GU 3.0lt dual batterys
Submitted: Thursday, Jan 05, 2006 at 17:47
Goons
I am in the process of installing a redarc system in the patrol.
Where is the best place to mount the solenoid? Any advice or pictures appreciated.
Reply By: Notso - Thursday, Jan 05, 2006 at 18:33
I Mounted
mine on the metal bracket near the plastic canister between the firewal and the second battery cradle.
146631
Follow Up By: Squizzy - Tuesday, Jan 10, 2006 at 07:26
Ditto,
mine is on the same plate facing forwards.
Ensure that the earth from your second battery is connected to the motor.
Mine was connected to the same plate that the majority of earth wires are using (and where the redarc is), and while in
Darwin earlier this year my battery was not charging properly.
An auto electrician up there changed the earth and all was sweet.
Geoff.
400882
Reply By: Muzzgit (WA) - Saturday, Jan 07, 2006 at 03:28
Sorry about the late response but I've been down at Margaret River (someone's gotta do it??) for the week.
The redarc in my 3.0 GU patrol is simply tech screwed into the firewall on the drivers side not far from the brake booster.
Be carfull, the metal is not as thick as it is on a toyota and too much force/speed will strip tha tech screw. (ahem, I have no idea how I know this)
Muzz
146932
Reply By: PandJ - Tuesday, Jan 10, 2006 at 00:00
Hi Goons,
I bolted myn on the metal plate between the abs brake equalizer and the plastic header
tank for radiator,and it's on the front side of plate.
147528
