 at 21:40
Mines got exactly the same noise from the same spot at low idle - but I know the cause it is the tap extension from the underbody
water tank
146037
Reply By: Bob Y. - Qld - Friday, Dec 30, 2005 at 22:22
MrB,
We had a 90 model 80 series, before we bought our current 97 model. On passenger side, a support for the dash had broken off, spot weld, in behind, or just above the kick panel. The dash moved about a bit on corrugations. Can't remember whether it made much noise, but a dodgy place to weld, with all wiring and other flammables about. I just put a tek screw in it. Good enough at the time, sold it before the tek let go.
I'd be checking things like rear transmission mount, or something caught between chassis/body/trannie. Get underneath, and bang around with a rubber/nylon hammer.
Hooroo...
146040
Reply By: MrBreeze - Saturday, Dec 31, 2005 at 11:39
Thanks all for your help.
Bob when you mentioned the dash it made me have a closer look this morning.
It was a plug to nowhere branching from the wiring harness behind the LHS kick plate.
The plug was rattling against the body ,making a hollow tinny noise.
Easily fixed!!
146082
Reply By: Member - DOZER- Saturday, Dec 31, 2005 at 15:57
Hey
Check the wiring behind the kick panel...it might be rubbing....this is where the diff lock computer lives for cross axle diff locks...
146102
Reply By: Hairy - Saturday, Dec 31, 2005 at 16:33
I had a similar noise and it was stones on the side step and lodged in the grooves under the side step.
146110
