LC 80 overheating petrol
Submitted: Saturday, Dec 31, 2005 at 16:16
ThreadID: 29268 Views:2198 Replies:7 FollowUps:1
Hi All
was reading post 28738, and reply below. this is same as mine is doing, fan spins for 3-5 seconds, so any idea on price below or should i get fan and clutch replaced how much would that be, and where in eastern sydney.?? thanks guys happy new year . steve.
Hi Jake,
When my 80 series was over-heating while towing heavy camper up hills, I got some excellent advice on this forum. The first thing I would check would be the bugs/mud in radiator, & if all that looks good go straight to the fan clutch. An easy way to chech it (as it was explained to me on this forum), is to put the vehicle under load i.e strap on the camper & go & find some hills on a warm day, & when the needle kreeps up higher then it should be, hop out & have a look under the hood with the wife at the controls. Whilst watching the fan get the missus to shut the car down, the fan should stop when the engine does. If it overspins then it is the cause of your problems & it needs some fluid. Easy job to fix.
Good Luck, OM&M.
Reply By: Peter 2 - Saturday, Dec 31, 2005 at 16:35
go see your friendly Tojo dealer next week and get some silicone fluid to add to the thermo unit.
do a search on silicone fluid and you'll find the part numbers.
also have a look at lcool forum there some info there as well.
AnswerID: 146111
Reply By: Billowaggi - Saturday, Dec 31, 2005 at 18:14
Hi Steve, if the fan clutch is low on fluid it is probably due to a faulty seal or bearing ,putting more fluid in will be a fairly temporary repair, also some clutches are factory sealed. The fan clutch for an 80 series is around $135 non genuine, on something as critical as the cooling system I would just replace it.
Regards Ken.
AnswerID: 146121
Reply By: Of Mice & Men - Sunday, Jan 01, 2006 at 11:01
Hi Steve,
That was my reply you stuck on the end of your question, when my 80 series was overheating, I fixed it myself for about 20 bucks. I'm not sure how mechanical you are, but to fix it, it was about a one hour job & two tubes of silicone. There is only a couple of tricks, on the diesels (not sure about your petrol) when removeing the fan & coupling, the fan shroud needs to come out as well, also you may need an impact driver to split the two halves of the coupling. One other thing is, do not wash out old silicone once the two halves are split, simply add the two new tubes to the existing silicone. It was mentioned earlier that adding the silicone is a tempary fix, well I fixed mine two years & 80,000 k's ago & still going strong towing my camper all over the place, definately don't go & buy a new coupling, when I priced them even the after market jobs were over $200. At the end of the day, if your not confident doing it yourself, take it to a mechanic you trust & get them to do it. If you have any other questions gjgrant@hotkey.net.au
Regards, OM&M.
AnswerID: 146160
Follow Up By: MYTTUF - Thursday, Jan 05, 2006 at 07:17
I too can testify that it's not always a temp fix. I refilled my coupling after being told there was a chance it may not work and have never had any further dramas.
Jonesy
FollowupID: 399989
Reply By: 120scruiser - Sunday, Jan 01, 2006 at 12:32
Try here
www.off-road.com
The part numbers for the silicone has changed but your toyota dealer should be able to get it easy.
I have done several and had no problems.
I would suggest to do it by the book as I have heard that they can disintergrate if you put too much silicone in.
120scruiser
AnswerID: 146173
Reply By: res.q.guy - Sunday, Jan 01, 2006 at 13:46
Hi Steve,
I have just read an article on cooling problems on 80 series, (Caravan & Motorhome No 74 - June 2005).
They replaced all the following parts with new Repco parts, for $1015 plus a day to fit them :
Heavy Duty Radiator (new, not re-cored), Water Pump and gasket, all the fan belts, all the hoses, Hydrostatic fan clutch assy, t/stat and radiator cap.
Neil
AnswerID: 146184
Reply By: Member - Davoe (Widgiemooltha) - Monday, Jan 02, 2006 at 02:29
I had exactly the same problem as you and fixed it by adding a tube and a bit of silicone. It is easy all you do is undo your shroud (removing it isnt neccessary but makes the job easier then there is 4 bolts holding the clutch assembly on - no belts need removing. you then sepperate the fan from the clutch and seperate the 2 parts to the clutch YOU MUST USE AN IMPACT DRIVER FOR THIS PART. It is then simply a matter of putting in as much silicone as you can and reversing this procedure to refit
AnswerID: 146272
Reply By: Member - DOZER- Monday, Jan 02, 2006 at 23:43
A friend of mine changed the usual list of things to no avail, and in the end, i gave him an electric fan to supplement the mechanical one....he proved that it was the mechanical clutch causing the problems when he turned on the electric one, as the temp went straight back down.....but he wont give it back as it makes his air colder.....
AnswerID: 146379
