Battery Terminal Gunge
Submitted: Thursday, Jan 05, 2006 at 17:05
Mad Dog (Australia)
Fellow Citizens, Do those green coloured pads that fit on the battery terminals do any good, just cleaned a lot of gunge of both terminals which got me thinking about those washers.
Reply By: Member -Dodger - Thursday, Jan 05, 2006 at 17:13
Yep they do help. Also spray lanolin pressure pack on the terminals also helps it is available in stores like supa cheap.
146610
Reply By: Notso - Thursday, Jan 05, 2006 at 17:39
Get some really greasy grease and rub it into the pads before you shove em over the terminals. Make sure you put heaps of grease on em.
146618
Reply By: Member - David 0- Thursday, Jan 05, 2006 at 18:49
Lanolin grease is perfect. Lasts for ages.
146635
Reply By: Member - Ian H (NSW) - Thursday, Jan 05, 2006 at 20:46
To save having a sticky, gooey mess on the terminals use "Battery Post Protector". It comes in a spray can, about $12 and does a great job. Get the posts and teminals clean first then spray sparingly but carefully over the connection. Good luck.
146658
