Duel Battery System which one?
Submitted: Thursday, Jan 05, 2006 at 15:29
ThreadID: 29375 Views:5761 Replies:11 FollowUps:17
What is the BEST duel battery (and Battery)system, for the LC100 series, I will be mainly be running a fridge and HF Radio all the time. I don't mind paying extra for a better quality system.
Reply By: Mainey (WA) - Thursday, Jan 05, 2006 at 16:03
Good to read some one is asking for advice on a "quality product" without asking for it to be the very lowest priced as well...
Your's is a Simple and EASY question to answer and is based totally on my own experience with a previous Smart Solenoid and electronic Piranha system on the same vehicle.
ROTRONICS
http://www.rotronics.com.au/4wd.CaravanApplicationSelect.htm
As for batteries:
as you are running the fridge, then the advice of ALL battery manufacturers specifically state that DEEP CYCLE batteries are made to handle long slow discharge, same as you get from a fridge, and a starter battery is designed for a shallow quick burst of power as used by the starter motor, but you will find some people who claim to know far more than the battery manufacturers and will inform you that a starter battery will be ok, but they neglect to mention that a Deep Cycle would be far better suited for the job... price and also the method of recharging the DC battery has something to do with it also.
Another point to remember is that the recharging of the DC battery has to be done as specified by the Isolator and battery manufacturer for best results.
For further confirmation phone any commercial leasing company that rents out “Winnabagos” and similar Mobile Homes and see if they use ‘starter batteries’ as Aux batteries in their vehicles.
AnswerID: 146592
Follow Up By: Topcat (WA) - Thursday, Jan 05, 2006 at 17:51
I fully agree with Mainey's comments. Been running deep cycle batteries with a 'Rotronics' system for years, & as you said if you don't mind the expense then also go for a decent solar energy setup (at least 120watts) & you will have a good re-charge system for your deep cycle battery. Cheers
FollowupID: 400086
Reply By: jp - Thursday, Jan 05, 2006 at 16:04
Hi Cobber My system is from ABR. Derek makes up dyi systems or if in Brisbane he might fit it.
AnswerID: 146593
Follow Up By: ACDC - Thursday, Jan 05, 2006 at 18:54
All he sells is el cheapo !!!
FollowupID: 400091
Follow Up By: jp - Thursday, Jan 05, 2006 at 21:21
See post furthert down the page.
Cheers John
FollowupID: 400124
Follow Up By: 4145derek - Thursday, Jan 05, 2006 at 22:07
Cheap shot ACDC
I don't recall ever selling to you. Please return your purchase with and I will give you double your money back.
My systems have been in use for over 7 years and not one fault.
Please refrain from slander this is a forum for advice and help not mud slinging. Especially if you don't know me !
Contact me directly if you have a gripe of some kind.
ABR djbester@bigpond.net.au (07) 3890 5899
My Site
New Pathfinder
FollowupID: 400138
Follow Up By: Leroy - Thursday, Jan 05, 2006 at 23:14
nice plug derek.......hehe
Leroy
FollowupID: 400161
Reply By: Plunger - Thursday, Jan 05, 2006 at 16:08
Cobber
I think you've just opened a can of worms! That's like asking which is the best fridge!!
Have a look here... just one set of views from a small Brisbane company. They just did my 100 series using System 7 (see brochure):
http://www.cometbatteryco.com.au/brochures.php
Plunger
AnswerID: 146596
Follow Up By: Mainey (WA) - Friday, Jan 06, 2006 at 10:36
Plunger,
He did ask for... the BEST
Yes and without reference to price, this is a big change on any 4wd forum!
I believe Rotronics is the best battery isolator system available!!!
The BEST “performance” fridge is the.... Reefer Premier
0f course some-one without a Reefer will always disagree
-unfortunately they have never used one to know the facts
Therefore their idea is only one sided and biased in the negative.
How can any-one make a valid and credible comment on any product they have NEVER used, and probably never even seen, wether it's a battery isolator or a fridge??
FollowupID: 400235
Follow Up By: Plunger - Friday, Jan 06, 2006 at 12:51
Mainey
Thank you for putting me straight!
Plunger
FollowupID: 400267
Reply By: 4145derek - Thursday, Jan 05, 2006 at 16:52
Derek from ABR
Give me a ring if you want a chat.
Regards Derek.
(07) 3890 5899
AnswerID: 146602
Reply By: David78 - Thursday, Jan 05, 2006 at 16:56
Hi there Cobber,
I have a Rotronics unit and Comet deep cycle secondary fitted in my Discovery.... works a treat and the Rotronics customer service is great to...
good luck,
Dave.
AnswerID: 146605
Reply By: Brad, W.A. - Thursday, Jan 05, 2006 at 19:20
I have a Piranha DBE-180S set-up on my 80 Series, it has worked faultlessly over all sorts of terrain. A solar panel set-up can be hooked into it so you can charge the auxilary battery on extended stops. It's like everything though, people have their own preferences and experience with pariticular brands so the best thing you can do is research and sort through all the bull and buy something that you are happy with.
AnswerID: 146646
Follow Up By: Mainey (WA) - Thursday, Jan 05, 2006 at 20:11
Brad, there is nothing at all wrong with a Piranha DBE ' S series' Isolator, as an isolator -
I needed to be able to simply charge my Start battery as well as the two Deep Cycle batteries from the Solar panel, and the Rotronics allows that, the Piranha does not, also the cable lenth can be lengthened on the Rotronics, not on a Piranha, yes just simple things but important to me.
It's no good being the richest corpse, enjoy it while you can!
FollowupID: 400109
Follow Up By: Sand Man (SA) - Friday, Jan 06, 2006 at 11:41
Mainey,
Interesting comment you have made here.
I also have a Piranha DBE "S" series Isolator and although I have never had the need to charge the starting battery via my Solar Panel, I would merely connect it directly to the battery. Easy as!
Everyone is going to have their own opinion based on their own particular criteria and experiences.
I actually had an initial problem when the Piranha was installed, but the fault turned out to be due to a faulty installation (bad earth connection) and not due to the Isolator, or Battery.
All of the leading brand Isolators, be they Piranha, Rotronics, Redarc, etc. will do the job they are designed to do and that is to protect the starting battery from discharge to the point that you cannot start the vehicle.
Any additional "features" of individual products are merely that, features.
Not many people would need the ability to charge their starting battery "through" the Isolator rather than simply bypass it.
My personal opinion of course.
Bill
FollowupID: 400248
Follow Up By: Mainey (WA) - Friday, Jan 06, 2006 at 16:58
Sand Man, My Solar system is installed on the roof and stays there with the cable going into the roof, via a marine quick-clip connection, with the cable then running between the hood lining and the underside of the roof, out of sight and out of the way, connecting to the Steca Solar regulator and with all cables still out of sight and out of the way going to the Deep Cycle batteries and the fridge also, so it would be a pain to disconnect any batteries or Solar panels as all the cables are all 'hidden' and it only takes 5 seconds to connect the mini 3 inch 'jumper cable' to the two Rotronics Isolator box (+) battery connection bolts.
However, because I camp for extended periods in the bush & beach and by leaving doors open etc causes some minor start battery drain.
I use the two (+) posts on the Rotronics, (which are not on the Piranha) to connect the Start battery direct to the Deep Cycle batteries via a small 3 inch 'mini jumper lead' every few weeks, and all three are charged by the Solar system at the same time.
A major point you did not mention is that the Redarc Smart Solenoid system, which I once used, is recomended by the manufacturer to be used with two 'identical' batteries and not two different batteries, such as a Deep Cycle and a Starter battery, hence the reason I had to have my solenoid replaced to achieve a full charge to the Deep Cycle battery.
Yes, as you say they do connect and also DISconnect the Starter battery from the Aux battery to avoid Starter battery drain, BUT there is more to an Isolator than just DISconnection!
Both Piranha and Rotronics actually specify their systems will work 100% with two totally different batteries, however Redarc actually specify the two batteries should be identical :-)
(that's not an opinion - but a fact)
FollowupID: 400292
Reply By: jp - Thursday, Jan 05, 2006 at 21:19
AC.DC.
I invite you to come and have a look at my dual Battrey System, and point out what is C---P about it.
Cheers John
AnswerID: 146667
Follow Up By: ACDC - Thursday, Jan 05, 2006 at 22:02
It could be the $3 spike protector from pro----a or maybe the $8 led battery meter or even the $20 dual battery controller no no the $4 solenoid.
FollowupID: 400136
Follow Up By: 4145derek - Thursday, Jan 05, 2006 at 22:16
ACDC this is 2006 looks like pricing from the 60's. Technology has changed too.
FollowupID: 400141
Follow Up By: jp - Thursday, Jan 05, 2006 at 22:24
ACDC, are you in the business of selling Dual Battry systems, etc,as you seem to a wealth of knowledge.Dont want to inspect my system?
Cheers John
FollowupID: 400142
Follow Up By: ACDC - Thursday, Jan 05, 2006 at 22:35
I've seen them, electro parts sell them.
The prices quoted are what they cost out of Asia.
4145derek if your happy with your system and it works for you that's great.
FollowupID: 400146
Follow Up By: 4145derek - Thursday, Jan 05, 2006 at 22:53
Thank you ACDC for changing your tune.
As everything including the cars we fit dual battery systems to come from Asia. Including the the Asian Engel fridge, Asian Inverter, Asian Radio, Tv, Laptop .... need I go on.
I don't pay Asian prices and I'm sure Engel won't like it if you tell them their fridge costs $100 to produce in Asia. Asian components only form a small part of my systems which carry a full 12 month warranty. Most parts are Australian made including the labour all joints are soldered, sealed and fitted with heat shrink.
I'm sure it won't be long before we all need to learn to speak Chinese but until then lets enjoy the great outdoors and each other.
Happy New Year.
Regards Derek.
FollowupID: 400151
Follow Up By: Vivid Adventures - Thursday, Jan 05, 2006 at 23:55
I bought one of Derek's systems from him on eBay for a song.
Twas easy to fit. Has worked flawlessly with a deep cycle gel battery I have and is running my inverter driving battery rechargers and computers.
Everything I needed without going over the top.
My 2c worth
id Adventures Adventure Photography Tours>/a>
FollowupID: 400181
Reply By: Truckster (Vic) - Thursday, Jan 05, 2006 at 23:27
Every single one on the market has + and -, and you will get all sides here which can be good, but can take months to decypher the bollox from the facts.
Rotronics if you contact them will send you a CD with their gear on it. You can have a look for yourself.
There are probably 1040239840293402398 other threads on it in the past, so have a read back through.
I have the Piranha system in mine, and it has worked perfectly for 3 years. I would get it again, or keep it and put in next car without fail.
Good luck decyphering!
AnswerID: 146698
Reply By: Member - Andy Q (VIC) - Thursday, Jan 05, 2006 at 23:49
G'day cobber, as you've read, everyone has given good advice and recommendations. I too at one stage last year asked for the same advice and recieved many responces on brand and price. I think the best advice I received was to make and fit the dual battery system myself. After going to my local battery dealer and armed with the products I needed, with his help(read advice) I successfully fitted the battery system. I run 40L fridge(continuos), compressor and accessory interior lights. The system cost me less than half the price of Pirahna and ARB, included in the price was a replacement cranking battery. Hope this helps, give it a go it is not rocket science....good luck
AnswerID: 146708
Reply By: Member - Ozdyssey (QLD) - Friday, Jan 06, 2006 at 00:00
Rotronics
AnswerID: 146710
Reply By: MikeEgan - Friday, Jan 06, 2006 at 09:17
the Rotronics fitted to my LC100 blew up twice. Toyota dealer replaced it with a Redarc which works great http://www.redarc.com.au/sbi.htm
powers up my 40l fridge and two way
my mate had a Rotronics in a HJ47 which is went phut phut smoke fail kaboom
AnswerID: 146746
Follow Up By: Mainey (WA) - Friday, Jan 06, 2006 at 10:59
Mike, you say "the Rotronics fitted to my LC100 blew up TWICE"
Don't you think it could have something to do with the installation method to have TWO (one would have to have been NEW & still under warranty) battery isolators "blow up" in the same vehicle?
I would have been talking to Rod at Rotronics and getting the correct installation information from them when the second NEW system "blew up"
I’m positive they would have done the right thing about your isolator problems and you would have a decent system, and yes I can say that because I did have a Redarc system, but found it would not work correctly with my Deep Cycle battery, so I sold it and replaced it with a Piranha electronic system.
Maybe you and your mate are just really "unlucky"
Don't suppose either of you win tatslotto too often then?
FollowupID: 400240
