AnswerID: 146409 Submitted: Wednesday, Jan 04, 2006 at 16:11
4runner
replied:
Hi. I have a 1991 V6 4Runner and find that it is a thirsty little sucker. The best I have had out of it was 12 litres per 100 Km , but on an overall average 13 -14 litres per 100Km is about as good as it gets. Yes, you do have to row the gearbox at low speeds, and on climbing long hills one has to drop from 5th down to 4th. From others I have spoken to about the lack of performance at low speeds , this is normal for a vehicle that weighs in at approximately 2 1/2 tons. Thats nearly 4000 Lbs in Imperial measurement. One thing you should do as others in this
forum have suggested, is to replace the fuel pump and also the fuel filter. Failing that then get the fuel injectors checked and cleaned. But for HEAVENS sake if you have to replace them , whatever you do dont buy the injectors from Toyota, as they quoted me $260 per injector. Multiply by 6 and you will see what I mean. Repco or other good quality aftermarket accesory shops can do better than that in terms of price.
Oh and before I forget, have you checked your air filter element????? Its placed in the most ridiculous position, right behind the left hand head lamp and therfore sucks in every conceivable bit of dust and dirt. A snorker would be a better proposition. Hope that has been of some help.
Reply 5 of 7
