dual fuel tanks
Submitted: Sunday, Jan 12, 2003 at 21:39
dino
I have just removed the LPG system from my GQ patrol and I am wanting to refit the original fuel
tank. I have an auxillary
tank already fitted under the drivers side and I want to keep this. Does anyone have any suggestions on how to have both tanks fitted so that I only require one filler. Any suggestions would be greatly appreciated.
Reply By: diamond - Sunday, Jan 12, 2003 at 22:07
hi dino would you like to use your
tank under the drivers side as a secondary
tank or use them both as one where they both empty together
11151
Follow Up By: Dino - Sunday, Jan 12, 2003 at 22:29
As a secondary
tank preferably.
6106
Reply By: Member - Peter- Monday, Jan 13, 2003 at 15:48
I have a second
tank fitted to 4 runner by A.R.B it has a 'Y' pipe gust inside the filler and this has worked
well , try talking to them
hope this helps .
11183
Follow Up By: Member - Mike - Monday, Jan 13, 2003 at 18:27
I have similar system in my GQ RB 30. Switch on console changes tanks, provides fuel gauge info, and transfers fuel to main
tank via separate filter. Filler is Y piece. Hose gauge to aux
tank does mean refilling is slower - clicks off if you try to be too clever.
Hope that helps
Mike
6153
Reply By: CLIVEB - Monday, Jan 13, 2003 at 16:35
Dino,
I am just going through the same exercise.
Mine is an EFI with the submerged fuel pumps,I am going to leave the existing sub
tank and pump and fit back the original with its own pump.
then use a 6 port soleniod to connect up the two tanks to the fuel and return lines.
As for the fill point ,brown davis has two neck fillers that fit in the original space, but they are $220 each (to much).
I will investigate the ARB offering but most likely will make my own from
car wreck parts.
I look forward to other suggestions on this site. Regards
11188
Reply By: nissan4x4 - Monday, Jan 13, 2003 at 22:08
hi dino,
Brown Davis are good people to talk to if you have any questions (and they're quite willing to talk). I just recently had them replace my "Y" filler with one of their twin fills. I had 2 issues with my "Y" fill, couldn't fit a hi-flow bowser nossel(nozzel?) into the aux
tank (my GQ's diesel), but more importantly, fuel will transfer between tanks when going thru steep inclines (as we saw very noticably on our trip to
Cooper Creek via
Broken Hill) mucking up calculations on how much you actually have on board.
11235
Follow Up By: Dino - Sunday, Jan 26, 2003 at 19:01
Thank you to all for your help.
6793
